[Case Gallery] Project Water Cooled
Cndmeatshield
20 (0.00/day)
Specs:
Case: Haf X
CPU: AMD 8150 Water block EK Full Copper
MB : ASUS Crosshair V Formula Water block EK Crosshair
GPU: 2X EVGA 480 Water block Danger Den
Ram: Gskill G.SKILL Ripjaws X Series 8GB
Rad: Phobya G-Changer 360
SSD:G.SKILL Phoenix Pro Series FM-25S2S-240
HD : Seagate Barracuda ST1000DM003 1TB
PS : CORSAIR Professional Series Gold AX1200
Reservoir: Zalman RESERATOR 1 V2
Mods:
Copper Manifolds
Hey there all, I'm Cory.
This is my first water cooled build mod of ANY sort, I have planned this out and carefully selected every piece for the best results. it's taken a good 4 months for purchasing and 1 month for modding building.
I started with a Haf X PC case and had it striped and nickle plated.
The vid water blocks are from Danger den and the MB and CPU blocks are from EK bought through Dazmode here in Toronto.
The manifolds are build by me using a pex style manifold.
http://www.pexsupply.com/Sioux-Chief-672XV0342-1-Copper-Manifold-w-1-2-Crimp-Ball-Valves-3-outlets-5435000-p
I went this route b/c I wanted each component to have cool water and not have it add heat every stage. The manifold is fed via 2 1/2" ins to equal pressure and flow concerns. They also have brass ball valves to help regulate flow if needed. Also and easy way to lock off part of the system IF components need to be replaced.
If you have any questions about this please ask
124 (0.03/day)
Stockholm
Processor Intel I7 2600K @ 4.5ghz 1.26
Motherboard Asus P8P67 Deluxe B3
Cooling Corsair H100i
Memory Crucial Ballistix Tracers 1600 cl9
Video Card(s) GTX 580 SLI
Storage Samsung 500gb SSD, WD Caviar Black 500gb HDD
Case Corsair 550D
Power Supply Corsair AX850
yeah 5 for this "non mod" GJ
Troll
861 (0.17/day)
System Name FragBox
Processor Intel Core i7 2600K @ 5.0GHz/1.45 volts
Motherboard Asus P8Z77 WS
Cooling Custom CPU loop
Memory Kingston 12GB DDR3 1600
Video Card(s) Galaxy GTX 680/Zotac GTX 680 in SLi/EVGA GTX 650Ti
Storage 2 Vertex 3 120's, raid 0, 2 Seagate Momentus XT 500GB's in raid 0, 1 Hitatchi 2TB for backup
Display(s) 3 Acer S232HLX2 in nvidia surround
Case Corsair C70 White
Power Supply Corsair AX1200
Software Win 7 x64 Pro
8/10
I like that its something new, not my style tho.
INSTG8R
Vanguard Beta Tester
7,970 (1.12/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
Like the use of Copper and the classic Reserator.
Cymist
2 (0.00/day)
Processor Intel i7 860
Motherboard EVGA P55FTW
Cooling Corsair Hydro H70
Memory 12 GB Corsair dominator
Video Card(s) EVGA Gforce470 GTX
Storage 4x WD black caviar 1TB no raid
Case Thermaltake Tsunami
Power Supply Enermax 650W
Software Win7 ultimate x64
Reserator fan
well i see one basic flaw in your design.. and its not a flaw that will kill your system but i could potentially damage it over time
you see ive had one of those old skool reserrators for a while.. and ive stopped using mine for one good reason.. it simply does not cool the resevoir enough on a hot summer day, i guess thats why Zalmann invented the reserator fan that goes on top of the reserator and blow air down along the "fins"... but i didnt see one of those on your pics :(
I found my rig to run hot on summer days here in Denmark where hot is kinda relative.. we are talking 25 to 30 degrees celcius outside in the shade... to be honest i never got around to getting my room temeprature taken when i had the problems... and mind you.. this was only with running watercooling on the CPU and NOT on the GPU.. which back then was a Gainward 7800GTX and my CPU was a AMD FX60 i think (not sure here)
so for you to run a single uncooled reserator on both your CPU and on DUAL GPU's is kinda optimistic i think... there is 1 upside to the reserator tho.. it is ULTRA quiet, altho i don't know the db lvl of the optional fan...
if i were you i would have gone for an actively cooled unit instead of the passive cooling tower, especially since you are cooling 3 components in your case
anyways best of luck and it looks damn cool for sure :D
Cndmeatshield
20 (0.00/day)
Thanks for the info.
I am running a radiator 360 with three 120mm fans
I've run a number of days on 30c+ and the total heat will not go above 49c
Cymist
2 (0.00/day)
sounds much better that you would put an active radiator on your rig.
The radiator you mention, is it the Black Ice GTX 360 ?
Aquinus
Resident Wat-man
13,147 (2.93/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
I've seen this before, you sure you haven't posted this on here before?
Cndmeatshield
20 (0.00/day)
One year Update
Hey there all.
Thanks to anyone who is still reading this.
I thought I would make an update on how my computer is doing.
I have recently changed out some old bad hose that had gone hard and had growth in it despite i water change and flush and biocide added at the on year mark.
I changed out the CPU water block as the flow was a concern. I swapped it out with the new version of the same EK full copper water black. As the new one had a far bigger flow plate opening.
I removed the top GPU as it had failed at about the 9 month mark sadly. As I voided the warranty by adding the water black i had to buy a new one. This replacement has been put into my current media box to see how well it runs and to see if it fails b4 I water block it.
Other then that this machine runs VERY well and still under load it runs 6-10C above ambient temp with a healthy OC.
here is a link to my media box build and the most recent pictures of my computer
