Need Help With Choosing Power Supply
MTL
132 (0.02/day)
Processor AMD X2 3800+ @2.5Ghz
Motherboard DFI Lanparty SLI DR Expert
Cooling 2X Zalman 120mm fans
Memory 2GB Corsair XMS4000
Video Card(s) EVGA 7900GTO
Storage 250GB Samsung Spinpoint P-Series
Display(s) Dell 1907FP / Viewsonic VX922
Case Antec Sonata II
Audio Device(s) Ac'97
Power Supply OCZ GameXstream 700W
Software Windows XP
I'm looking for a dirt cheap, yet efficient PS what has enough juice to power at least a 7900GT / X1800GTO. I don't have SLI so I don't need dual 12V....I think.
Tell me, what should I be looking for? Any specific connector or do all ATX 2.0 generation power supplies have a graphics card connector? Is it OK to have 1 ATX 12V Connector or do I need 2?
I have an MSI K8N Diamond Nforce4 Ultra Mobo and a 3200+ AMD64
Here are some I have been looking at:
Thermaltake: $45.00
http://www.thermaltakeusa.com/product/Power/TR2power/w006970/w006970.asp
SPI:$33.00
http://www.sparklepower.com/pdf/ATX-350PN.pdf
Powerup: $63.00
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2222641&CatId=0
JPC:$50.00
http://www.justpcusa.com/power-SATA450.htm
So there are my choices. My budget does not go above $65.00 Canadian.
If you have other suggestions, please DO NOT post links to Newegg as they do not deliver to Canada and the prices are nearly double if I try to find the same thing here.
2,481 (0.36/day)
To run either of those cards you would need a 400+W PSU.
So already the Sparkle is out.
It also recommends that you need at least 20A on the 12V line, which means the Thermaltake is out.
And the other two brands I have never heard of before (hence not reliable).
You should always (and I cant stress this enough) get a quality and well-known brand name PSU.
This is bc a unknown PSU can fry your entire computer, so dont take that chance.
I suggest save up some more money so you can get a better and bigger PSU (like from Antec or OCZ) so you can upgrade in the future and not have to replace the PSU.
Also, take a look at the Antec SmartPowers. They are relatively cheap.
656 (0.10/day)
Madrid, Spain
System Name Sample light
Processor AMD Phenom II 965
Motherboard MSI DKA790GX
Cooling Zalman 9500LED
Memory 2x 2GB G-skill PC8500
Video Card(s) Asus built AMD/ATI HD4850
Storage 500GB Wesern Digital green
Display(s) too ashamed to tell, but its an acer
Case Lian Li V2000
Audio Device(s) Echo Audiofire 2
Power Supply Corsair VX550
Software Windows XP pro SP3
there are several manufacturers which sell decent PSU´s (decent, not good, dont expect miracles), at decent price, levicom has a value line called Xilence, also theres fortron which makes decent PCU´s, theres HEC or Enhanced,
error_f0rce
938 (0.14/day)
Wisconsin, USA
Processor Intel Core i7-930 (D0) @ 4.0GHz (1.28v)
Motherboard GIGABYTE GA-X58A-UD3R
Cooling CoolIT ECO-R120 Advanced Liquid Cooling w/ x2 Scythe ULTRA-KAZE 3000rpm | Scythe Master controller
Memory Mushkin Enhanced Redline - 6GB DDR3 @ 1910MHz 8-10-8-29
Video Card(s) MSI N460GTX Twin Frozr II SOC GeForce GTX 460 768MB 192-bit GDDR5
Storage RAID-0 w/ 2x OCZ Agility 2 SSD 90GB SATA II 3.5" (r4.6Gb/s w4.2Gb/s)
Display(s) ASUS VW266H - 26" LCD
Case COOLER MASTER Storm Scout | x2 120mm Scythe ULTRA-KAZE | 140mm Scythe Slipstream KAZE Maru2
Power Supply Thermaltake Black Widow TR2 RX - 850w
I agree with bruins, these are the best/cheap way to go. I just got an Antec SmartPower 2.0 500w from NewEgg 2 days ago for under $70, modular cabeling, all sleeved, it's looks and runs great:rockout: It look like it's only rated at 17A & 19A though, so I don't know about your graphics card. I'm running a Radeon X800 GTO on mine. The next step up would be an Antec TruePower 2.0 550w which has 19A on both rails, but will run you $100 and up. The latter is also SLi certified, should you ever choose that route in the future, you could keep the same PSU.
But I also echo what bruins said, DON'T GET A CRAPPY PSU or it will do this to your computer::nutkick:
Hope this helps, save some money, get a good PSU!
MTL
132 (0.02/day)
Software Windows XP
How about my other questions?
Do I only need one 4-pin 12V connector on the PS if I want to run a 7900? Or should I be looking for one with a dedicated PCI-E connector?
MTL
132 (0.02/day)
Software Windows XP
1,156 (0.18/day)
System Name Alienware laptop R4
Processor intel i7-3610M @ 2,30Ghz
Motherboard dell?
Cooling 2 built in laptop cooling fans
Memory 16GB DDR3 1600mhz
Video Card(s) AMD Mobility Radeon HD m290x 4GB GDDR5
Storage 256 ssd and 512ssd
Display(s) laptop screen 17.3" 1920x1080 + LG 22" inch LCD HD 1920 x 1200
Case My laptop back pack case
Audio Device(s) Sound Blaster
Power Supply laptop brick
Software Windows 7 Home Premium 64 bit
Thermaltake: $45.00
SPI:$33.00
Powerup: $63.00
JPC:$50.00
heres a good and cheap power supply http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1648064&Sku=TC3J-1048 its got 18A on the 12v nine it should have the juice you need.
