Need Help - 4 pin to 2 pin Fan
344 (0.06/day)
Georgetown, Ontario, Canada
System Name Dirty Bitch
Processor Intel Core i5 2500K Quad Core LGA1155 @ 4.6GHZ Sandy Bridge 6MB
Motherboard ASRock Fatal1ty Z77 Professional-M "Micro-ATX"
Cooling Raystorm & Evga Full Blocks, Single & Dual 120mm Radiator With Push/Pull Config, All Noctua fans
Memory 12GB G.SKILL Ripjaws DDR3 @1600 CL9-9-9-24
Video Card(s) 2X SLI EVGA GTX 480
Storage PNY XLR8 PRO SSD 256GB - 1TB WD Black @7200RPM
Display(s) LG 40" LED 1080p & ASUS VE278Q LCD Black 27"
Case Lian Li PC-V354B Aluminum Mini Computer Case mATX
Audio Device(s) Integrated out to Marantz Receiver 4.0 Klipsch Speaker Setup
Power Supply OCZ ModXStream Pro 700W ATX
Software Windows 7 Ultimate, G15 Keyboard, Cyborg R.A.T 7 Mouse, IceMat Mouse Pad
Hi everyone,
Had the fan seize up on my XFX HD 6870 after only 3 months of use :(
Hope someone can help me out and tell me what wires I need to attach to turn a 4 pin fan connector into a 2 pin fan connector.
I really don't care if it runs at 100% all the time just want to get it going.
Where im at.
I think the blue wire on the 4 pin is negative, the green is positive, yellow is tacho and black is PWM (I think). Should I attach the positive and negative to the 2 pin or should i attach the positive and something else?
Thanks,
Appreciate any help :toast:
4,355 (0.93/day)
Mexico
System Name Dell-y Driver
Processor Core i5-10400
Motherboard Asrock H410M-HVS
Cooling Intel 95w stock cooler
Memory 2x8 A-DATA 2999Mhz DDR4
Video Card(s) UHD 630
Storage 1TB WD Green M.2 - 4TB Seagate Barracuda
Display(s) Asus PA248 1920x1200 IPS
Case Dell Vostro 270S case
Power Supply Dell 220w
Software Windows 10 64bit
Is the original a 2 pin fan?
344 (0.06/day)
Yes and it has fan speed control so im confused how its achieving this with 2 wires?
4,355 (0.93/day)
Mexico
It uses voltage control. The yellow wire (12V) on the 4 pin fan must go to the red lead (12V)on the 2 pin connector. The black wire on both connectors is ground.
You might need to cut the wires from the old fan and solder them to the correspondent wires on the new fan. I suspect the pin shape isn't the same between the two connectors.
344 (0.06/day)
Giving it a go now. Thanks for the help!
4,355 (0.93/day)
Mexico
Make sure the replacement fan has the same amperage as the old one, or a little lower. If much higher the card's VRM might not be able to drive the fan if it was designed to only deal that much current to it.
344 (0.06/day)
Both 12V with .5A so should be good. Hope they get along together haha
344 (0.06/day)
So she is up and running. Stress test @100% GPU&CPU for 10min and wont go past 66C (been at that temp for 5 min)
Better temps than I was getting with stock fan when it was new!
If anyone is interested I used the fan out of a XFX 8800 GTS shroud I had kicking around. Fits just right and 2 out of the 3 fan mounts line up.
Thanks again TRWOV
1,709 (0.41/day)
Somewhere Over There!
System Name Gen2
Processor Ryzen R9 5950X
Motherboard Asus ROG Crosshair Viii Hero Wifi
Cooling Lian Li 360 Galahad
Memory G.Skill Trident Z RGB 64gb @ 3600 Mhz CL14-13-13-24 1T @ 1.45V
Video Card(s) Sapphire RX 6900 XT Nitro+
Storage Seagate 520 1TB + Samsung 970 Evo Plus 1TB + lots of HDD's
Display(s) Samsung Odyssey G7
Case Lian Li PC-O11D XL White
Power Supply Super Flower Leadex SE Platinum 1000W
Mouse Xenics Titan GX Air Wireless
Keyboard Kemove Snowfox 61
Software Main: Gentoo+Arch + Windows 11
Benchmark Scores Have tried but can't beat the leaders :)
Mussels
Freshwater Moderator
58,413 (8.15/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
put some asus and gigabyte stickers on there too, call it frankencard.
344 (0.06/day)
I actually like it a lot more now haha. When I pull it to replace it with a newer card on water ill give it some more stickers and keep it around for a tester or another build ;)
8,069 (1.39/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
XFX and Nvidia back together again!
3,628 (0.62/day)
System Name Ultra 64
Processor NEC VR4300 (MIPS R4300i)
Motherboard proprietary design
Cooling Fanless aircooled
Memory 4.5MB 250 MHz RDRAM
Video Card(s) 62.5 MHz Reality Coprocessor
Storage 32 - 512 Mbit ROM Cartridge
Display(s) 720x576
Case Clear Blue Funtastic
Audio Device(s) 16-bit CD quality
Power Supply proprietary design
Mouse N64 mouse for use with N64DD
Keyboard N64 keyboard for use with N64DD
n-force
1 (0.00/day)
I looked for this issue up and i found this topic right away, tried the solution and it worked all ok. Why do i bump after all these years? Well there is not enough info here. Voltage control is not always yellow cable and no info given about speed control and sensors .
I soldered voltage control(in my case it was red) to red line and all others to black line, now it works completely ok with speed control now at last available. However i have no idea what would happen if i did red on red and black on black, unfortunately i have no information about sensors.
Thanks to op and trwov for help.
FreedomEclipse
~Technological Technocrat~
23,409 (3.75/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
New member... Check
First post.... Check
4 year old necro-thread.... Check
glassjaw
3 (0.00/day)
Hey! I need to resurrect this post :)
I'm trying to fit 2pin fan into 4pin. I didn't quite understand if mello_newf did any soldering or not? If not, how to connect the smaller connector into gpu? Thanks :)
9,781 (2.31/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Mouse Logitech G502 spectrum
often. it generally goes something like this
pin 1 is - and pin 2 is +. Black goes to pin 1 and red goes to pin 2. Pin 1 should be black
9,781 (2.31/day)
Massachusetts
Processor i7-11700K
So no need to cut the wires?
well thats determined by what it is your trying to do. but generally in the times ive needed to do this, ive had to cut the wires that werent needed. they also make an adapter for this purpose
im unclear what your trying to do, but it seems liek your trying to plug a 2pin Fan into a 4pin HEader, if thats the case, you might be able to just plug it in, but you wont be able to control speed, etc....either way, i would recommend that thsi only be a very temporary fix, until a proper fan can be ordered that actually fits the header in question.
glassjaw
3 (0.00/day)
Thanks, I'm trying exactly that. I don't have manual controls of the speed anyway... It spins as it wishes :)
9,781 (2.31/day)
Massachusetts
Processor i7-11700K
I hope it works out for you
One more thing, I really would like to stress the fact that you should get a proper replacement as soon as possible.... although nothing terrible would likely happen, it's in my opinion, best to have suitable components for suitable applications, but if tou dont end up cutting anything, it should be fine
:toast:
