Help with basic 4g OC of QX9650 on air
88 (0.01/day)
Processor QX9650, 4@1.36v 11x365
Motherboard Asus p45q-e
Cooling Prolimatech Super Mega Cooler (Akasa Viper push/pull)
Memory OCZ 8GB (4x2GB) PC2-6400C4 800MHz ReaperX HPC Enhanced Bandwidth Edition Dual Channel DDR2
Video Card(s) HIS 6970 ATI HD
Storage 1TB
Display(s) 30" dell 3008, 2x19" samsumg syncmaster
Case Antec P180
Audio Device(s) PCI XFi SB
Power Supply 800wat Tagan
Software Windows 7 x64
Benchmark Scores 14500 3dmark 06 @ 2500x1600 8AA 22000 3dmark 06 @ defaults 4800 3dmark 11 @ defaults
Hi OC'ing experts,
I recently upgraded an old rig to an ATI6970 and QX9650 on an ASUS p45q-e. See linked
Just bought 6970, now is my CPU smoked.
Now I am trying to crank it up a bit, so far I have just played with CPU and am at 10x365 and running fine. 11x357 failed to boot. How can i get this baby unto 4g now :rockout:
brandonwh64
19,542 (3.65/day)
NICE! cant wait to see your 4ghz!
should be easy on that chip! Lower your RAM speeds down to like 533 or 667 and then turn off ALL power saving junk like C1E and speed step, then change the multi up until it doesnt boot then change voltage by .05V
Also this may help as well
4Ghz Club
88 (0.01/day)
Storage 1TB
Case Antec P180
Hmm just ran an hour of OCCT on the 3.65ghz stock voltage and OCCT peaks at 68c. Somewhat hot..,I am aiming for for 64.5 as far as I know.
88 (0.01/day)
Storage 1TB
Case Antec P180
It seems that the programming I was using had a higher Tjunction than the actual 95* for the QX9650. Core temp reports around 5 digs lower than most others for the cores. Core temps hit around 60 degs under stress test loads after one hour. Seems fine for a push to the 4 gig club this week.
FWIW playing fallout 3 is significantly less demanding than the stress testers, Core temp rarely hits 53 digs through a long play session. This makes me more inclined to run the thing slightly hot under peak stress as it would rarely happen in reality and would give me max burst performance when required.
Deleted member 74752
Just piddling...
88 (0.01/day)
Storage 1TB
Case Antec P180
she runs too hot? (this was 10 minutes worth of OCCT)
CPUv=1.33v
brandonwh64
19,542 (3.65/day)
doesnt look too hot, change Bus speed to 364*11 for 4ghz
88 (0.01/day)
Storage 1TB
Case Antec P180
What would be reasonable near max core teems to keep in mind? I was thinking that 70 was hot, although I kinda plucked that out of my a$$.
brandonwh64
19,542 (3.65/day)
your close, i would get better cooling on that sucker and see if you could do higher, maybe water
88 (0.01/day)
Storage 1TB
Case Antec P180
My old 6600 was running 3.2 and would show warnings for heat during stress tests, ran fine for years and still runs fine. I radiator cooler will be my next toy, can only fit a single in my case though.
5,731 (1.12/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
tjmax is 95c
brandonwh64
19,542 (3.65/day)
Also you could think of closed loop setups like a corsair H50 (H70 is over rated)
I have a H50 on my 1156 Xeon setup OCed to 4Ghz @ 1.4v and it doesnt get above 70 deg full load
88 (0.01/day)
Storage 1TB
Case Antec P180
Right, so plenty of slack here to play with. Aim for 90? :D
88 (0.01/day)
Storage 1TB
Case Antec P180
Joking aside, anything in the region of 65-75 is acceptable based on distance to Tjmax.
Another question, is it generally better to have the highest stable FSB and lower multiplier? Would that give the best performance? My understanding is that a higher bus speed must be a good thing for performance. P5Q-e has plenty of heat sinks on it's bus, so I am keam to try to push it.
88 (0.01/day)
Storage 1TB
Case Antec P180
Oh dear, 1.33v and 4g met the blue screen of death whilst OCCT testing. I have not down tuned my memory yet, so i guess that will be something to try. Back to 3.67 at stock volts for now. Fun little session of pushing, more to follow. Thinking of a new cooler, but TBH at the moment, 3.67g and ATI 6970 murders everything, so no rush.
4,686 (0.80/day)
System Name Obelisc
Processor i7 3770k @ 4.8 GHz
Motherboard Asus P8Z77-V
Cooling H110
Video Card(s) GTX 780 Ti
Case T81
Software Win10 64bit
I had 4 ghz on my QX9650 but it began to degrade. I'd try to keep it under 1.35v in cpuz. The newer, non X models are more tolerant.
hat
Enthusiast
21,731 (3.41/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
400x10 ought to be doable... 400FSB isn't really too much to ask for, and then you can run a 1:1 CPU/DRAM ratio and leave your RAM at 800MHz (maybe play with this ratio later when you get the CPU stable). I'm not sure what other settings may need changed to get to 400FSB... I ran into a wall on my E2160 with my evga 750i board past 300, couldn't get it stable, even with maxing out the FSB voltage and the NB voltage.
