Connection problem with video card and motherboard.
582 (0.10/day)
Dallas, Oregon
System Name Custom FX
Processor AMD Ryzen 5 1600X @ 4Ghz
Motherboard MSI B350 Tomahawk
Cooling EK A240 Kit
Memory G.SKILL G.SKILL Ripjaws V Series DDR4 3200 8GB
Video Card(s) EVGA GeForce RTX 2070 FTW3 Ultra
Storage SAMSUNG 960 EVO M.2 250GB NVMe OS Drive/Seagate Hybrid SSHD ST1000LM014 1TB MLC/8GB 64MB Cache
Display(s) ASUS VE228H 21.5 inch
Case Raijintek Thetis
Power Supply Silverstone Strider 750 Plus 750W Modular
Mouse Red Dragon M715 Dagger
Keyboard Corsair Strafe
I have a problem with my new motherboard ( ASUS SABERTOOTH 990FX R2.0 ) and my video card ( GIGABYTE GV-R927XOC-2GD Radeon R9 270X 2GB ).
If i bump my computer even the slightest or if my son goes bouncing by my monitor will go black. I will ether need to restart my computer or sometimes open the side panel and give the video card a little push in and it will all work fine.
I never had this problem with my old motherboard and this video card just this new one. I have tried using something to support the video from sagging down at all even tho it doesn't but that still didn't help.
Anybody out there know what i can do to fix this problem?
1,181 (0.18/day)
Processor 7900
Motherboard Rampage Apex
Cooling H115i
Memory 64GB TridentZ 3200 14-14-14-34-1T
Video Card(s) Fury X
Case Corsair 740
Audio Device(s) 8ch LPCM via HDMI to Yamaha Z7 Receiver
Power Supply Corsair AX860
Mouse G903
Keyboard G810
Software 8.1 x64
Can you lay your case on its side and see if it still has this problem?
582 (0.10/day)
Dallas, Oregon
Cooling EK A240 Kit
I have tried that and it still does it just it takes a little harder hit or bounce but still not really that hard of a hit or bounce. And also I really don't have the room to lay it on its side all the time.
8,069 (1.39/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
Is the GPU seating properly? Sometimes, the tabs on the bottom of the expansion slot covers attached to the GPU don't fit through the slots in the motherboard tray.
831 (0.29/day)
System Name Gaming Desktop
Processor i7 6700k
Motherboard asus rog alpha
Cooling H110i
Memory Corsair Dominator 16gb DDR4 3200
Video Card(s) GTX 1080
Storage EVO 840 500gb, EVO 850 500gb, Perc 710 Raid WD RED 4tbx4
Case Corsair 500r
Power Supply Antec 850
Mouse Logitec G502
Keyboard a cheap dell
did you miss the center motherboard standoff?
1,181 (0.18/day)
Processor 7900
Cooling H115i
Case Corsair 740
Mouse G903
Keyboard G810
Software 8.1 x64
Can you try using one of the lower slots and see if it still have this problem?
582 (0.10/day)
Dallas, Oregon
Cooling EK A240 Kit
Forgive my Noobness but this is my first at the time High end Motherboard and ether completely forgot or didn't realize that two out of the 4 full size PCI-E slots run at full 16X speed. But thanks for your tip that worked now I don't have to worry about if i bump my computer or when my son is jumping around the screen going blank thxs again.
1,181 (0.18/day)
Processor 7900
Cooling H115i
Case Corsair 740
Mouse G903
Keyboard G810
Software 8.1 x64
12,195 (1.88/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
If moving the card to a different PCI-e slot resolved your problem, you demonstrated a fault with your "NEW" expensive motherboard. You need to RMA it as this may be just one (and/or the first) of multiple problems to appear.
If me, I would move the card back to the original slot and see if the problem returns. If it works fine, then I might assume something was just loose before. But if the problem returns, that conclusively proves the motherboard is defective and I would not hesitate to return it under warranty immediately.
5,657 (1.15/day)
System Name Space Station
Processor Intel 13700K
Motherboard ASRock Z790 PG Riptide
Memory Corsair Vengeance 6400 2x16GB @ CL34
Video Card(s) PNY RTX 4080
Storage SSDs - Nextorage 4TB, Samsung EVO 970 500GB, Plextor M5Pro 128GB, HDDs - WD Black 6TB, 2x 1TB
Display(s) LG C3 OLED 42"
Case Corsair 7000D Airflow
Audio Device(s) Yamaha RX-V371
Power Supply SeaSonic Vertex 1200w Gold
Mouse Razer Basilisk V3
Keyboard Bloody B840-LK
Software Windows 11 Pro 23H2
Some GPU circuit boards have very poor clearance on some HSs or other components on the MB. Here's a post on Tom's where a guy had a problem seating an AMD HD7850 GPU in the top slot on that MB because the GPU PCB hit the SATA ports.
http://www.tomshardware.com/answers...0x-fit-sabertooth-990fx-mobo-sata-height.html
This kind of thing is usually caused by sloppy GPU PCB offsets, not the MB components. I seriously doubt a MB of that grade is at fault. More likely the R9 270x.
9,781 (2.32/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Mouse Logitech G502 spectrum
I had the same exact problem my daughter on one of those bouncy balls with a handle that you sit on it bounce around it turned out that I use the incorrect standoff of the problematic build made of something else or I don't know but the ground right
