Need help...oc problems
Discussion in 'Overclocking & Cooling' started by h3llb3nd4, Feb 15, 2009.
  1. h3llb3nd4
    h3llb3nd4 New Member
    Feb 15, 2009
    3,323 (1.56/day)
    307
    Durban, South Africa
    I tried to oc my 2220 but my pc refuses to post after a small change such as 201mhz (200mhz stock). multiplier is on max of 12, ram 400mhz (2:1 ratio).:cry::confused::banghead:
  2. MRCL
    MRCL
    May 31, 2008
    5,791 (2.42/day)
    860
    Switzerland, Heart of Europe
    Have you tried raising the voltages?
  3. h3llb3nd4
    Feb 15, 2009
    3,323 (1.56/day)
    307
    no I left it on auto.
  4. MRCL
    MRCL
    May 31, 2008
    5,791 (2.42/day)
    860
    Then try to raise them. Maybe that helps.
    Tho your RAM seems a little weak at 400MHz
    h3llb3nd4 says thanks.
  5. h3llb3nd4
    Feb 15, 2009
    3,323 (1.56/day)
    307
    thanx, so I must raise the cpu voltage?
  6. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (2.98/day)
    862
    Dorset, UK
    You should be able to boot fine with no other changes at 201Mhz, cus that is a reasonable flucatuation anyway.
    Can we have your full system specs so we know what we are dealing with. Like many have done, you can see the drop down under our avatars saying System Specs.
    Go here:
    http://forums.techpowerup.com/profile.php?do=specs
    Fill it out and make sure you choose the drop down as yes to display system specs.
  7. h3llb3nd4
    Feb 15, 2009
    3,323 (1.56/day)
    307
    done
  8. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (2.98/day)
    862
    Dorset, UK
    That is wierd.
    So you saying, based on default BIOS settings, it wont boot at 201Mhz?
  9. h3llb3nd4
    Feb 15, 2009
    3,323 (1.56/day)
    307
    yep.:confused:
  10. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (2.98/day)
    862
    Dorset, UK
    Your mobo doesnt seems to exist, is it defintely P5KL-E
    Can I have a CPU-Z screenshot of the board tab if so?
    :toast:
  11. h3llb3nd4
    Feb 15, 2009
    3,323 (1.56/day)
    307
    well it says so on the manual...
    k
  12. h3llb3nd4
    Feb 15, 2009
    3,323 (1.56/day)
    307
    the mobo uses a g31 chipset
  13. alexp999
    alexp999 Staff
    Jul 28, 2007
    8,045 (2.98/day)
    862
    Dorset, UK
    Its a P5KPL-E , lol.
    Thats why I couldnt find it.
    Not sure what going on then. It should be fine at 201Mhz.
    Does it just give you a black screen when you try it then?
  14. h3llb3nd4
    Feb 15, 2009
    3,323 (1.56/day)
    307
    oh sorry typing error:banghead:
    (also blind LOL:cool:)
    yep gives me the black screen
  15. h3llb3nd4
    Feb 15, 2009
    3,323 (1.56/day)
    307
    Ahh... raising voltages did work, but for a while only because my "Generic" Ram is stopping the overclock form happing... :cry:
  16. Asylum
    Asylum
    Jul 18, 2008
    2,826 (1.20/day)
    687
    South Carolina
    Unlink your ram from your FSB and then try again!!
  17. h3llb3nd4
    Feb 15, 2009
    3,323 (1.56/day)
    307
    I'm Still a nOOb pls tellme how to do that :embarrased:
    Nitro-Max says thanks.
  18. Nitro-Max
    Nitro-Max New Member
    Sep 9, 2006
    2,476 (0.82/day)
    239
    Great Yarmouth, United Kingdom.{East Anglian Coast
    everyone starts out a noob no shame in that and be prepared to make mistakes somtimes costly but if you learn from it its not all bad dont go too wild on the voltages and overclock all in one go just do it step by step.
Share This Page