On 775, more FSB will yield more bandwidth over the FSB bus... should make things feel faster. On 1366/1156, FSB was replaced with a faster bus, so it doesn't matter so much.
88 (0.01/day)
Storage 1TB
Case Antec P180
Having done some research it seems like the megahalems air cooler achieves lower temps than the h50/ h70. What do people generally think about opting for the megahalems air with some kick ass fans as opposed to a similar priced h50 or h70?
Custom loop seems like a fun project for the end of the year, but for now, a cheaper interim cooler setup that my wife can keep when I upgrade.
88 (0.01/day)
Storage 1TB
Case Antec P180
Okay, no responses. I am pretty much sold on the megahalems cooler as that cost is small and the fans reuable in future. The question now is which fans and how many?
My case Antec P180 has top and rear exhaust by the CPU, so i have a number of options for push pull and exhuast.
What do people think?
Scythe Gentle Typhoon 1150RPM 120mm
Noctua NF-P12 Case fan 120mm or
Scythe Kaze Jyuni 1900RPM Slip Stream Fan
and how many?
cyriene
183 (0.03/day)
Miami
System Name PrettyH8Machine/GameOn
Processor i7 920 D0 4.2GHz/i7 920 D0 4.0GHz
Motherboard X58A-UD7(v1.0)/X58A-UD3R
Cooling RRT Chrome EK Supreme HF/EK Supreme HF
Memory G.Skill Pii 3x2GB 1600 cas7/G.Skill Pii 3x2GB 1600 cas7
Video Card(s) Gigabyte HD4550/XFX 6950 2GB Crossfire
Storage Corsair F120SSD/Samsung F3 1TBx2 RAID1
Display(s) Dell U3011 & Dell 2407WFP
Case Coolermaster HAF 932/Mountain Mods Duality
Audio Device(s) Onboard/Corsair HS-1 Headphones
Power Supply Corsair HX620W/Corsair TX850W
Benchmark Scores I should run some of these sometime...
Seems my Noctua NH-U12P cooled my i7 920 better than the megahelans did while being quieter. I haven't tried the GT on an air cooler, but they are great for rads.
6,862 (1.16/day)
S.E. Virginia
System Name Barb's Domain
Processor i9 10850k 5.1GHz all cores
Motherboard MSI MPG Z490 GAMING EDGE WIFI
Cooling Deep Cool Assassin III
Memory 2*16gig Corsair LPX DDR4 3200
Video Card(s) RTX 4080 FE
Storage 500gb Samsung 980 Pro M2 SSD, 500GB WD Blue SATA SSD, 2TB Seagate Hybrid SSHD
Display(s) Dell - S3222DGM 32" 2k Curved/ASUS VP28UQG 28" 4K (ran at 2k), Sanyo 75" 4k TV
Case SilverStone Fortress FT04
Audio Device(s) Bose Companion II speakers, Corsair - HS70 PRO headphones
Power Supply Corsair RM850x (2021)
Keyboard Logitech Orion Spectrum G910
VR HMD Oculus Quest 2
Benchmark Scores https://www.3dmark.com/spy/34962882
I'd go for the megahalam, less possibility of failure when compared to a h50.
As for temps, under full load of all 4 cores, try to keep temps at or below 70'c. In real world use, you won't be running all four core at full load all the time. So if when at full load, as long as your cpus stays below 70'c, your cooling is adequate.
Cant really say which fans to use as I don't know whichs ones are the best, but I can say you need a fan on your case for pulling air into the case. If you only have fans blowing out of the case, you'll end up with negative pressure in your case, which will hamper your cooling.
6,862 (1.16/day)
S.E. Virginia
BTW, my q9650 running at 3.6ghz does just fine with my 5870 and 1920*1200 resolution 24" widescreen, you really need 4ghz?
88 (0.01/day)
Storage 1TB
Case Antec P180
The Noctua will not fit onto P45q MB so far as i can tell without removing a ram stick.
Okay, I have 2xfan bays for inwards blowing. I can fix something up there easy enough. TY
Heh, not really, but it would be nice :)
88 (0.01/day)
Storage 1TB
Case Antec P180
One thing i was wondering though:
Is it better to have excess push pressure over the CPU, i.e. 1600rpm and lower 1200rpm pull.
6,862 (1.16/day)
S.E. Virginia
I believe people get the best results with even push/pull pressure, I could be wrong though. Someone else wanna chime in on this?