MTL
132 (0.02/day)
Software Windows XP
There is something wrong with that descrption. It says it has 2 12V rails but looking at the pictures, the sticker says 1 12V @ 18A. Don't I need that line to power my processor?
M
markkleb
choosing a PS is easy
Rule 1- You get what you pay for.
Rule2- figure what you are gonna do(OC, SLI, lots of fans or lights)
Rule3- are you gonna upgrade later(if yes modular is cool)
First go here and figure how much power you need
http://www.extreme.outervision.com/psucalculator.jsp
Than buy a GOOD PS like a Silverstone, FSP, PC Power And Cooling or Seasonic
I use a Silverstone Strider 400 ($50)and that has plenty of power for the X1800GTO.
Remember cheap PS make less than they advertise and good ones make MORE than they advertise.
G.T
573 (0.08/day)
The other side of Hell
Processor 3.20E GHz P4 Prescott
Motherboard Asus P4P800-E Deluxe
Cooling Zalman (CNPS7000B-CU) Super Flower Cooler + Ultracool II fan controller
Memory 2 Gig Mushkin HP 3200
Video Card(s) Leadtek A6600GT TDH
Storage 2 x WD 10k 74GB Raptors in RAID 0 (OS), 2 x WD 80GB SATA RAID 0, 1 X Maxtor 250GB ATA (Media, music)
Display(s) Samsung 19" TFT SyncMaster 913N
Case Antec Plusview Iii (Modded front) 1000AMG SOHO File Server - 5X Antec UV reactive fans - 2xUV tubes
Audio Device(s) Creative X-FI Fatal1ty FPS running through Creative Inspire 6.1 6700 speakers
Power Supply Hiper Type-R 580w Blue with UV cables
Software XP pro (Legit) & shitloads that isn't >:] /serial Brycer and FraxFlamer :)
1,156 (0.18/day)
Motherboard dell?
Thermaltake: $45.00
SPI:$33.00
Powerup: $63.00
JPC:$50.00
ill sell u my 250W for 15$ lmao:D
MTL
132 (0.02/day)
Software Windows XP
So, can someone PLEASE tell me if I need 1 or 2 12V cords or a dedicated PCI-E cord for the cards????
M
markkleb
did you read my post? I think I explained it pretty simple.
MTL
132 (0.02/day)
Software Windows XP
I read the WHOLE post on the frum linked to the site you directed me to and it still didn't tell me if I need a dedicated PCI-E connector.
M
markkleb
Any of the PS that I recommended will be fine and the one G.T said too is fine. Unles you get a very good PS you will have to use a adaptor.
If its possible its better not to use adaptors.
MTL
132 (0.02/day)
Software Windows XP
Do most new video cards come with adaptors?
Is it a 4 to 6 pin adaptor or another kind?
2,481 (0.36/day)
I guess just telling you the PSU to look for wasnt enough.
So here is a link (I believe ZipZoomFly ships to Canada). http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=273502
This is one of the best brands you could get and is very reliable.
You do not need a dedicated PCI-E to connect your video card, you can also use a 4 pin molex.
I suggest reading up more by the way and doing your research. PSUs are easy to pick out. Just do the following:
1. Make sure that there is enough AMPs on the 12V line since most of your devices draw from the 12V line (Should be at least over 20A these days, 30A if you want to upgrade a lot or OC).
2. Watts don't mean a thing. A 400W PSU can be more powerful than a 500W PSU. This is bc the 500W doesnt have a lot of amps on the 12V line. So watch out....
3. Make sure the PSU has under and over voltage safeties, like automatic shut off so your system doesnt get fried.
4. Make sure it is a known company like FSP, Antec, OCZ, PC Power and Cooling, Sparkle, Coolmax, etc.
5. Dont get a cheap PSU bc it will kill your system. If you see a PSU for $10....its $10 for a reason.
Thats the basics. Good luck
MTL
132 (0.02/day)
Software Windows XP
I see says the blind man. So its basically a 2 molex to 6-pin adaptor for higher end cards. So you have to hope you have at least 2 molex connectors free.
It doesn't matter what most of the other rails are because most of the components draw power from the 12V rail and that is why it should be above 20A. If there are 2 16A rails that means that the PS has a total of 32A for the 12V components,
I GET IT NOW!!!! YAY!!!
{JNT}Raptor
732 (0.11/day)
NY
System Name Ummmm...Mine
Processor I7 920 @ 4.2ghz @ 1.29v's load
Motherboard ASUS P6T Deluxe V2
Cooling Custom 1/2 inch H20
Memory 3x2gb Patriot Sector 7 @2008Mhz 27-9-11-9 1T
Video Card(s) EVGA GTX 580 SC 900/1800/1090
Storage 1-Mushkin 60gb SSD 1-500GB WD Black and 2-1TB 32mb WD Black
Display(s) 25 inch Hanns-G 2ms
Case Custom
Audio Device(s) Turtle Beach Catalina
Power Supply Corsair AX850 Pro Series-Modular
Software All Kinds...and then some.
Benchmark Scores 3dMark 11 P7066 Compare Link- http://3dmark.com/3dm11/251153
Dirt cheap PSU to power a $300+ video card on top of a Quality CPU Is Insane........PSU should one of the Most Important decisions you make when building your own High End system.....buy cheap....buy twice.........and more than likely you'll be buying more than a new PSU when the Dirt Cheap one goes.
You'll buy $1000 worth of parts.............and power It with a "Dirt Cheap" PSU???????..to each his own I guess.
I use the Antec True Control 2 550.....and would recommend It to anyone looking to future proof thier rig......$89 at NewEgg.
