Sapphire HD4850 Noise Issue
Discussion in 'AMD / ATI' started by neurogas, Jul 12, 2010.
  1. neurogas New Member
    Jul 12, 2010
    22 (0.01/day)
    0
    Can you give me additional information?
  2. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    Sounds to like like something may have been knocked during the install of the AC Twin Turbo Pro. :(
    You know it is directly linked to the GPU since you did switch out the card and it has only happened sine you change the cooler.
    I don't have anymore possible answers.
  3. neurogas New Member
    Jul 12, 2010
    22 (0.01/day)
    0
    As predicted...well the new card that i've linked in previous page it's a good card?
    I've fonded it at 80euros and it's compatible with my Artic Cooling Accelero
  4. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    I do not know much about the ASUS HD5840 1GB you are interested in.
    Only one issue, you may not be able to change the fan speed or read the fan speed of the Twin Turbo Pro.
    The fan power connector on the ASUS HD4850 1GB is different from the reference model HD4850.
    It comes with a 3-pin instead of a 4-pin fan connector which means it either has no fan control or no fan speed sensor but most likely no fan control.
    I also find it strange the ASUS HD4850 1GB has no VRM cooling. :wtf: but the Twin Turbo does come with a set of VRM cooler fortunately.
  5. Radical_Edward
    Radical_Edward
    Jan 24, 2010
    3,586 (1.63/day)
    1,927
    Oregon, USA
    Maybe you shorted something out and it's caused permanent damage.
    Crunching for Team TPU
  6. neurogas New Member
    Jul 12, 2010
    22 (0.01/day)
    0
    The accelero comes with an 3 pin adapter, and i think that the fan control it's in percentages (like mine video card, that have only two pins!)
    For corfirm, the performances are the same between two cards?
  7. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    Interesting.
    Only two pins and your GPU fan gets control and monitoring.....
    As far as I know you need a V & Earth which leaves the other two wires as Fan control and or fan speed sensor.
    As for the performance between your card and the one you are looking at, I would not be certain.
    Just look for a review of the two of them and compare the clock speeds if they have the same VRAM size.
    Choose the one with the higher clock speed.
    I find it interesting the ASUS HD4850 doesn't have any VRM heatsink as stock.
    Not even any RAM coolers, just a heatsink.
  8. neurogas New Member
    Jul 12, 2010
    22 (0.01/day)
    0
    Maybe the asus uses less-heating components, maybe in OC cooled correctly can make an big "step".
    Unique differences between cards are:
    Asus have 1024MB memory instead of 512MB
    Asus don't cool VR (no problem, i will use the accelero kit)
  9. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    Looks like the card has been revised
    Same card but non reference PCB.
    ASUS EAH4850/HTDI/1G Radeon HD 4850 1GB 256-bit GD...
    As I mentioned about the VRMs without cooling.
    The reviews seems to state is does indeed overheat with it's stock cooling.
    So in theory the card will run without issue if using a Accelero Twin Turbo.
    Just make sure you stick the VRM coolers on the little black squares :)
  10. neurogas New Member
    Jul 12, 2010
    22 (0.01/day)
    0
  11. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    The link to the card you sent is actually the model off the ASUS site which you first sent.
    I had concerns about the revision from newegg as it has a different VRM layout and looked like the VRM coolers supplied may not be enough or may not sit well.
    The one you are getting is basically the refernce PCB layout which the accelero VRM coolers can sit on well.......as long as some stronger thermal tape is used rather than the pre-applied tape supplied with the heatsinks as mine started to come loose from the VRMs after a little while.
    Also you will find you will most likely have to modify one of your Memory coolers and VRM coolers like I have for the heat sinks to fit nicely.
    Here's is the link on what I had to to to make them fit http://forums.techpowerup.com/showthread.php?t=117343
  12. neurogas New Member
    Jul 12, 2010
    22 (0.01/day)
    0
    Witch of two models? Asus EAH4850/HTDI/1G or Asus EAH4850/2DI/1GD3?
  13. Widjaja
    Widjaja
    Jun 12, 2007
    4,819 (1.52/day)
    640
    Wangas, New Zealand
    EAH4850/HTDI/1G is best suited for the AC Twin Turbo as it is the reference HD4850 PCB
    Choose this one simply for assurance of compatibility with the AC Twin Turbo.
    EAH4850/2DI/1GD3 is an ASUS revised PCB which may not work with the AC Twin Turbo.
    Plus if you read the reviews on the card on the newegg link I gave you, many people who purchased it state the card over heats.
    BTW:-Newegg has incorrectly named the card as the one you are interested in purchasing.
  14. neurogas New Member
    Jul 12, 2010
    22 (0.01/day)
    0
    TNX i will look for the EAH4850/HTDI/1G ;)
  15. OneMoar
    OneMoar There is Always Moar
    Apr 9, 2010
    5,806 (2.73/day)
    2,630
    Rochester area
    the noise is NOT from the cooler its from the gpu its self probably the Vddc its normal for voltage regulators not made with proper shielding
    electronic regulators make noise
    and without writing a 2 page post on electrical theory you probably wouldn't get it
    its normal and happens a lot i had a old 9800pro that used to make my dog bark
  16. neurogas New Member
    Jul 12, 2010
    22 (0.01/day)
    0
    it's from the gpu & the speakers
  17. OneMoar
    Apr 9, 2010
    5,806 (2.73/day)
    2,630
    Rochester area
    its just EMI
