help with picking water cooling pump
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
System Name el'lappy|Cruncher | Cruncher 2
Processor intel C2D T6400 | i7 3770k @4.2ghz | AII X2 220 @3.4ghz
Motherboard some Acer | Asus P8Z77-V Pro |Gigabyter GA-M61p-S3
Cooling dual 80mm cooling fan | WC'ing ) |cheapo
Memory 2x2gb ddr3 | 2x2gb Ripjaws 1600 |4x512mb D9s
Video Card(s) onboard | 60 1GB(hd7770 ) |8800GTS
Storage Momuntus xt 320gb |Kingston Hyper X 120gb SATA III|500gb WD
Display(s) 17in | 42" 1080P HD 3D TV
Case lappy case | CM HAF XB |none yet
Audio Device(s) onboard | onboard | onboard
Power Supply Dell brick w/ acer end end | Antec EW 650w |Antec SP 350w(upg.soon)
Software Windows 7 Ult. 64bit---->------->
I need help with picking out how high of flow rate of a pump i will need for best temps components are going to be...
Danger Den Maze 4 (CPU)
Some big ass high performance transmission cooler.
1/2 ID tube.
Swiftech Micro res
43,587 (6.71/day)
Motherboard ASUS TUF x670e
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD m.2
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Tester84
Are you running a single loop?
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
p_o_s_pc
F@H&WCG addict
13,006 (2.10/day)
Newark ohio
forgot that i will be running a Swiftech Micro res
EastCoasthandle
6,885 (0.99/day)
System Name MY PC
Processor E8400 @ 3.80Ghz > Q9650 3.60Ghz
Motherboard Maximus Formula
Cooling D5, 7/16" ID Tubing, Maze4 with Fuzion CPU WB
Memory XMS 8500C5D @ 1066MHz
Video Card(s) HD 2900 XT 858/900 to 4870 to 5870 (Keep Vreg area clean)
Storage 2
Display(s) 24"
Case P180
Audio Device(s) X-fi Plantinum
Power Supply Silencer 750
Software XP Pro SP3 to Windows 7
Benchmark Scores This varies from one driver to another.
If you have the room get a D5. Check out the water cooling thread in my sig
Fitseries3
Eleet Hardware Junkie
15,508 (2.56/day)
Republic of Texas
hows about checking my water cooling guide in my sig? it has links to VERY in depth reviews on all the popular water cooling parts.
