No OpenCL for AMD 6970M?
ransagy
6 (0.00/day)
I can't get GPU-Z to detect OpenCL on my mobile (Clevo) AMD Radeon 6970M.
Geeks3D GPU Caps Viewer shows OpenCL and runs the OpenCL GPU tests fine.
LuxMark also finds the OpenCL GPU support.
I'm running the 11.12 mobility drivers as well as installed the APP SDK 2.6 for good measure.
Just as a point of reference, i got to this after trying another OpenCL app - FLACCL - which failed to run.
I'm just wondering why GPUZ fails to see the OpenCL GPU device and others can.
W1zzard
Administrator
28,606 (3.74/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
whats the name of the opencl device?
should be something with the gpu codename
ransagy
6 (0.00/day)
It just says 'Barts' which is the codename for the GPU, i believe, as you said.
W1zzard
Administrator
28,606 (3.74/day)
Memory 48 GB
gpu-z calls your gpu blackcomb ?
try the attached build
  • GPU-Z.exe
ransagy
6 (0.00/day)
It does, and your version fixes the issue. Is this a test build i missed somewhere? I looked in the test forum.
Either way, This certainly shows OpenCL.
"Supported Version: Full"
"Supported profile: OpenCL v1.1 AMD-APP(831.4)"
W1zzard
Administrator
28,606 (3.74/day)
Memory 48 GB
nope, just fixed the problem. changes will be included in next release. thanks for reporting this
the underlying issue is that for some reason amd calls their opencl device by the gpu codename.
codenames are not meant for public so this is bad already. next they call their mobile gpus the same as the desktop gpu in opencl. technically this is true, because it's the same silicon, but at other occasions amd uses separate marketing names for their mobile gpus.
gpuz needs some special case handling to account for this
ransagy
6 (0.00/day)
Interesting. I'll lookout for a new version and will rest assured OpenCL is enabled now :)
Thanks for the very, very fast replies and a very useful application.
1,039 (0.17/day)
Frankfurt/Main - Germany
System Name Shaman of Sexy
Processor AMD Phenom II X4 955 BE@4Ghz EK Supreme Block
Motherboard M3A79-T Deluxe Anfi-Tech Waterblocks
Cooling Magicool 360 + 120 + 120 Slim scythe slipped Laing DDC-1/T
Memory 4GB Corsair Dominator CM2X2048-8500C5D
Video Card(s) Sapphire ATI Radeon HD 4870 X2 EK 4870 X2 Block
Storage RAID 0 Seagate
Display(s) Samsung 226BW 22"
Case CoolerMaster Cosmos RC-1000 in mod progress
Power Supply Coba Nitrox 750W
Software Windows 7 Ultimate
Benchmark Scores http://service.futuremark.com/compare?3dmv=1056967
just have same problem on the antilles
Geeks 3d GPU Caps Viewer reports as Cayman and enabled OpenCL
and no openCL in GPU-Z
thx
ransagy
6 (0.00/day)
And the build posted here doesn't work for you? (If it doesn't, I guess it was made only to test that specific gpu codename)
I guess the next version will be made to detect these special cases, as said.
1,039 (0.17/day)
tried it , same as 0.5.7 from build nr. but not shown
W1zzard
Administrator
28,606 (3.74/day)
Memory 48 GB
check the attached build for antilles please
  • GPU-Z.exe
ransagy
6 (0.00/day)
In any case it matters, That build also retains the proper detection for mine.
13,848 (1.84/day)
System Name Dark Monolith
Processor AMD Ryzen 7 5800X3D
Motherboard ASUS Strix X570-E
Case Silverstone Kublai KL-07
OpenCL is not getting detected for my HD6230 either (AMD Fusion E-450).
DirectCompute 5.0 is detected but not OpenCL even though i've installed the runtime thingie with the drivers. Catalyst 11.12.
W1zzard
Administrator
28,606 (3.74/day)
Memory 48 GB
please post a gpuz and gpu caps viewer screenshot
1,039 (0.17/day)
Hi W1zzard,
works !
maybe you could also show the version used in the ballon tips ?
thx
ONH
12 (0.00/day)
Hallo W1zzard
Same problem here with 2 GPUs.
The First 1 is
where the Opencl Device name is "BeaverCreek", according to clinfo.exe.
And the second one is
where the Opencl Device name is "Loveland", according to clinfo.exe.
thanx
