- Jul 25, 2006
- 12,153 (1.87/day)
- Nebraska, USA
System Name | Brightworks Systems BWS-6 E-IV |
Processor | Intel Core i5-6600 @ 3.9GHz |
Motherboard | Gigabyte GA-Z170-HD3 Rev 1.0 |
Cooling | Quality case, 2 x Fractal Design 140mm fans, stock CPU HSF |
Memory | 32GB (4 x 8GB) DDR4 3000 Corsair Vengeance |
Video Card(s) | EVGA GEForce GTX 1050Ti 4Gb GDDR5 |
Storage | Samsung 850 Pro 256GB SSD, Samsung 860 Evo 500GB SSD |
Display(s) | Samsung S24E650BW LED x 2 |
Case | Fractal Design Define R4 |
Power Supply | EVGA Supernova 550W G2 Gold |
Mouse | Logitech M190 |
Keyboard | Microsoft Wireless Comfort 5050 |
Software | W10 Pro 64-bit |
"Diesel" generators are typically used to power large facilities (with >10 - 15KW demands) for hours and hours.
Do the math!
1Ton is equivalent to just 12,000BTUs. That is basically a small to medium sized "window" air conditioner that can run off plain ol' 115VAC.
8 computers, a few lights, network gear and a small AC is a tiny requirement.
A simple 3KW gas generator would support your needs just fine. Bump it up to 5.7KW like this one, and you can keep your refrigerator, microwave oven, and big screen TV running too. And you can roll it out when needed, and lock it away when not. Note the 7,125 "starting watts" rating covers the extra demands for when that AC or refrigerator cycles on.
I cannot the imagine the AC demands in Canada will be excessive much of the time. So with its 6 gallon tank at 50% load, it gives you 9 hours of run time. And being gas instead of diesel, your fuel expenses will be cheaper, and typically gasoline is easier to find than diesel, unless you live near a truck stop, or in Europe where many cars are diesel. And gas generators are quieter too.
In the cold months, you can easily run your gas forced-air furnace as they only need electricity for the initial spark and to run the fan - much less than the AC needs.
I would still run your computers (and big screen TV) off several "good" UPS with AVR. This will keep them running during the power cutover from mains to generator. But more importantly, the AVR (automatic voltage regulation) will smooth out any power anomalies too. Just ensure they are quality UPS as they will be able to tolerate the waveform from the generator.
Another alternative would be a permanently installed natural gas generator. These are great if you have frequent, extended outages. But obviously they are more expensive to purchase and must be installed by certified electricians and gas technicians. And if you ever move, it stays.
Do the math!
