More Radeon R9 390X Specs Leak: Close to 70% Faster than R9 290X
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
There is a difference, you can replace a cooler but you cannot replace the built in memory structure.
And the advertised specs on the AMD actually skewed benchmarks which lead to worse than expected performance by the consumer. I'm amazed that people are totally ok with AMD listing and advertising clock speeds that they know their cards can't maintain in stock form. However, nVidia lists some incorrect specs on private spec sheets, specs that they don't advertise openly, and everyone freaks out.
If it's available, shouldn't they use it? Yeah, it conveniently makes benchmarks look better and yes, AMD's marketing department will squeeze every last drop of PR they can out of it, but it also gives us as consumers the ability to get more out of our cards via aftermarket cooling instead of having them locked down from the get-go.
The alternative here is to make the card run slow all the time even if the conditions are perfect for 24/7 boost clock speeds.
Then do what nVidia does and pick an at least obtainable base clock that can be maintained constantly. Then let the card boost if temperature allows. Give at least a guaranteed base clock that the card won't go lower than. But then again, advertising the core clock at 600MHz would be an embarrassment...
1,586 (0.34/day)
Kaunas, Lithuania
System Name my box
Processor AMD Ryzen 9 5950X
Motherboard ASRock Taichi x470 Ultimate
Cooling NZXT Kraken x72
Memory 2×16GiB @ 3200MHz, some Corsair RGB led meme crap
Video Card(s) AMD [ASUS ROG STRIX] Radeon RX Vega64 [OC Edition]
Storage Samsung 970 Pro && 2× Seagate IronWolf Pro 4TB in Raid 1
Display(s) Asus VG278H + Asus VH226H
Case Fractal Design Define R6 Black TG
Audio Device(s) Using optical S/PDIF output lol
Power Supply Corsair AX1200i
Mouse Razer Naga Epic
Keyboard Keychron Q1
Software Funtoo Linux
Benchmark Scores 217634.24 BogoMIPS
600MHz? Does it really fall down THAT much?
I mean not counting those [sadly, rather often] cases when clueless average joe users have coolers covered with 2 years worth of dust. (But to be fair that sometimes even pushes otherwise normally cool cards to critically downclock to minimal clocks in effort not to melt. And that is a fault of user negligence, not fault of "bad design")
newtekie1
Semi-Retired Folder
28,472 (4.23/day)
Indiana, USA
Yep, brand new cards in my Corsair 650D, on the quiet BIOS the cards actually went below 600MHz, on the extreme BIOS I saw as low as 600MHz after a while gaming(roughly half an hour).
1,330 (0.31/day)
Processor i7-13700k
Motherboard Asus Tuf Gaming z790-plus
Cooling Coolermaster Hyper 212 RGB
Memory Corsair Vengeance RGB 32GB DDR5 7000mhz
Video Card(s) Asus Dual Geforce RTX 4070 Super ( 2800mhz @ 1.0volt, ~60mhz overlock -.1volts. 180-190watt draw)
Storage 1x Samsung 980 Pro PCIe4 NVme, 2x Samsung 1tb 850evo SSD, 3x WD drives, 2 seagate
Display(s) Acer Predator XB273u 27inch IPS G-Sync 165hz
Power Supply Corsair RMx Series RM850x (OCZ Z series PSU retired after 13 years of service)
Mouse Logitech G502 hero
Keyboard Logitech G710+
Think about it, it would drop to 800mhz stock fan curve, in an Open air bench. Now stick that in a case with bad air flow so it gets pretty hot. 600mhz is very possible.
Well nvidia cards can do 90+c as well but they prefer to keep it lower. It does cost performance but life of the card is enhanced. I offset temp target of mine to 85c even though never gets there. Was running around 65-70c on AC with it clocked about 1500mhz.
2,785 (0.60/day)
New Zealand
System Name MoneySink
Processor 2600K @ 4.8
Motherboard P8Z77-V
Case NZXT Switch 810
Power Supply Seasonic X-1050
Software Win8.1 Pro
What's weird is that one of those slides was leaked a couple of days ago, and ppl called it out as a fake because of a couple of typos. Notice how "functionallity" was misspelled
The typo actually makes it more likely that the slide is genuine IMO
and Direct X 12_Tier has a weird underscore.
That isn't a typo. Decimal point for DX revision, underscore for feature level.
