Need recommendations for low-power, high ppd Eyefinity capable card
Discussion in 'Folding@Home' started by twilyth, May 27, 2011.
  1. twilyth Guest
    Right now I just have a 5770 folding. I need another 3-monitor card and would prefer to stay with AMD but I will try to have an open mind.
    My parameters
    1. up to $200 street price (that's a pretty hard limit)
    2. must use under 150w under load (also a hard limit)
    3. eyefinity/other 3-monitor support
    According to the behardware survey earlier this year, for the mid to high-end AMD cards, that limits my choices to 6850, 6870, 5770 and 5850.
    I've checked the ppd database on OCN and while there are a number of data points for the 5770 and 5850, there's nothing on the 6850 and only one entry for the 6870.
    Any help is appreciated.
  2. entropy13
    entropy13
    Mar 2, 2009
    4,978 (2.34/day)
    1,221
    5850.
  3. 95Viper
    95Viper
    Oct 12, 2008
    4,455 (1.96/day)
    1,629
    στο άλφα έως ωμέγα
    Velvet Wafer says thanks.
  4. twilyth Guest
    Very helpful. Thank you. :respect: :respect: Although the 6870 bests the 6850, the later seems to provide the better combination of ppd and power usage. The 6850 jumps into an early lead.
  5. entropy13
    entropy13
    Mar 2, 2009
    4,978 (2.34/day)
    1,221
    But the 5850 trumps both. ;)
    5850 - 49.54 PPD per (peak) watt
    6870 - 47.33 PPD per (peak) watt
    6850 - 44.49 PPD per (peak) watt
  6. twilyth Guest
    True but I was looking more at total power usage. The 5850 is right at the border of my power requirements with 151 watts on furmark and 142 on 3dmark, while the 6850 is well below the limit with 116 and 107 respectively. But thank you for pointing that out and doing the math. :toast: :toast:
    edit - it definitely would rule out the 6870 in favor of the 5850 though, so that is very helpful. :respect:
  7. twilyth Guest
    OK, last call. I have a Powercolor 6850 queued up on Newegg along with a couple of PCI to IDE/SATA/eSATA expansion cards. Tell me why I shouldn't get it or I'm going to tickle a puppy.
Share This Page
