Do "gaming" PCs require i5 procs?
Easy Rhino
Linux Advocate
15,685 (2.33/day)
Mid-Atlantic
System Name Desktop
Processor i5 13600KF
Cooling Noctua NH-U9S
Storage WD_BLACK 4TB SN850x
Display(s) Gigabye M32U
Case Corsair Carbide 400C
Audio Device(s) On Board
Mouse MX Master 3s
Software Fedora KDE Spin
Modern i3 procs are very powerful. Coupled with something like a 770GTX, will today's PC games play just fine?
6,790 (1.34/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
Definitely not. I have an ivy bridge 2.7ghz celeron here and all but certain cpu heavy games were just fine, paired with a 7870 tahiti. Bigger gpu is more beneficial to fps than cpu most games.
6,560 (1.01/day)
System Name Vintage
Processor i7 - 3770K @ Stock
Cooling Scythe Zipang II
Memory 2x4GB Crucial DDR3
Video Card(s) MSI GTX970
Storage M4 124GB SSD// WD Black 640GB// WD Black 1TB//Samsung F3 1.5TB
Display(s) Samsung SM223BW 21.6"
Case Generic
Power Supply Corsair HX 520W
Software Windows 7
No they do not NEED anything above an i3.
Only if you are one of those desperate to have the highest amount of FPS possible even though there isn't a shred bit of evidence that it will make any difference to your game play experience.
Heck I'm sure some people here are still happy with the quad core2 chips.
43,629 (6.36/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
If i3's are still limited to 2 cores, no. With games using more cores, more often an i3 just won't cut it sometimes. It's not just lower FPS overall (that isn't a big deal IMO) but getting things like bad stuttering and slowdown when there's more action on screen.
911 (0.22/day)
System Name BlueKnight
Processor Intel Celeron G1610 @ 2.60GHz
Motherboard Gigabyte GA-H61M-S2PH (rev. 1.0)
Memory 1x 4GB DDR3 @ 1333MHz (Kingston KVR13N9S8/4)
Video Card(s) Onboard
Storage 1x 160GB (Western Digital WD1600AAJS-75M0A0)
Display(s) 1x 20" 1600x900 (PHILIPS 200VW9FBJ/78)
Case μATX Case (Generic)
Power Supply 300W (Generic)
Software Debian GNU/Linux 8.7 (jessie)
Please, define fine. I consider fine 20 FPS and above, 15-20 FPS is playable, <10 FPS is a patience test.
751 (0.15/day)
System Name My PC
Processor i7 4790k @4.4ghz
Motherboard Gigabyte z97m-d3h
Cooling Corsair H105
Memory 4x4GB Corsair Dominator Platinum 2133-9-11-11-31-1T
Video Card(s) GTX970 Stric oc
Storage Samsung 840Pro 512GB
Display(s) Asus ROG SWIFT
Case Lian Li 359
Audio Device(s) Denon DA-300USB / Denon AH-D5000
Power Supply Corsair AX860
Mouse Roccat Kone Pure Optical
Keyboard Corsair K70
Software Win10 64-bit home
Got a friend with then the latest 4th gen i3 (the fastest i3 available). He had a GTX560. With that system he averaged 30FPS in Path of exile, and had a lot of spikes. He very recently bought a used GTX670. Now he averages 40fps and has fewer spikes.
I myself had an i7 930 and an HD7970 few months ago, the game was running 60fps flawlessly. That GTX670 has no reason not to run the game at higher fps, the cpu is holding back the performance.
So yea the i3 just couldn't cope with an F2P game.
TheMailMan78
Big Member
22,598 (3.46/day)
'Merica. The Great SOUTH!
i7 2600k minimum requirement for everything IMHO.
4,966 (0.85/day)
System Name i7-PC / HTPC / iMac
Processor i7 3820 / Phenom II 940
Motherboard GIGABYTE G1.ASSASSIN2 / M3A79-T Deluxe
Cooling Corsair Hydro H100i / Scythe II (HS only)
Memory G.SKILL Trident X Series 8GB (2 x 4GB) DDR3 1600mhz / 4GB DDR2 1066 (@800) Corsair Dominator
Video Card(s) GB Radeon HD 7950s 3GB / GB Radeon HD 7950s 3GB
Storage 2x 80GB Intel X-25, 2x600gb SATA, 1x1tb 5400RPM storage /1x600GB, 3x500GB,1x160,1x120 SATA
Display(s) 1x 27" Yamakasi / Vizio 42" HDTV
Case Lian Li Lancool PC-K58 / Antec 900
Audio Device(s) HT Omega Striker 7.1 / Onboard and HDMI from ATi Card
Power Supply PC Power & Cooling 750W / 610W
Software Ubuntu / Windows 8.1 Pro / OS X / PHPStorm / Gaming
newtekie1
Semi-Retired Folder
28,473 (4.01/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Thanks to Hyperthreading, I'd say an i3 would be capable of playing most games with a single graphics card. I probably wouldn't pair an i3 with a GTX780 or R9 290, but I think an i3 would be fine with a GTX760 or an R9 280.
I kind of wish the i3's were still overclockable, then I would say for sure an i3 would be fine for gaming. I was hopeful when I saw BCLK straps implemented in 1150 that lower end processors would be overclockable again using them, but then Intel limited BCLK straps to only work with K-Series processors, which makes the feature basically totally useless. A 4.5GHz i3-4340 would be awesome.
259 (0.06/day)
Processor Intel i7-4770k
Motherboard ASUS MAXIMUS VI HERO
Cooling Deepcool GAMMAXX S40
Memory Kingston HyperX Beast Black 8gb @ 1600 cl8
Video Card(s) MSI GTX 670 POWER EDITION
Storage Samsung 840 EVO 250GB / WD Caviar Black 500GB
Display(s) BenQ XL2420T
Audio Device(s) Asus Xonar U3
Power Supply FSP 650w
idk, but, the better your pc, the bigger your balls is.
