- Mar 13, 2011
- 51 (0.01/day)
HELP: Flash BIOS 2X HD 6990
YOP TEAM
I have try some things for flash with edited bios my 2 6990 HIS, but no solution for flash edited bios.
More info for my config (new topic in building
) : http://www.overclocking-tv.com/forum/index.php?topic=351.0
I have try:
By atiflash in DOS: all commande not worck ( no adaptater found)
By ATIWinflash with RBE (in system)par ''acquire/flash" but whene I fore flash I have this error message: ''Unknown! InvalidBIOS or adapter ...''
By By ATIWinflash with .BAT file commande (in system):
atiwinflash -unlockrom 0
atiwinflash -s 0 backup0.bin
atiwinflash -unlockrom 1
atiwinflash -s 1 backup1.bin
atiwinflash -unlockrom 2
atiwinflash -s 2 backup2.bin
atiwinflash -unlockrom 3
atiwinflash -s 3 backup3.bin
WORK
But whene I try this with all backup.bin edited good with RBE:
atiwinflash -f -p 0 backup0.bin
atiwinflash -f -p 1 backup1.bin
atiwinflash -f -p 2 backup2.bin
atiwinflash -f -p 3 backup3.bin
flash seems to be ok ( no error...) flash time is normal.
But after reboot, one i taped "atiwinflash -s" for all GPU to in order to see if edited bios flash has performed well.
The problem is : this resave resave stock bios without any modification
So flash procedure didn't work.
All these test has been done with 2 switch bios mode ans Crossfire bridge enabled and disabled.
does it come from the fact flashing software don't manage 6990 cheksum ? Or anything else ?
More info for my 2X 6990
: http://forum.hardware.fr/hfr/Hardware/2D-3D/penser-6990-amd-sujet_885272_1.htm
VERY NEED to flash this card'S
Thanks for your HELP
Sory for my bad english.
YOP TEAM
I have try:
WORK
