- Nov 20, 2013
- 5,475 (1.44/day)
- Kyiv, Ukraine
System Name | WS#1337 |
Processor | Ryzen 7 3800X |
Motherboard | ASUS X570-PLUS TUF Gaming |
Cooling | Xigmatek Scylla 240mm AIO |
Memory | 4x8GB Samsung DDR4 ECC UDIMM |
Video Card(s) | Inno3D RTX 3070 Ti iChill |
Storage | ADATA Legend 2TB + ADATA SX8200 Pro 1TB |
Display(s) | Samsung U24E590D (4K/UHD) |
Case | ghetto CM Cosmos RC-1000 |
Audio Device(s) | ALC1220 |
Power Supply | SeaSonic SSR-550FX (80+ GOLD) |
Mouse | Logitech G603 |
Keyboard | Modecom Volcano Blade (Kailh choc LP) |
VR HMD | Google dreamview headset(aka fancy cardboard) |
Software | Windows 11, Ubuntu 20.04 LTS |
Port is not crippled and not a single sane manufacturer will intentionally limit the current in complete disregard to specification
PSU is definitely not 80+ certified, so even if we give it an optimistic 75% efficiency before it starts losing its mind, we will get a safe margin of 180W.
85W is used by CPU at 100% load assuming that it is not overclocked. Then you have devices like motherboard, RAM, HDD, ODD etc, which use not so much individually, but add up to a significant number.
His entire system without CPU uses approximately 130W at full load, so with GTX750Ti this number jumps a bit over the safe limit. He might experience occasional voltage fluctuations, maybe some random shutdowns, but nothing serious.
If @JunkBear at some point decides to add an SSD and another stick of RAM - that's another 5W. Even an 80+ certified PSU starts to wobble at that point.
So there are a few ways to fix this:
1) Downgrade the CPU to something 65W or lower (e.g. Pentium G3258 )
2) Downclock the existing CPU to the point where it acts like Pentium G3258
3) Tear out the ODD and do not use any USB devices. Forget about overclocking and if you are still desperate for power - take out all fans and just blow really hard to cool off the CPU.
4) Just buy a 25W GT730, or wait for low-budget variations of R5/7 3xx or GT9xx if there will be any.
Don't forget that it is a pre-made aftermarket low-budget PC.240W-84W=156 watts Do you really think that 156 watts isn't enough to run a 75 watt (MAX) GPU and all of the rest of the computer? And that's assuming a 100% load on the CPU and GPU at the same time. Now the OP should stay away from running MAX CPU benchmark AND MAX GPU benchmark - at the same time.
