Gigabyte V-Power GH-UDUP21-VC VGA Cooler
6 (0.00/day)
Hi all. :)
I have sapphire hd4850 with really bad cooling (stock cooling)... the idle temperature is about ~60 degrees. On full load it reaches 90~100 degrees.
I saw in a shop near me Gigabyte V-Power GH-UDUP21-VC, but salesman doesn't know anything about it. I have heard that it will fit on hd4850 (as i have found here, it fits on 3850). My question is about performances of this cooler on hd4850, i couldn't find any tests on web. If anyone got this cooler on 4850 it would be very helpful to post some info about temperature and noise :).
Thanks in advance!
5,965 (0.98/day)
New York
Processor AMD Ryzen 9 5950x, Ryzen 9 5980HX
Motherboard MSI X570 Tomahawk
Cooling Be Quiet Dark Rock Pro 4(With Noctua Fans)
Memory 32Gb Crucial 3600 Ballistix
Video Card(s) Gigabyte RTX 3080, Asus 6800M
Storage Adata SX8200 1TB NVME/WD Black 1TB NVME
Display(s) Dell 27 Inch 165Hz
Case Phanteks P500A
Audio Device(s) IFI Zen Dac/JDS Labs Atom+/SMSL Amp+Rivers Audio
Mouse Logitech G502 SE Hero
Keyboard Corsair K70 RGB Mk.2
VR HMD Samsung Odyssey Plus
I had that on a HD3850, a VF900 is better at idle and much much better under load, I don't think it will handle a HD4850 very well since a VF900 will run really hot on a HD4850
what other coolers did they have their
1,644 (0.29/day)
System Name Black Killing Machine
Processor Delidded NO IHS mount Intel i7-4770k
Motherboard Gigabyte Z87X-OC
Cooling Swiftech DIR655 pump, Watercool HEATKILLER® GPU-X³ 79X0 Ni-Bl gpu, DT SNIPER CPU block, UT60 420 RAD
Memory Gskill Trident 2400mhz CL9 Samsung IC9
Video Card(s) SAPPHIRE HD7950 OC 950mhz Edition, VaporX HD7950
Storage 2xM4 Crucial 64GB RAID 0, 1 OCZ AGILILITY 3 60GB, WDCB 500GB x2RAID0, WD Green, Hitachi 1TB
Display(s) Samsung SyncMaster 226BW and 24" 120hz BenQ gamer
Case SilverStone Raven rv-02
Audio Device(s) Audio Technica ATH-AD900 headphones, Topping D2 DAC/Headphone AMP
Power Supply Seasonic Platinum 860
Software Windows 7 Pro 64bit
Benchmark Scores http://hwbot.org/user/sonda5/ Delidding is magic. http://valid.canardpc.com/2878462
