Fractal Design Introduces the Kelvin Series AIO Water Cooling Systems
4,784 (1.06/day)
Still on the East Side
Fractal Design is proud to launch Kelvin, a uniquely Expandable All-In-One water cooling series. Available in three different versions T12 (120 mm radiator), S24 (240 mm radiator) and S36 (360 mm radiator).
Simple to install, silent operation, powerful performance and easy expandability define the Kelvin Series. The silent high-performance ceramic pump is strong enough to support considerable expansion, should you decide to include GPU blocks and/or additional radiators in the same loop.
The Kelvin Series water cooling systems are constructed from enthusiast class components. Both the CPU block and the radiator are made from pure copper, for maximum performance and an increased product life span with zero maintenance required.
All modern CPU sockets are supported by the versatile, easy-to-use mounting kit.
Key Features Kelvin T12, S24, S36
  • The strong pump and the full-copper construction places the Kelvin Series water cooling system ahead of the pack in cooling performance.
  • Highly Expandable system. Just open it up to get the full benefits of custom water cooling, with the ability to add any parts you want to the loop.
  • High pressure pump provides impressive water flow rates even when an additional CPU or GPU water block or an additional radiator has been added to the loop.
  • All parts have fully standard G 1/4" thread fittings for compatibility with the vast majority of enthusiast water cooling products.
  • The tubes are fastened with two-part brass compression fittings, providing a secure seal while being easy to open and re-seal with a standard wrench.
  • Easy refilling with dedicated fill port
  • Made with enthusiast-grade components in cooperation with Alphacool
  • Available with a triple fan radiator, a 30 mm thick 360, providing a much larger area than nearly all other pre-filled water cooling units
  • Also available in the two most common formats: thin 240 mm and thick 120 mm
  • Long lifetime.
    To avoid Galvanic corrosion of the water cooling loop, the Kelvin Series water cooling system is constructed with pure copper in both the radiator and the water block, along with brass fittings.
    To avoid the common issue of most pre-filled water cooling units (that tend to lose, over time, performance due to water loss in the tubes), Fractal Design equipped the Kelvin series with a fill dedicated port
MSRP T12
  • USD: $99.99
  • EURO: €74.99
  • GBP: £89.99
  • SEK: 799
MSRP S24
  • USD: $119.99
  • EURO: €85.99
  • GBP: £104.99
  • SEK: 999
MSRP S36
  • USD: $139.99
  • EURO: €99.99
  • GBP: £119.99
  • SEK: 1149
1,594 (0.36/day)
Northamptonshire, UK
System Name Main / HTPC
Processor Ryzen 9 5900X / Ryzen 7 2700
Motherboard Strix B550i / B450i Aorus Pro
Cooling Lian-Li Galahad 360 / Wraith Spire
Memory Corsair LPX 2x16 3600MHz / HyperX Predator 2x8GB 3200MHz
Video Card(s) RTX 3080 FE / ARC A380
Storage WD Black SN770 1TB / Sabrent Rocket 256GB
Display(s) Acer Z301c / 39" Panasonic HDTV
Case Corsair 2000D / Cougar QBX
Audio Device(s) Yamaha RX-V379 / Realtek ALC1220
Power Supply Corsair SF600 / BeQuiet SFX Power 2 450W
Mouse Logitech G900
Keyboard Drop Sense75 with WQ Studio Morandi's
VR HMD Rift S
Software Win 11 Pro 64Bit
Holy sh*t, an affordable triple rad AIO solution!:rockout:
5,409 (0.97/day)
System Name Cyberline
Mouse Elecom EX-G
Keyboard Rapoo V700
Those prices are great, now we just need some benchmarks
4,360 (0.99/day)
St. Paul, MN
System Name Bay2- Lowerbay/ HP 3770/T3500-2+T3500-3+T3500-4/ Opti-Con/Orange/White/Grey
Processor i3 2120's/ i7 3770/ x5670's/ i5 2400/Ryzen 2700/Ryzen 2700/R7 3700x
Motherboard HP UltraSlim's/ HP mid size/ Dell T3500 workstation's/ Dell 390/B450 AorusM/B450 AorusM/B550 AorusM
Cooling All stock coolers/Grey has an H-60
Memory 2GB/ 4GB/ 12 GB 3 chan/ 4GB sammy/T-Force 16GB 3200/XPG 16GB 3000/Ballistic 3600 16GB
Video Card(s) HD2000's/ HD 2000/ 1 MSI GT710,2x MSI R7 240's/ HD4000/ Red Dragon 580/Sapphire 580/Sapphire 580
Storage ?HDD's/ 500 GB-er's/ 500 GB/2.5 Samsung 500GB HDD+WD Black 1TB/ WD Black 500GB M.2/Corsair MP600 M.2
Display(s) 1920x1080/ ViewSonic VX24568 between the rest/1080p TV-Grey
Case HP 8200 UltraSlim's/ HP 8200 mid tower/Dell T3500's/ Dell 390/SilverStone Kublai KL06/NZXT H510 W x2
Audio Device(s) Sonic Master/ onboard's/ Beeper's!
Power Supply 19.5 volt bricks/ Dell PSU/ 525W sumptin/ same/Seasonic 750 80+Gold/EVGA 500 80+/Antec 650 80+Gold
Mouse cheap GigaWire930, CMStorm Havoc + Logitech M510 wireless/iGear usb x2/MX 900 wireless kit 4 Grey
Keyboard Dynex, 2 no name, SYX and a Logitech. All full sized and USB. MX900 kit for Grey
Software Mint 18 Sylvia/ Opti-Con Mint KDE/ T3500's on Kubuntu/HP 3770 is Win 10/Win 10 Pro/Win 10 Pro/Win10
Benchmark Scores World Community Grid is my benchmark!!
Almost sounds, Too good to be true.
They say the pump works, does it? And for how long? Warranty?
672 (0.12/day)
System Name HTPC whhaaaat?
Processor 2600k @ 4500mhz
Cooling Noctua NH-C14
Memory Gskill Ripjaw 2x4gb
Display(s) Vizio P 65'' 4k tv
Case Lian Li pc-c50b
Audio Device(s) Denon 3311
Power Supply Corsair 620HX
I was literally JUST going to make a thread asking if there were any 120mm AIO solutions that supported 2 blocks (similar to the 295x2's cooler), with or without resorting to the corsair/other cpu->gpu bracket. I would prefer a slim rad, but this might work. I wonder if the sg10/any of the other cases I'm looking at can accommodate it...probably not. :p
I reallllly like the idea of cooling two (crossfire/sli) gpus with a simple closed (granted this isn't) 120mm bolt-on setup. Not super extreme, but 295x2 shows it works well-enough, and it eliminates a huge problem for lots of heat getting out of a small area.
