Project: Aluminum Water Cooling Case
Discussion in 'Project Logs' started by Spotswood, Apr 17, 2011.
  1. Spotswood
    Spotswood
    Sep 2, 2009
    125 (0.05/day)
    171
    New Hampshire, USA
    This is a project/build log for an aluminum case designed specifically for a large water cooled rig, specifically:
    • 3 x 140x4 radiators
    • 1 140x3 radiator
    • 10-slot motherboard tray
    [​IMG]
    [​IMG]
    [​IMG]
    Stay tuned!
    adulaamin and Cold Storm say thanks.
  2. t_ski
    t_ski Former Staff
    Apr 11, 2006
    11,635 (3.24/day)
    5,725
    In the for the first sub :toast:
    Chicken Patty and Spotswood say thanks.
    Crunching for Team TPU
  3. Spotswood
    Spotswood
    Sep 2, 2009
    125 (0.05/day)
    171
    New Hampshire, USA
    The basic frame of the case is done, which consists of .5x1-inch u-channel with its ends plugged with blocks (pictured in the first post), press-fitted and pinned with a #4 screw along with some 1-inch angle:
    [​IMG]
    [​IMG]
    [​IMG]
    The assembled case frame is too tall to fit in the camera frame. hehe
    [​IMG]
    The frame looks kind'a "meh" until I bolt on the gorgeous anodized quarter rounds.
    [​IMG]
    [​IMG]
    Cold Storm says thanks.
  4. Funtoss
    Funtoss New Member
    Mar 4, 2011
    588 (0.33/day)
    61
    New Zealand
    How much did all these cost you!?
    it looks so nice!
  5. Eric_On_Web New Member
    Apr 4, 2011
    271 (0.15/day)
    19
    Depends where you live Funtoss. You are in New Zealand and hes in USA. For my part I am in Quebec one of the largest aluminum producer in the world so even cheaper here. Seek around in New Zealand if there's a big aluminum importer from China or producer in your country. Just saying..like a world economy class at the same time. hehehe
  6. Spotswood
    Spotswood
    Sep 2, 2009
    125 (0.05/day)
    171
    New Hampshire, USA
    The two shelves were cut from a .10-inch thick 5052 via my trusty router, a straight edge and a downcut spiral bit.
    [​IMG]
    At the back corners of the shelves, two .5x1-inch cutouts were routed out via a temporary router jig.
    [​IMG]
    [​IMG]
    The rounded inside corner left by the .5-inch flush router bit were filed square.
    [​IMG]
    FWIW, here's the difference in the thickness of the aluminum sheeting I use compared to everyone else.
    [​IMG]
    Finally, a mockup of the shelf inside the frame of the case:
    [​IMG]
  7. lonewolf
    Jun 14, 2009
    107 (0.04/day)
    30
    Alabama
    that is just awsome. I want one!
    Spotswood says thanks.
  8. Cold Storm
    Cold Storm Battosai
    Oct 7, 2007
    15,014 (4.92/day)
    3,002
    In a library somewhere on this earth
    sub to watch it all unfold. Thanks for the project.
    :toast:
  9. gumpty
    gumpty
    Apr 29, 2008
    744 (0.26/day)
    134
    Auckland
    Subbed.
    That is one huge case.
    3 x 140x4 + 1 x 140x3 = 3ft² of radiators.
    Huge.
  10. DrunkenMafia
    Jan 12, 2007
    2,277 (0.69/day)
    232
    Cairns QLD, Aussie
    That thing will be solid!! Love it :)
  11. mATrIxLord
    Feb 18, 2010
    93 (0.04/day)
    24
    subed.... i wanna see how this goes... it will give me a few ideas...
  12. Spotswood
    Spotswood
    Sep 2, 2009
    125 (0.05/day)
    171
    New Hampshire, USA
    The 5.25-inch drive bay rails finally came back from a local fabricator.
    [​IMG]
    And a 140x4 rad arrived in the shop.
    [​IMG]
    [​IMG]
  13. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.11/day)
    3,777
    Hmmm, subbed.
  14. >>PhoeniX<<
    >>PhoeniX<< New Member
    Jan 2, 2011
    131 (0.07/day)
    11
    Subbed :) Looks great
  15. Blue-Tiger
    Blue-Tiger New Member
    Jan 28, 2011
    42 (0.02/day)
    7
    Houten, the Netherlands
    Subbed, the model looks soo clean! :D
  16. Spotswood
    Spotswood
    Sep 2, 2009
    125 (0.05/day)
    171
    New Hampshire, USA
    Next up is to cut the front sheet.
    [​IMG]
    In order to cut-out all of the openings for the 5.25-inch drives accurately, a custom router template is required. I used .5x1-inch u-channel and .25x1.25-inch flat bar to frame the openings on .5-inch particle board.
    [​IMG]
    The aluminum bits guided my flush trimming router bit.
    [​IMG]
    The aluminum bits were removed and the particle board template was used to cut the .10-inch thick aluminum sheet.
    [​IMG]
    [​IMG]
    Now I just need to square all of the corners and cut to width. Ugh.
    PopcornMachine says thanks.
  17. PopcornMachine
    PopcornMachine
    Aug 17, 2009
    1,565 (0.66/day)
    459
    Los Angeles/Orange County CA
    Another huge case. That is one big radiator you've got there.
  18. ERazer
    ERazer
    Oct 8, 2009
    1,576 (0.68/day)
    500
    Republic of Texas
    subd! this guys projects r EPIC!!! :respect::respect:
  19. Chicken Patty
    Chicken Patty WCG Moderator Staff Member
    Nov 27, 2007
    28,341 (9.45/day)
    12,231
    Miami, Florida
    Subbed, this looks good. :)
  20. DrunkenMafia
    Jan 12, 2007
    2,277 (0.69/day)
    232
    Cairns QLD, Aussie
    more?? pleease!! Loving the fabrication on this project. :)
  21. Spotswood
    Spotswood
    Sep 2, 2009
    125 (0.05/day)
    171
    New Hampshire, USA
    "Life" had gotten in the way of this project for a few weeks, but I've managed to fabricate the inner and outer sheets of the front panel. It took me 5 hours to square-off all of the inside corners.
    [​IMG]
  22. HammerON
    HammerON The Watchful Moderator Staff Member
    Mar 2, 2009
    6,914 (2.72/day)
    4,063
    Sub'd. Glad to see you building another monster case!
  23. fullinfusion
    fullinfusion 1.21 Gigawatts
    Jan 11, 2008
    8,767 (2.97/day)
    2,485
    Subbed, this is going to be good :rockout:
  24. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.11/day)
    3,777
  25. Spotswood
    Spotswood
    Sep 2, 2009
    125 (0.05/day)
    171
    New Hampshire, USA
    Yep.
