Need help choosing a CPU cooler
Which CPU cooler would you choose?
  • Antec Kuhler H2O 620
    Votes: 6 42.9%
  • Antec Kuhler Box
    Votes: 0 0.0%
  • Thermaltake Water 2.0 Performer
    Votes: 3 21.4%
  • Cooler Master Hyper 212X
    Votes: 4 28.6%
  • Cooler Master Hyper 412 Slim
    Votes: 0 0.0%
  • Cooler Master V8 GTS
    Votes: 1 7.1%
  • Total voters
    14
31 (0.01/day)
System Name Blackjack
Processor Intel® Core i7 860 @ 4.11 GHz
Motherboard Gigabyte P55-UD3 Rev. 1.0 (F11 BIOS)
Cooling Cooler Master Seidon 240M
Memory 4x4GB DDR3-1600
Video Card(s) ATI Radeon HD 5850 @ Stock
Storage 3TB+2TB+1TB+500GB
Audio Device(s) Asus Xonar Essence STX
Power Supply Thermaltake Toughpower 600W
Software Windows 7 Ultimate SP1 64-bit
I’m thinking about getting a CPU cooler, but kind of having trouble deciding which one would be the best. Availability of products is a big issue in my country, so I’m forced to choose from the few models that are available here right now. I am going to list the options that I have at this moment, including the local market price. I’ll only list the products that are within my budget.
Antec Kuhler H2O 620 (6500 BDT)
Antec Kuhler Box (6500 BDT)
Thermaltake Water 2.0 Performer (7500 BDT)
Cooler Master Hyper 212X (3000 BDT) **Out of stock**
Cooler Master Hyper 412 Slim (4000 BDT)
Cooler Master V8 GTS (7500 BDT)
My primary choice was Thermaltake Frio Advanced (5700 BDT). Sadly, though, it has run out of stock and I don't feel like waiting for an indefinite period of time for stocks to be refilled, unless all the other choices are absolute crap compared to its price/performance ratio.
Finding reviews and comparing these exact models with one another proved to be quite fruitless so far, mostly because the reviews used different testing methodologies (different CPU and clock speed, especially) and none had more than 3 of these compared in one single review (including TT Frio Advanced, which I’m considering to be the “standard”).
Personally, I’m leaning towards the Antec Kuhler H2O 620 but can’t be sure about how it’ll perform compared to TT Frio Advanced. Also, I’ve never used any All-in-One liquid cooler before, so kind of confused about their durability as well. I am open to suggestions, by the way.
I’m running the CPU at 3.6 GHz now, thanks to the crappy cooler I currently have. But I’m planning to push it to ~4/4.2 GHz if the new cooler can handle it.
I have also posted a poll here, feel free to cast your vote.
Edit: Updated product availability.
12,062 (2.75/day)
Gypsyland, UK
System Name HP Omen 17
Processor i7 7700HQ
Memory 16GB 2400Mhz DDR4
Video Card(s) GTX 1060
Power Supply 230W
Mouse Roccat Kone XTD+
If poor, Hyper 212 EVO
If Mr Money, H80i or Kuhler 620
96 (0.02/day)
Iceland
System Name Massi
Processor Intel i5 10600K, 6 core @5Ghz
Motherboard Gigabyte Z490 GAMING X
Cooling Corsair H115i PRO 280mm
Memory Corsair 16GB DDR4 3600Mhz
Video Card(s) Asus 5700 XT OC 8GB
Storage 1TB ADATA XPG SX8200 Pro
Display(s) Asus 27" PG278QR TN LED 1ms, 2560x1440, 165hz
Case Corsair Obsidian 450D, Noctua fans in front, up, and back
Audio Device(s) Onboard Realtek ALC1200
Power Supply Corsair RM850X 850W
Mouse Asus Gladius Optical Gaming
Keyboard Black, Asus
I have a Thermaltake Water 3.0 Performer witch is pretty much the same as 2.0 cooling my FX 8350.. excellent cooling performance !
sneekypeet
Retired Super Moderator
29,409 (4.46/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
what is the maximum temperature you are seeing now?
31 (0.01/day)
If poor, Hyper 212 EVO If Mr Money, H80i or Kuhler 620
I'm poor, hahah! But I also want to keep going with the current CPU for as long as I can, so the little extra juice is worth the investment.
It has to be good. My question, though, was about which one among these is the best. TT Water 2.0 is also one of the most expensive ones in my list.
~80-ish under Intel Burn Test load. As I said, the current cooler is crappy and 3.6 GHz is the absolute max I can go.
P.S. Could a moderator please edit the first option in the poll and add "620" at the end? I seem to have forgotten to add that and I can't edit it either.
sneekypeet
29,409 (4.46/day)
System Name EVA-01
I would say the Tt Water2.0 is likely the best choice. It is a newer head unit and pump than the 620, and will outperform all of those air coolers. The CM V8GTS would be my second choice.
8,069 (1.40/day)
Hillsboro, OR
System Name Main/DC
Processor i7-3770K/i7-2600K
Audio Device(s) on board
The Thermaltake Frio Advanced is actually fairly poor performer. Frostytech review
The V8 is overpriced.
Can you get any of the CM TPC coolers?
Of the ones you have listed:
*Antec 620/TT Performer would perform the best
*CM 212X would be next on my list
31 (0.01/day)
I called the distributors and they cannot bring in TPC coolers, sadly. And I've got another bad news: CM Hyper 212X stock has run out as well.