FordGT90Concept
"I go fast!1!11!1!"
26,263 (4.35/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
If you're trying to cheap out on the CPU in a gaming system, I'd recommend an AMD processor before going with an i3. You can get a tri-module, six-thread FX processor for the same or less than all the dual-core, four-thread i3s.
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
My son uses an i-5 650 (dual core with HT @ stock) with 2 GTX 560 Ti's. The only place we see an issue is when we run benchmarking programs.:laugh: The Batman games run just fine.
TheMailMan78
Big Member
22,598 (3.46/day)
What?! The standards are very high ($) these days, $650 CPU is not for everyone...
2600K is needed as a bare minimum if you want 60 FPS on all AAA games combined with a decent GPU. Anything below is trash for gaming.
Frick
Fishfaced Nincompoop
20,055 (2.86/day)
norr
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
Eh, for a given value of "trash", and "gaming". 1280x800 is a lovely resolution. ;)
911 (0.22/day)
TheMailMan78, post #13.
That quote doesn't exist, please remove it. LOL!
8,102 (1.32/day)
Hillsboro, OR
System Name Main/DC
....However, I do wonder if we are at the (tipping) point where more cores will become more important/necessary.
These questions are always interesting because the answer depends on what the respondent considers "good enough", as MailMan just proved.:laugh:
...I kind of wish the i3's were still overclockable, then I would say for sure an i3 would be fine for gaming. I was hopeful when I saw BCLK straps implemented in 1150 that lower end processors would be overclockable again using them, but then Intel limited BCLK straps to only work with K-Series processors, which makes the feature basically totally useless. A 4.5GHz i3-4340 would be awesome.
I don't think Intel liked it when people took their $100 i3-5xx and OC'd them to 5GHz.:shadedshu:
693 (0.15/day)
System Name Old but gold
Processor 3770k @ 4.5Ghz
Motherboard Asus Maximus Gene V
Cooling Hyper 212 Evo
Memory 16Gb 1600 DDR3@2400 Cl11
Video Card(s) GTX 1080 FE
Storage SanDisk Extreme 120Gb SSD (os) , SanDisk 480Gb (Games), WD Caviar Black 4 TB (Games and storage)
Display(s) 32" Samsung HDTV 1080P
Case Some old Dell
Audio Device(s) Onboard HDMI
Power Supply EVGA G2 550w
Software Windows 10 Pro 1903
Its not so much that i3's can't run everything , it's how they run and as erocker stated I found with an i3 that some games just couldn't handle the CPU intensive games without a fair bit of stalling and stuttering.
Great chips for a budget system with a single card but at that point I'd probably look at AMD.
911 (0.22/day)
And not even consoles can keep that frame rate anymore... I hope they fixed this with PS4 and XBOXONE, otherwise what a shame. :shadedshu:
259 (0.06/day)
If i play my favorite games, i can do it only with 120 fps and with 1-2 ms gtg response. I consider this is very much better than a few extra settings on ultra, if i`d had a lower gpu i`d go lower settings to get 120fps anyway, i made my decision about that. But in all cases i can`t lower a texture quality/resolution settings :) its very important of course.
911 (0.22/day)
751 (0.15/day)
System Name My PC
Case Lian Li 359
4770K overclocked to 4.6 minimum now days
Don't forget the new 4K display too, bare minimum! And to hell with the 30Hz!
johnspack
Here For Good!
6,071 (0.95/day)
Nelson B.C. Canada
System Name System2 Blacknet , System1 Blacknet2
Processor System2 Threadripper 1920x, System1 2699 v3
Motherboard System2 Asrock Fatality x399 Professional Gaming, System1 Asus X99-A
Cooling System2 Noctua NH-U14 TR4-SP3 Dual 140mm fans, System1 AIO
Memory System2 64GBS DDR4 3000, System1 32gbs DDR4 2400
Video Card(s) System2 GTX 980Ti System1 GTX 970
Storage System2 4x SSDs + NVme= 2.250TB 2xStorage Drives=8TB System1 3x SSDs=2TB
Display(s) 1x27" 1440 display 1x 24" 1080 display
Case System2 Some Nzxt case with soundproofing...
Audio Device(s) Asus Xonar U7 MKII
Power Supply System2 EVGA 750 Watt, System1 XFX XTR 750 Watt
Mouse Logitech G900 Chaos Spectrum
Keyboard Ducky
Software Archlinux, Manjaro, Win11 Ent 24h2
Benchmark Scores It's linux baby!
I'm running games that make my i7 at 4ghz cry.... I see all 8 threads going.... yes if you want a proper gaming rig you need an i7, not an i5. BF4 uses 6 threads by itself, the os certainly can use the last 2.
MxPhenom 216
ASIC Engineer
13,172 (2.46/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27ACDNG 360Hz QD-OLED | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" 1440 IPS 1440p
Mouse Razer Viper v3 Pro
Psh, no its not. GPU will matter far more then CPU.
5,968 (0.93/day)
New York
Processor AMD Ryzen 9 9950x / AMD Epyc 7773x
Motherboard Gigabyte B850 Gaming X/ ASROCK ROME
Cooling Be Quiet Dark Rock Pro 4(Custom) / Custom Air
Memory 64GB Crucial Pro 6400 / 384GB
Video Card(s) MSI RTX5070Ti(Temporary)/ 4X RTX3090
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Lian Li A3 Mini
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus/ Quest 3
i5 minimum, definitely not for games, heck up until last year I was running a core2quad 4ghz and that ran most games with no problem at all but I upgraded to a 3770k because I needed one to do my work, most of the time it was gpu limited even then.
