Control case fan speed (SYS)
383 (0.09/day)
NJ Hillside
System Name Windows7 64bit Ultimate
Processor Intel Core i7-6700K
Motherboard Asus Z170M-PLUS
Cooling Cooler Master T4
Memory G.skill 32GB DDR4 (2x16GB) 3200MHz
Video Card(s) ASUS GTX970 4GB
Storage PNY 500GB SSD + Seagate 4TB SSHD
Display(s) HP LE1851w
Case Cooler Master N200
Power Supply Cooler Master 750watt
Mouse HP
Keyboard HP
Benchmark Scores no need
Hi
I bought case fan which has 3 PIN port
so the problem is that fan running 2909 RPM all time , it's really make noise even brother thought I have Mustang in my rom :eek: .
I try to control it through BIOS, but there is only CPU fan option ( fast, medium & slow )
Also, I download speedfan but useless, it show temp only.
Is there any software enable me to control speed fan?
I am not looking to get Hardware to control speed fan. :)
Mb asrock g41m-vs3
sneekypeet
Retired Super Moderator
29,411 (4.45/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
3-pin fans are not PWM, or controllable via software. What you want is either a fan controller or inline resisters to lower that fans speed.
just power, ground, and RPM sense; no PWM wire for fan speed control.
383 (0.09/day)
NJ Hillside
Mouse HP
Keyboard HP
Ah :shadedshu I think I will get one of those stuff that control speed fan
thanks bro ;)
2,132 (0.39/day)
Chicago burbs
System Name Halloween Boo!
Processor Intel Core i7 3770K
Motherboard Gigabyte Z77-Up7
Cooling Custom Water/ Thermalchill TA 120.3/ Swiftech Apogeee XT/ MCP655/ Swiftech M icrores/ XSPC RX 240
Memory 16G G.Skill trident 2400MHz
Video Card(s) 3 x Radeon 7970
Storage OCZ Revo Drive 240G
Display(s) 24 inch Viewsonic
Case Phobia WayCoolIt Test Bench
Power Supply Nexus 1100 watt
You could buy a fan controller
Athlon2K15
HyperVtX™
7,909 (1.23/day)
O-H-I-O
Processor Intel Core i9 11900K
Motherboard MSI Z590 Carbon EK X
Memory Team DDR4 4000MHz
Video Card(s) ASUS TUF RTX 3080 OC
Storage WD WN850 1TB
Display(s) 43" LG NanoCell 4K 120Hz
Power Supply Asus Thor 1200w
Mouse Asus Strix Evolve
Keyboard Asus Strix Claymore
2,132 (0.39/day)
Chicago burbs
173 (0.04/day)
Processor 4GHz intel i7 950
Motherboard GA X58-USB3 F5
Cooling Noctua C12P
Memory 48GB G.Skill RipjawsZ
Video Card(s) EVGA GTX 480 873/1746/1848
Storage Intel 520 Series
Display(s) HP 2210m
Case Antec 300
Power Supply Antec True Power New 750
Software Windows 8 Pro
Your motherboard can't control the system fan headers.
You don't want any form of hardware controller (even a $1 inline resistor).
Answer: Buy a new motherboard with better fan header control. Even the cheapest Asus motherboards allow custom system/chassis control based on CPU temperature or manual DC/PWM percentage.
sneekypeet
29,411 (4.45/day)
System Name EVA-01
A new motherboard will not make a 3-pin fan work via PWM plain and simple, but thanks for trying anyways!;)
173 (0.04/day)
Cooling Noctua C12P
Display(s) HP 2210m
Case Antec 300
Of coursed it wont, but PWM headers still allow DC based speed control (given a non half assed motherboard), which is more ideal over using a PWM converter because DC motors not designed for PWM control tend to tick really annoyingly.
You know, the 10 years + before PWM fans were released? DC control was the common. It still is very common because all but the latest and greatest CPU coolers still use 3 pin fans.
I'm still rocking an old Noctua P14 which is 3 pin, plugged into the 4 pin CPU PWM header, set to DC control for full speed vs cpu temp control on my Gigabyte mobo. I have control down to 0RPM, at idle I don't even have the CPU fan spinning because it isn't needed <: Most people who first saw the PWM Core2Duo coolers were amazed that they didnt have to spin. It's nothing special, it just requires sufficient control from the motherboard, and wasn't related to being a whole new PWM fan technology.
In the past Abit had the best control, completely independent control of every fan header (3 pin or not) based on any of the logged temps that the Super IO could detect. These days the best we get is Asus, but still the mass of chassis/system fan headers are still usually clumped together in one group instead of being independent.
de.das.dude
Pro Indian Modder
8,785 (1.73/day)
Stuck in a PC. halp.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
http://www.marnscda.com/Guide/3Pin12vMB.jpg
some chips do allow the control of 3 pin fans via voltage regulation.
i.e. instead of 12V they supply anything from 6V to 12V. This is the case on my current motherboard.
i think ASUS calls this "Q-fan"
EDIT:-
as you can see
i have only 3PWN fans, CPU1 and CPU2, and CHASSIS1
chassis 2 and 3 are 3 pin.
the PWM ones have an added advantage of being able to follow a temperature varied graph. I can use speed fan to control these as well.
173 (0.04/day)
Cooling Noctua C12P
Display(s) HP 2210m
Case Antec 300
I should probably also add that it's possible to get fan controllers which only have 3 pin connectors but they use PWM to control the fan speed, ie the mcubed tbalancer allows as near as makes no difference an infinite amount of fan control, including specifying PWM or DC based speed control for it's headers.
de.das.dude: no minimum temperature target? that will let you set a fan curve manually, might only be an EFI option however, is definitely an option is every recent BIOS Asus board I've owned (since 775).
9,781 (2.32/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
EDIT:-
as you can see
http://img.techpowerup.org/130424/fan control.png
+1 Me too ext 3 Gen 3