So, that leaves me with two "popular" options: Antec 620 and TT Water 2.0 Performer. I want to get one before the stock runs out but still cannot make up my mind.
9,797 (1.90/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
water of course, and take TT Water 2.0 Performer
12,281 (2.35/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
8,069 (1.40/day)
Hillsboro, OR
System Name Main/DC
If you can get the TT Water 2.0 Pro, get it. The extra thickness of the radiator will perform better.
I have a H80i and it kept my 4.4GHz 2600K below 64 degrees while Folding or WCG'ing 24/7, but it was too noisy for my tastes and I replaced it with a Phanteks PH-TC14CS. (I'm old school, I like downward blowing CPU coolers) It now runs about 10 degrees warmer, 10db's quieter (I'm guessing), and that is with only 1 fan due to RAM clearance issues.
1,317 (0.33/day)
System Name Gamer/ HTPC
Processor AMD Ryzen 5 2600
Motherboard ROG Crosshair VI
Cooling Alphacool Eisbaer 420 AIO
Memory G.Skill TridentZ RGB 2x8GB 3333 CL14
Video Card(s) Gigabyte Aorus RX 580
Storage Corsair Neutron 480 GB
Display(s) Samsung 42" 1080p
Case Phanteks Enthoo Luxe Tempered Glass
Power Supply Corsair 750
Software Win10 Pro
Benchmark Scores http://hwbot.org/user/johan45/
I have a TT water 2.0 Extreme and it works great , have used it on and FX 8350 and an Intel 4770k. It keeps them both well within temperature limits at 4.6 G
8,069 (1.40/day)
Hillsboro, OR
System Name Main/DC
31 (0.01/day)
Thank you for your opinion.
Although buying from abroad is my last option, this refurbished one seems to have a lot of complaints in the customer reviews section. Thanks, btw.
Nope, the "pro" isn't available, I'm afraid.
Well, my option was the Performer only but thanks anyway for sharing your experience.
At this point, I'm actually having thoughts of extending my budget a bit. How are the Cooler Master Seidon 240M coolers? It is priced at 10000 BDT around here... worth it?
343 (0.08/day)
Ft Stewart
System Name Queen Bee
Processor 3570k @ 4.0GHz
Motherboard Gigabyte UD3 Z77
Cooling Water Loop by EK
Memory 8GB Corsair 1600 DDR3
Video Card(s) MSI GTX 970 Gaming WaterCooled
Storage 1x Western Digital 500GB Black 1x Intel 20GB 311 SSD
Display(s) BenQ XL2420G
Case CoolTek W2
Power Supply Corsair 650Watt
Software Windows 7 Pro
Usually the larger the cooling surface the better, however these larger 240 rad aio solution's tend to for the much more reckless overclocker. Basically unless you do a LARGE overclock you will see little to no differences as they experience heat soak at higher volts.
31 (0.01/day)
I'm running the i7 860 at 3.6 GHz with only 1.175v, which appears to be a sweet spot for my CPU. Even 3.7 GHz needs 1.22v to be stable under IBT load. So, you see, it's gonna be running pretty hot once I cross the 4 GHz mark.
31 (0.01/day)
Update: I ended up getting a CM Seidon 240M last week. It keeps my CPU ~25-30°C cooler under full IBT load compared to the old crappy CPU cooler. I'm currently running the i7 860 at 4.11 GHz with a vcore of 1.3625v (it's not stable above this mark unless I feed it dangerously high volts). The fans, at full speed, are very noisy, though. So I used Gigabyte's Easy Tune6 to create a custom fan profile that keeps the fans of Seidon 240M silent even under full load. So far, I'm satisfied with the results.
40,435 (6.58/day)
Dark Rock Pro 2/3, Ashura, Macho
18 (0.00/day)
Canton, Ohio
System Name Bob's PC
Processor i7 3770k
Motherboard ASROCK Extreme 4
Cooling Coolermaster 212 Evo 120mm
Memory 8 gig Crucial DDR3 1600
Video Card(s) EVGA GTX 780 SC ACX 3 gig
Storage 2x2tb and 4x1tb seagate and 1x2 tb external hard drives
Display(s) 50" LG
Case Coolermaster HAF 912
Audio Device(s) HD onboard
Power Supply Corsair HX 850
212 EVO is my recommendation keeps my 3770k @ 4.4 around 70c under normal gaming/converting situations. I stopped running IBT and all that crazy stuff I use Wprime & Multicore Super Pi to test my overclocks. As long as all 8 threads are 100% and it don't crash or blue screen I'm happy.
652 (0.13/day)
Fresno, CA
System Name LS Vtec B18B1 Bolt Ons
Processor AMD Phenom ii 1045t x6 @ 3.5Ghz OC
Motherboard ASRock 970 Extreme3 R2.0 AM3+
Cooling CM Hyper 212 EVO Push Pull
Memory CORSAIR Vengeance 8GB (2 x 4GB) Black 1600Mhz
Video Card(s) Sapphire 7950 Dual-X
Storage Samsung EVO 250gb SSD/Samsung 500gb 7200 rpm/WD Cavirar Green 1TB
Display(s) Acer H236HLbid IPS
Case NZXT Gamma (Powder Coated Champion White)
Audio Device(s) Creative Lab SB0460
Power Supply NZXT HALE82 V2 550W
Software Windows 7 Ultimate 64bit SP1
Benchmark Scores Vtec
I have a hyper 212+, it been cooling my 2500k oc to 4.3GHz 3 years straight no problem
