Seriously considering going to water cooling. Suggestions please.
Discussion in 'Overclocking & Cooling' started by JC316, Sep 24, 2007.
  1. JC316
    JC316 Knows what makes you tick
    Jan 24, 2006
    9,365 (2.56/day)
    913
    Ok, I am tired of the suck ass air cooling and I want to have a water cooler. I like the looks of kits, but I am not against building my own, but I need advice. My budget is $150, give or take a few bucks.
    I only want to cool the CPU and MAYBE the northbridge. The video runs plenty cool already.
    My picks:
    Gigabyte Galaxy II
    Zalman Reserator
    corsair Nautilus
    I want to see yours. I am SURE that d44ve will chime in.
    10 Year Member at TPU
  2. Paulieg
    Paulieg The Mad Moderator Staff Member
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    Wherever I can find the iron.
    I just got my Swiftech H20-120 Compact system up and running. Really easy to set up, and temps are awesome. Check it out....
    http://www.swiftnets.com/
    JC316 says thanks.
  3. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    Oh, and Jab-tech has it for $159, and they ship pretty fast...
  4. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.12/day)
    3,777
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835108075
    That's my suggestion. I have it, and I can crank 1.6v thru my 6000+ all day long, no worries. I also cooled my NB with it (until I got the 2900, block no longer fits, 2900 in the way) by adding the Swiftech MCW30 chipset block.
    If you absolutely don't want to go custom, there is nothing better for your money.
    JC316 says thanks.
  5. Paulieg
    Feb 19, 2007
    11,962 (3.65/day)
    3,041
    Wile, I struggled between the compact or the premium. I bought the compact version because I could put the rad/res into the case. The performance has been great so far.
  6. JC316
    Jan 24, 2006
    9,365 (2.56/day)
    913
    I was looking at that one too, but I didn't see it at the egg. The swiftech looks pretty sweet.
  7. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.12/day)
    3,777
    I put both in the case for my premium as well. But it might be tight in a smaller case. The rad will fit no probs, tho.
  8. mello_newf
    mello_newf
    Jun 12, 2007
    344 (0.11/day)
    18
    Georgetown, Ontario, Canada
    Get the swiftech kit I have the ultra+ kit and it's amazing.
  9. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.12/day)
    3,777
    Bummer. Looks like Swiftech discontinued the Premium. I really believe it's the way to go, imho.
  10. t_ski
    t_ski Former Staff
    Apr 11, 2006
    11,634 (3.24/day)
    5,720
    Yep, the Swiftech kit is a good start. However, if you're not opposed to building your own, try shopping around in the forums for some used hardware. here's some of the stuff I'd recommend:
    Swiftech MCP655 or Danger Den D5 pump - $50-55 shipped used
    Swiftech Apogee GT or Danger Den TDX - $35 shipped used
    2 x 120mm Radiator (swiftech new $40 + shipping, Hardware Labs GT Stealth $50 new + shipping)
    Five feet 1/2" ID vinyl tubing from your local hardware store/ Home Depot - $1 / ft
    Misc fittings and clamps (at home depot) - $5
    JC316 says thanks.
    Crunching for Team TPU
  11. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.12/day)
    3,777
    Honestly, I'd just go with 3/8" ID tubing. It's much easier to route.
    I'd also rather have a Swiftech MCP-350 or 355 (Laing DDC-1 or DDC-2).
    Not that what you listed is bad at all, because it isn't.
  12. t_ski
    t_ski Former Staff
    Apr 11, 2006
    11,634 (3.24/day)
    5,720
    True, the 350/355's are good, as they tend to heave pretty good head pressure and are fairly compact. I like the idea of volume and the flow rate is higher on the 655/D5 (IIRC) and the barbs are natively 1/2" OD.
  13. freeboy
    Feb 17, 2007
    979 (0.30/day)
    26
    I have the basic Corsair N500, great EASY kit.. works far better than air..
    What is your goal?
    If you are serious about extream oc'ing, get a great more expensive kit.. or build your own.
    I would sell you mine at a around 120.00, perfect condition, have not even used the fluid as I purchased another brand coolant! Also a second set of clip connectors to attach to the board as my last upgrad , lost them and the local retailer gave me an extra set and Corsair sent me ones... I would then take your money and start a scratch kit.. let me know if you are interested.... fyi, kit works GREAT, I am just trying to push the envelope! LOL
  14. tkpenalty New Member
    Sep 26, 2006
    6,958 (2.03/day)
    345
    Australia, Sydney
    Swiftec, by far the BEST brand. I would seriously consider going with them as they provide you with almost everything. Pretty good price as well only $400 AUD here, with the whole radiator, CPU, NB, SB, and GPU block! (except im sorta angry that they discontinued the premium kit...)
  15. freeboy
    Feb 17, 2007
    979 (0.30/day)
    26
    but he is on a budget.. way less than 400.00
    read some reviews, we have a geat database on this site!
  16. t_ski
    t_ski Former Staff
    Apr 11, 2006
    11,634 (3.24/day)
    5,720
    That 400 Austrailian dollers, which is rather inflated because of the cost to brings parts there.
    I've managed to install the old loop in my new Intel setup, and temps are very good. I'm using a Storm Rev 2 (bought used for $40), a Danger Den D5 pump (bought used for $55), and a Swiftech MCR320-QP rad (bought new for ~$45). Add fans, tubing and clamps, and the system is running cooler than ever. Looking at idle temps around 23C and load temps around 37C at stock. When I OC to 3.6 GHz and up the voltage slightly I get 25C idle and 44C load.
    If you know what you're doing, watercooling is so much better than air :pimp:
    However, if you want to buy new, I'd go with a Swiftech basic kit, which will run about $130 for the loop, plus the cost of the chipset block if you decide to add that later.
  17. DaMulta
    DaMulta My stars went supernova
    Aug 3, 2006
    16,135 (4.64/day)
    1,458
    Oklahoma T-Town
    Danger Den or that place dom shops
  18. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.12/day)
    3,777
    www.petrastechshop.com
    Some great stuff in there for good prices.
  19. erocker
    Jul 19, 2006
    41,039 (11.76/day)
    16,134
    I think I'm going to try the Swiftec compact system. There are a couple good reviews around. It's basically the premium kit with the pump on top of the heatsink.
  20. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.12/day)
    3,777
    Yeah, and a res on the rad.
  21. erocker
    Jul 19, 2006
    41,039 (11.76/day)
    16,134
  22. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.12/day)
    3,777
    I couldn't tell you. Sorry. The Infinity doesn't have a way for you to rotate the mounting brackets?
  23. erocker
    Jul 19, 2006
    41,039 (11.76/day)
    16,134
    No. I would have to rotate my motherboard retainer. I went ahead and picked the universal mount, a few l.e.d.'s and some MX2! I also think I may buy one of thier w/c kits.
  24. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.12/day)
    3,777
    What kit/kits are you considering?
  25. erocker
    Jul 19, 2006
    41,039 (11.76/day)
    16,134
    I would probablly go with the lite kit. For $135.00, it's a good deal. I have to see how this retention kit works out first for my Infinity.
