Guide: Cable Management Mobo Tray Mod
CyberDruid
2,887 (0.48/day)
On top of a mountain
System Name Shop Dog
Processor E8400
Motherboard Asus Blitz Formula SE
Cooling d-Tek FuZion
Memory 2 x 2GB DDR2 800 G Skill
Video Card(s) EVGA 7900 GTX
Storage 150GB VelociRaptor
Display(s) Acer 21.5 1080p LED Back Lit Monitor
Case Working on it
Audio Device(s) PCI SoundMax
Power Supply Silverstone 750 Modular
Software XP Pro SP2
Benchmark Scores Super Pi 11.56s 1M at 4050mhz
Hey guys:rockout:
This is a guide that will aid your efforts to manage cabling in cases with a bottom mount PSU.
The idea can be applied to any case that offers enough clearance between the blind side panel and the back of the motherboard tray for your PSU cabling.
Here we have a virgin Antec 900
This is pretty essential for layout but if you plan to paint right away you can skip the tape and use a pencil or whatever instead of a Sharpie
C-Channel is going to come in handly to prevent chafing and clean up any holes you make. It can also surplant the use of Grommets (which are expensive)
To determine the size of the holes you'll make choose the grommets first.
A step bit (on left) is one of the cleanest ways to make and enlarge holes in sheet metal. A Hole saw is good for larger holes but you need to use a backing board clamped into place.
A drill and some bits will make pilot holes.
A Holesaw Kt and serious High torque low speed drill with a large chuck is required for making the optional PSU fan hole mod
But you can also use a jigsaw
If you don't have the drills or jigsaw a die grinder or dremel type tool with cut off wheels will get the job done as well
Scissors and/or a utility or Exacto knife will be handy for cutting any patterns from paper or trimming C Channel to exact length
More to follow
CyberDruid
2,887 (0.48/day)
Processor E8400
Case Working on it
Software XP Pro SP2
First you need to have the PSU in hand because there are a lot of different types and lengths of PSUs some with small fans no fans or large fans
You will be surprised at how small a hole the 24 pin plug will fit through if you "roll it"--here it's being poked through a factory hole intended for LC just to demonstrate.
Strip the case
SInce I have a lot of mods going at once I alwas store the parts in the box..that way later I don't have a WTF moment
This blank slate needs to have some guidelines to layout the holes
If your PSU has nice long cables you can leave the fan up...but most don't
You can see here that this will stretch the cables across the airflow and basically be your typical n00b cabling disaster...
So here's an optional mod to flip the PSU if it has a fan
It's easier to put tape to mark the edges of the PSU wih the cable outlet away from the mobo panel
A handly thing for layout is a piece of stiff paperor cardboard with a 90 degree corner...this will let you trace a slightly oversized guide of where the PSu sits in the case.
Use that "square" to transfer your marks all around and measure to determine the center of the fan o the PSU and transfer that mark to the case floor.
Pilot a hole at that center mark
If you have the right size holesaw
Flip the case and secure it on a pad and have at it...
Or use a compass and draw out the cut and use a cut off wheel...or even a jigsaw
A Drum sander on a drill will rapidly deburr the cut
Using the guideline for the PSU position drill a hole the right size for your largest grommet or about 1-1/4" diameter if using C-Channel
This is where you will poke the majority of the PSU cabling through to hide it behind the mobo tray
Edge your PSU fan hole with C-Channel
Now you are ready to layout for the motherboard cabling holes.
Lay your mobo in place and use the tape to mark around it or if painting soon just mark around it. Make check marks where the 24 pin, SATA cabling and FP cabling will pop through. You want to make your holes so the enters are 1/4" away from the edge of themobo This ill allow the cabling to ease through and still hide most of the hole. Use drills the right size for your grommets.
More to Follow
CyberDruid
2,887 (0.48/day)
Processor E8400
Case Working on it
Software XP Pro SP2
If using holesaws back up your work with a piece of scrap wood and clamp the case.
If Using step bits use some tape around the bit to ensure you do not go one step too large.
The layout here is top grommet for Front Panel stuff coming off the top panel, 24Pin, SATA, Front Panel to Mobo, and finally 24pin etc from the PSU
That's how it starts
PSU can breathe
Sanitary cabling from the start
I hope this helps out modders here at TPU :toast:
KBD
2,477 (0.39/day)
The Rotten Big Apple
Processor Intel e8600 @ 4.9 Ghz
Motherboard DFI Lanparty DK X48-T2RSB Plus
Cooling Water
Memory 2GB (2 x 1GB) of Buffalo Firestix DDR2-1066
Video Card(s) MSI Radeon HD 4870 1GB OC (820/950) & tweaking
Storage 2x 74GB Velociraptors in RAID 0; 320 GB Barracuda 7200.10
Display(s) 22" Mitsubishi Diamond Pro 2070SB
Case Silverstone TJ09-BW
Audio Device(s) Creative X-Fi Titanium Fatal1ty Profesional
Power Supply Ultra X3 800W
Software Windows XP Pro w/ SP3
very, very cool, i wish i knew about this when i got my TJ-09. it has the bottom mounted PSU and makes cable management rather difficult. When i had my PC P&C 750 what i did was simply flipped it over so the PSU cables wound up right next to the mobo tray as opposed to being on the opposite side of the mobo tray and were being stretched from one side of case to another making it look stupid. Fortunately that case does have a grill in the PSU area and when i got my Ultra PSU with 140mm i just put it facing the grill. The big downside, of course, is that in this configuration the PSU fan sucks up all the dust under the case, thats the only problem i see with this mod.
3,471 (0.61/day)
System Name Acer Aspire V3-771G-53218G75Maii
Processor Core i5 3210M (2,5-3,1Ghz)
Memory 8GB DDR3 SODIMM
Video Card(s) Geforce GT650M
Storage Samsung 830 256GB - 750GB Toshiba drive
Software Windows 7 x64 Home Premium (non-acer-bloatware)
...and another task added to my never-ending agenda :D
4,016 (0.70/day)
Ohio
System Name Desktop|| Virtual Host 0
Processor Intel Core i5 2500-K @ 4.3ghz || 2x Xeon L5630 (total 8 cores, 16 threads)
Motherboard ASUS P8Z68-V || Dell PowerEdge R710 (Intel 5520 chipset)
Cooling Corsair Hydro H100 || Stock hotplug fans and passive heatsinks
Memory 4x4gb Corsair Vengeance DDR3 1600 || 12x4gb Hynix DDR3 1066 FB-DIMMs
Video Card(s) MSI GTX 760 Gaming Twin Frozr 4GB OC || Don't know, don't care
Storage Hitachi 7K3000 2TB || 6x300gb 15k rpm SAS internal hotswap, 12x3tb Seagate NAS drives in enclosure
Display(s) ViewSonic VA2349S || remote iDRAC KVM console
Case Antec P280 || Dell PowerEdge R710
Audio Device(s) HRT MusicStreamer II+ and Focusrite Scarlett 18i8 || Don't know, don't care
Power Supply SeaSonic X650 Gold || 2x870w hot-swappable
Mouse Logitech G500 || remote iDRAC KVM console
Keyboard Logitech G510 || remote iDRAC KVM console
Software Win7 Ultimate x64 || VMware vSphere 6.0 with vCenter Server 6.0
Benchmark Scores Over 9000 on the scouter
Excellent guide! My friends and I always cut holes in the mobo tray and hide the wires behind it, but this is a really clean way to do it.
