mikeymcdee
- Sep 8, 2006
- 1 (0.00/day)
I recently built a computer with the following specs:
Motherboard: ASUS M2N32-SLI Deluxe Motherboard
Processor: AMD Athlon 64 FX-62
Procssor Cooler: ZALMAN CNPS 9500 AM2 2 Ball Green LED Light CPU Cooling Fan/Heatsink
Memory: CORSAIR XMS2 2GB (2 x 1GB) 240-Pin DDR2 SDRAM Unbuffered DDR2 800 (PC2 6400) Dual Channel
Power Supply: Thermaltake PC Toughpower Power Supply 700W SLi Ready
Video Card: ASUS EN7950GX2/2PHT/1G Geforce 7950GX2 1GB 512-bit GDDR3 PCI Express x16 Dual GPU Video Card
Hard Drive: Western Digital Raptor WD740ADFD 74GB 10,000 RPM 16MB Cache Serial ATA150
Tower: Cooler Master CM Stacker STC-T01-UW1
There is a lot of heat comming from the tower and i've tried looking for water cooling kits but have had much trouble finding one that will suit my specs. I have heard of an AM2 bracket that will work for coolermaster water kits but havent had much luck finding anything. If anyone has the same motherboard/video card and have found a good water cooling kit please let me know! Any information will be much appreciated! Thank you for taking the time to read my post.