Now in this new leak, the typos have been corrected; oh well, it might that the slide was fixed between the time it was leaked and this new presentation... Kinda suspicious though :wtf:
Conscientious AMD PR flack leaker. Real time leak revision - now that is good hustle!
I think W1zzards own review here indicated a drop to that. The drop was transient, but the trend is/was apparent.
1,349 (0.23/day)
Milwaukee, Wisconsin, USA
Processor i7-3770K
Motherboard Biostar Hi-Fi Z77
Cooling Swiftech H20 (w/Custom External Rad Enclosure)
Memory 16GB DDR3-2400Mhz
Video Card(s) Alienware GTX 1070
Storage 1TB Samsung 850 EVO
Display(s) 32" LG 1440p
Case Cooler Master 690 (w/Mods)
Audio Device(s) Creative X-Fi Titanium
Power Supply Corsair 750-TX
Mouse Logitech G5
Keyboard G. Skill Mechanical
Software Windows 10 (X64)
I don't think +70% faster than a 290x at $700 will be very impressive, if that's what it will be.
3,275 (0.45/day)
Sunny California
Processor Intel Core i9 13900KF
Motherboard Asus ROG Maximus Z690 Hero EVA Edition
Memory 4x16GBs DDR5 6800MHz G.Skill Trident Z5 Neo Series
Storage 2TB Samsung 980 Pro OS - 4TB Nextorage G Series Games - 8TBs WD Black Storage
Power Supply EVGA Supernova G2 1300W
VR HMD Samsung Odyssey VR
Software Windows 11 Pro 64bit
Well I can't say I agree, yes, the price might be a tad high, but 290X was $549 on release and went all the way up to $799 a few weeks after due to the bitcoin bubble. That was over a year ago.
Now this new card, if it includes an AIO water cooler, that sorta justifies the $100 premium, over the $549 original launch price for the 290X with its lackluster cooler; as far as that 60~70% faster at 4K figure, we haven't had such a high performance jump in many generations, for me that is very impressive, considering we've only seen a 10~15% performance jump for quite a few generations now.
So 40~50% performance jump from GTX980 to Titan-X, but at a $999 price. Anything over 60% performance jump from AMD's previous flagship, probably putting this card in the same league as a much more expensive card from the green team, sounds like quite an impressive achievement to me.
No matter what, we are in for a dozy as PC gamers. 4K maxed out rendering from a single GPU will finally become a real possibility, and the release of the VR headsets towards the end of the year will require the all the GPU power available in these new cards.
2,067 (0.40/day)
System Name The Stone that the Builders Refused / iJayo
Processor R5 1600/ R7 3700X
Motherboard Asrock AB350 Pro4 / Asus Rog Strix B450-F gaming
Cooling Cryorig M9 / Noctua NH-D14
Memory G skill 16 Gigs ddr4 / 16 gigs PNY ddr4
Video Card(s) Nvdia GTX 660 / Nvidia RTX 2070 Super
Storage 120gig 840 evo, 120gig adata sp900 / 1tb Mushkin M.2 ssd 1 & 3 tb seagate hdd, 120 gig Hyper X ssd
Case Pink Enermax Ostrog / Phanteks Enthoo Evolv Tempered Glass edition
Audio Device(s) Altec Lansing Expressionist Bass/ M-Audio monitors
Power Supply Corsair450 / Be Quiet Dark Power Pro 650
Mouse corsair vengence M65 / Zalman Knossos
Keyboard corsair k95 / Roccat Vulcan 121
Software Window 10 pro / Windows 10 pro
if Amd gotta charge $700 to make a profit and survive and the card delivers $700 worth of performance...... I say well done! If this is fluff.......i feel sorry for them. There is not gonna be another mining boom and major cpu releases are a year(hopefully) away....they need a home run ....right now.
1,330 (0.31/day)
Processor i7-13700k
700$ for what probably be 4gb card. If you are a 4k a adopter that probably won't be enough ram wise. Can only guess what 8gb version will cost but i would put guess probably 900$ for that extra ram. That 60-70% figure AMD claims probably was using that 8gb card not the 4gb card. If that turns out to be the case well can't give nvidia any more crap over Titan pricing anymore.
