Power down and connect PCIe Power Cable error on NVIDIA GPUs: hardware or not?
21 (0.02/day)
Philippines
System Name DESKTOP-yes
Processor AMD Ryzen 5 2600
Motherboard MSI A320M PRO-M2
Cooling AMD Stock Cooler
Memory 8x2 Ballistix Sport LT DDR4-2666
Video Card(s) NVIDIA GTX 1070
Storage KINGSTON A400 120GB SSD, SEAGATE BARRACUDA 1TB HDD
Display(s) BenQ XL2411, some tv i found
Case Inplay Meteor 01
Audio Device(s) Motherboard Audio, KZ DQ6
Power Supply Seasonic FOCUS GX-750
Mouse Model O Wireless
Keyboard Anne Pro 2
Hi.
I have been given a GTX 1070 that the former owner said had an error that said: Please power down and connect PCIe power cable for this graphics card. I can't test it on my PC just yet since it was given quite recently and the owner will ship it sometime next week, but I want to know if it is a kind of red flag that indicates a dead GPU, or if I just need to put in 2 PCIe cables.
Thanks in advance!
5,501 (1.43/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Just guessing here, but it sounds like the former owner was attempting to use the card without any power connections to the PSU.....or perhaps his connectors were not fully engaged, or the cables were flakey/defective, or even the sockets on his psu were kaput...
Virtually any modern GPU needz some juice to work propely, in addition to what they get from the pcie slots...even though the 1070 series cards aren't giant power hogs but still...
So if thats the case, you should be able to run it normally once connected correctly, assuming nothing (else) is actually wrong with it....
Good luck :)
21 (0.02/day)
Philippines
Keyboard Anne Pro 2
Good luck :)
That's what I was guessing. I currently am asking what power supply was used to test the GPU, just so I would know if it's not enough juice that was the problem. I searched more, and I think the only thing I should watch out for is that the power connectors themselves might be dead, but with the GPU with display, I don't think that's the case.
Thanks for the answer!
5,501 (1.43/day)
Motherboard AZW SEI
no problem, glad to help....
Just to add though, if the card was functional enough to know that it needed moar powa, then it is most likely ok, unless the former owner ran it for a long time with the cables being connected, or used it under heavy loads for an extended time :D
21 (0.02/day)
Philippines
Keyboard Anne Pro 2
Talked to the former owner. Said he used a modular power supply with the card, and that the connectors were defective.
So it means that I might get a straight dead GPU (~3/10 dead gpu), unless I make soldering magic and work the 12V connector? I'm feeling kinda doubtful with the GPU now, but I wish the card good luck.
40,435 (6.57/day)
Hi.
Thanks in advance!
Yes vreg is dead, do not
Buy it
21 (0.02/day)
Philippines
Keyboard Anne Pro 2
Buy it
Hi, sorry for the really late reply. I didn't take it since there was someone else who wanted to buy it from him. Thank you for that, though.
By any chance, can you care to explain what the issue might be, if I were to take it?
Thank you!
