How do I figure out my power supply needs?
Necrodamus
14 (0.00/day)
How do I figure out what power supply I need?
For example, if I have the following setup, is a 500W power supply enough?
Geforce 8800 GS 384MB
Single Core AMD 3200
3GB Memory DDR2
What about if I overclock my video card or upgrade the processor to a dual or quad. What do I look at to make sure my power supply is enough?
cdawall
where the hell are my stars
27,680 (4.27/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
you should be fine on a 500w for up to an oc'd dual and a stock quad (even with the graphics oc'd) but if you want to oc a quad 650+
panchoman
Sold my stars!
9,595 (1.57/day)
Processor Amd Athlon X2 4600+ Windsor(90nm) EE(65W) @2.9-3.0 @1.45
Motherboard Biostar Tforce [Nvidia] 550
Cooling Thermaltake Blue Orb-- bunch of other fans here and there....
Memory 2 gigs (2x1gb) of patriot ddr2 800 @ 4-4-4-12-2t
Video Card(s) Sapphire X1950pro Pci-E x16 @stock@stock on stock
Storage Seagate 7200.11 250gb Drive, WD raptors (30/40) in Raid 0
Display(s) ANCIENT 15" sony lcd, bought it when it was like 500 bucks
Case Apevia X-plorer blue/black
Audio Device(s) Onboard- Why get an sound card when you can hum??
Power Supply Antec NeoHe 550-manufactured by seasonic -replacement to the discontinued smart power series
Software Windows XP pro SP2 -- vista is still crap
3,175 (0.55/day)
Brockport, NY
System Name Is rly gud
Processor Intel Core i5 11600kf
Motherboard Asus Prime Z590-V ATX
Memory (48GB total) 16GB (2x8GB) Crucial Ballistix Sport 3000MHZ and G. Skill Ripjaws 32GB 3200MHZ (2x16GB)
Video Card(s) GIGABYTE RTX 3060 12GB
Storage 1TB MSI Spatium M370 NVMe M.2 SSD
Display(s) 32" Viewsonic 4k, 34" Samsung 3440x1440, XP Pen Creative Pro 13.3
Power Supply EVGA 600 80+ Gold
VR HMD Meta Quest Pro, Tundra Trackers
Should be, but it depends on the amperage. How many amps are on the 12v rail(s)? :)
MKmods
Case Mod Guru
5,697 (0.96/day)
Nevada
System Name Crossflow III
Processor AMD 965 (4.04Ghz)
Motherboard Asus Crosshair III
Cooling Air
Memory 4 gigs Mushkin 7-7-7-20@1T
Video Card(s) single 9800GT
Storage Raptor 150's in Raid0
Display(s) LG Flatron 24"
Case Custom
Audio Device(s) AuzenTech X-Raider W/OP637
Power Supply Custom modded Corsair 750HX
Software Win 7 64/Solaris Utility
Benchmark Scores 3DMark06--21963 so far
3GB Memory DDR2
It really matters which PS you use.
A good 300 watt one will power that comp
A bad 600watt one will fail.