200$ premium is within realm of possible as its 120$ atm for 8gb 290x over 4gb one. Just due to fact of new type of memory gonna be bit a more $.
edit: as i think about it, wouldn't shock if those graph's were 290x 4gb vs 390x 8gb card. They don't say it on graph so in all likely hood that is what it was
150 (0.03/day)
System Name Poke
Processor i7-7700K OC 4.8 Ghz
Motherboard Asus Z270 ROG Maximus IX Hero
Cooling Cooler Master MasterLiquid Pro 280
Memory G.skill TridentZ DDR4 16GB 2X8GB kit 3600 Mhz XMP
Video Card(s) Nvidia GeForce GTX 1080TI FE
Storage Samsung 850 Evo 1 TB SSD / Western Digital Scorpio Blue 500 GB HDD
Display(s) Asus VG248QE 144 Hz
Case NZXT H440 Black
Power Supply Corsair RM750i
Mouse Logitech G403 Prodigy
Keyboard Logitech G910 Orion Spark
Software Win 10 Home x64
I'll be quite disappointed if the pricing is true. I mean, if the PC market is stagnant (which it is), throwing a 200 dollar markup on their top tier cards is probably not the way to go.
Also, with the factory cooling it seems like there will be a variant with the liquid cooling, not all of them.
As for the current status of AMD's marketshare expect that price, they need to recover some money.
6,446 (1.44/day)
Florida
System Name natr0n-PC
Processor Ryzen 5950x/5600x
Motherboard B450 AORUS M
Cooling EK AIO 360 - 6 fan action
Memory Patriot - Viper Steel DDR4 (B-Die)(4x8GB)
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) PIXIO IPS 240Hz 1080P
Case Thermaltake Level 20 VT
Power Supply Super Flower Leadex III ARGB 80+ Gold 650W
Software XP/7/8.1/10
very excite.
4,184 (1.14/day)
Texas
Mouse Logitech G5
Keyboard Logitech G19S
Simple solution, turn the fan speed up another notch or cool it another way. Though again after the update from amd mine never throttled in a single gpu config on uber mode. I don't think most people care about the specs being wrong in the 970 except the memory itself.
Well my three didn't throttle at least on uber, they went to around 800 on quiet. But that was my test bed in an lanboy air case.
Everyone is shooting for 4k as the goal right now. At this point either of these GPUs will do the lower without breaking a sweat so the real question come to who can do the higher part better.
It's exciting to see such a massive jump!
23 (0.01/day)
But...I don't want my mom to think I'm still up just done shower using her hair dryer in the midnight or I'm boiling water making a coffee while snapping some food when I'm not supposed to, and then she comes check me realized I'm right in hot gaming and all the sudden you know what's gonna happen...
3,881 (0.88/day)
586 (0.16/day)
Processor AMD FX-8320
Motherboard AsRock 970 PRO3 R2.0
Cooling Thermalright Ultra120 eXtreme + 2 LED Green fans
Memory 2 x 4096 MB DDR3-1333 A-Data
Video Card(s) SAPPHIRE 4096M R9 FURY X 4G D5
Storage ST1000VX000 • SV35.6 Series™ 1000 GB 7200 rpm
Display(s) Acer S277HK wmidpp 27" 4K (3840 x 2160) IPS
Case Cooler Master HAF 912 Plus Black + Red Lights
Power Supply OCZ ProXStream 1000W
Mouse Genius NetScroll 100X
Keyboard Logitech Wave
That's gonna be one monster of a card!
AMD were first and perhaps the only ones with GDDR4, later with GDDR5, now with HBM. Not to mention all process jumps done before nvidia.
Indeed, it will be almighty card, and will not have the stupid titanIC name. :D
Maxwell doesn't support DX 12 Tier 3, it is restricted to lower Tiers.
AMD again on the win here. ;)
the54thvoid
Intoxicated Moderator
12,474 (2.37/day)
Memory 32GB Kingston Fury
Case Asus Prime AP201
Audio Device(s) On Board
Software W10
It looks indeed to be s great card, perhaps my next. However, if you think Titan is a silly name, perhaps you should be reminded of the AUSUM (awesome) switch on the 6990, which unlocked Uber mode....
AMD do silly as well.
12,062 (2.74/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
Would be a pleasant surprise if AMD come out on top this time. AMD hasn't been able to control pricing structure since the release of the 7970! Even then it was tame.
Doesn't mean much if they can't turn a profit for at least one quarter this year.
944 (0.21/day)
Slovenia
System Name PC.
Software Windows7 64....
Is 1.25 Gbs Taipo? 5 Gbs on R9-290X ! 4Q R9-395X :)
424 (0.08/day)
Wonder if the AIO cooling solution will get in the way of multiple card configs, I'm sure I wont be able to fit two separate 120mm or 140mm coolers on my current HAF-XB Radeon build...
