- Aug 14, 2014
- 190 (0.05/day)
- France
Processor | 5800X3D |
Motherboard | MSI Prestige X570 Creation |
Cooling | Corsair Hydro H100i RGB Platinum SE |
Memory | Kingston 32Go 3600MHz |
Video Card(s) | Nvidia 4090 |
Display(s) | Asus XG27UQ + Asus PG279Q |
Case | Corsair Obsidian 750D |
Power Supply | Corsair RM850x White |
Here is my problem , I will try to be as specific as I can.
As it appeared that my card is voltage locked , I thus decided to flash another bios version.
My bios version was 015.044.000.008.000000 , and I tried to flash the Sapphire.R9280X.3072.130829 version (015.039.000.000.000000).
I was in the UEFI bios version of my graphic card while doing it.
Since then, I am unable to boot , even in the motherboard bios , and obviously no video signal is transmitted.
As my card has 2 different bios , the legacy and the uefi one , I was able to switch between them via the dedicated button on my graphic card.
Back to the legacy bios , I was able to boot and everything worked as expected.
Nevertheless , here is my question : Is it possible to get back to my previous uefi bios , even if I currently can't get anything working while using it ?
(I am just trying to know if in any way I could get back to my regular setup with my uefi bios, otherwise my card is working fine as before.)
Notes :
-Take a look at my system specs.
-I did save my bios before flashing.
-The bios I was trying to flash was from the " Tahiti B0 XTL C38650 GDDR5 3GB 500e/150m " (Information from VBE7 " ROM message " ).
-I flashed using ati winflash 2.6.7.
-I afterwards realized while comparing memory types using "Memory Info" that I have a Elpida ram whereas the bios I flashed had the Hynix model.
-I apologize for my hypothetical obtuseness or bad english
Notes :
