need help on finding vids on how to install case (chassis) to motherboard
Odis1987
29 (0.01/day)
I need help help or instructions on how to install a corsair 230T case (chassis) to a MSi B85M-G43 motherboard, when i mean install it i mean how to hook the case wires" like the pw switch and led light wire's.?
Aquinus
Resident Wat-man
13,147 (2.94/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
This might sound like a smart ass comment, but I assure you that it isn't: Read the manual. The motherboard manual will tell you where and how everything needs to be plugged in. The chassis manual will tell you what it has to be plugged in. It's usually pretty hard to screw it up considering the connectors are keyed and won't just plug into any ordinary connector for power. Just take it slow and you'll be fine. It's really not that hard to figure it out.
Bo$$
Lab Extraordinaire
5,656 (1.03/day)
London, UK
System Name Desktop | Server
Processor Intel i7 2700k @ 4.6GHZ | AMD 5350 @ 2500MHZ
Motherboard Asus P7Z77-V Pro | Asus AM1I-A
Cooling Corsair H60v2 | Stock Air
Memory Crucial Ballistix 2x8GB CL8 1600MHZ | Corsair Vengence 2x4GB CL9 1600MHZ
Video Card(s) EVGA GTX 1060 6GB | PNY GTX 750Ti
Storage Samsung 840 EVO 250GB + 4TB WD Red | 2x Seagate Barracuda 2TB
Display(s) Samsung S27D390H + Asus VE276Q | Headless
Case Fractal Design R5 | CM Elite 110
Audio Device(s) Asus Xonar D1 w/Otone Stilo 5.1 and Creative Fatal1ty headset
Power Supply EVGA Supernova 850 G2| Corsair CX430M
Mouse Razer Imperator 2012
Keyboard Corsair K90
Software Windows 7 SP1 X64 | Ubuntu 16.04LTS
+1 Aquinus is right there.
MSI will include a little tag sheet with the connections labeled clearly
Odis1987
29 (0.01/day)
one more question, will a corsair H55 cpu cooler work with a haswell cpu, and will it fit in my corsair graphite series 230t with my graphics's card and motherboard.?
Bo$$
Lab Extraordinaire
5,656 (1.03/day)
London, UK
If you have the LGA1150 plate then it will work just fine. mounts are the same for the 1155/1154 so you should have it in the box if you haven't already looked.
9,795 (1.90/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
yep, read the manual carefully and just follow it.
always check and recheck before you turn it on.
just be patient too, coz nice build need a time :)