What's weird is that one of those slides was leaked a couple of days ago, and ppl called it out as a fake because of a couple of typos:
Notice how "functionallity" was misspelled, and Direct X 12_Tier has a weird underscore.
Source: http://www.guru3d.com/news-story/amd-radeon-390x-wce-water-cooled-edition.html
Might have been purposeful so AMD can track leakers???
A bit off topic, don't you think? Accident?
I don't think the AIO is the culprit. It's probably more to do with HBM and yields. Although I don't really know what yields are like on a design like this. I'm just guessing maybe not good because of the new tech.
2,785 (0.60/day)
New Zealand
Motherboard P8Z77-V
Software Win8.1 Pro
You mean that the leaks co-incidentally just happen to go public within two days of AMD's main rivals flagship card launch, and AMD aren't a party to it - moreover, they lay traps to actively discourage anyone from crashing Nvidia's party...
I'm inclined to agree. Complexity and the publicized costs of the interposer package make HBM and its packaging the likely cause
BTW: Triple posting??? Are you new to internet forums?
7,131 (1.45/day)
Rīga, Latvia
System Name HELLSTAR
Processor AMD RYZEN 9 5950X
Motherboard ASUS Strix X570-E
Video Card(s) Sapphire Pulse RX 7900XTX + under waterblock through Kryosheet
Storage Optane 900P[W11] + WD BLACK SN850X 4TB + 750 EVO 500GB + 1TB 980PRO[FEDORA]
Case Lian Li O11 Dynamic EVO
Mouse Razer Basilisk
Software FEDORA 40
Well nothing beats Creative in the silly department...
Well no matter what... I guess I will need to put an AMD sticker on my piggy bank... the question is... how many pigs...
2,785 (0.60/day)
New Zealand
Motherboard P8Z77-V
Software Win8.1 Pro
16,119 (4.62/day)
Wow, you guys are whinging about the alleged $700 price point, but that is $1,000 (roughly) when converted to our currency, and I can't see the base 390X selling for less than $1,200 here, the Liquid cooled version will most likely be around $1,500 once converted to Aussie dollars.
The cheapest new 290X is still $500 here.
If I lived in Australia on a "sunshine coast", I would rarely, if ever, play games. :love: You are still the winner in this, ;p
39 (0.01/day)
my $200 newegg gift card is ready. and sell my 290x hopefully for 150 or 200, so 300 outta pocket... not bad if the price of $700 is rumored true.
I did the same thing 2 weeks ago. I dumped my R9 290 windforce. I bought it 2nd hand for 270AU and I sold it for $275AU on ebay. I thought I did well haha. I have a crappy 6450 2gb as a stand in, waiting on seeing some real reviews of the 300 series, if its not as good as they say, and if the 380 (R9 290 respin) doesnt save a lot of power. ill be buying the 980 when Nvidia drop the price to compete
1,180 (0.20/day)
Australia
Processor Intel i7 4790K
Motherboard Asus Z97 Deluxe
Video Card(s) Asus R290X
Display(s) Samsung S23A950D
Case Corsair 850D
Power Supply Corsair AX850
I under stand things are never perfect in most people's systems, but in case of 290x even with Open air benches which does help keep video card cooler. A lot of reviews under stock fan profiles would seen a 15-20% drop in clocks to 800-850mhz after 5-10min. AMD could manned up and spent some $ on the cooler that could least keep the card near the 1000mhz they said. If on open air bench couldn't keep barely over 800mhz in testing that is terrible. Yea i know can after market cooler for them but shouldn't need to rely on that for card to run at speeds they claim.
Those reference cooler cards disappeared after a few weeks anyway, non-reference cards came out early and anyone who has a 290X got the partner cards like ASUS DirectCUII, Sapphire Tri-X, Gigabyte Windforce etc which came with beefy overclocks , and its not an issue. So not only did it not throttle, it had big overclocks and still didn't throttle. So that whole issue is irrelevant.
You cant even buy a reference 290X now, and I havent seen them on sale for ages at my local stores.
Anyhow the 390X looks good, it will be interesting to see if the water cooler improves performance over a good non reference cooler like the DirectCUII, Tri-X, or Twinfrosr. I'm going to bet that its not......unless AMD decide to bin chips for the WC model and I cant see them doing that.
