Small 2nd Monitor Help
Discussion in 'General Hardware' started by Zaspera, Feb 1, 2011.
  1. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    I'm currently using a 24" ASUS (in specs) but am looking to get a 2nd monitor for my AIDA64 sidebar and maybe itunes and aim? I don't have much room at all left on my desk with the HAF X and monitor. What should I get? I've been looking at 7" usb lcds. Are they any good?
  2. PVTCaboose1337
    PVTCaboose1337 Graphical Hacker
    Feb 1, 2006
    9,512 (2.60/day)
    1,143
    Dallas, Texas
    Those 7" LCDs are expensive for what you get. For $50 you could get a used 19" flatscreen. Check on craigslist. Not only do you get a better monitor, but it is much cheaper, higher resolution, and does not have the USB lag.
    10 Year Member at TPU
  3. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    I understand they cost a ton, but I don't physically have room for a 19" on my desk. :( How bad is the performance on the 7"?
  4. streetfighter 2
    streetfighter 2 New Member
    Jul 26, 2010
    1,658 (0.82/day)
    732
    Philly
    Just an idea but maybe use Maxivista combined with an old (chopped?) laptop? Obviously this isn't rational if you don't have an old laptop but if you do you'd get away at around $50.
    Or maybe if you have a PSP lying around you could use PSPdisp. It'd be one tiny monitor though!
  5. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    Just sold the only laptop I had last week because I didn't need it after building this thing. :(
  6. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.11/day)
    3,777
  7. Mussels
    Mussels Moderprator Staff Member
    Oct 6, 2004
    44,273 (10.67/day)
    11,435
    Australalalalalaia.
    dont forget that the USB and VGA monitors dont support HDCP, so they break HD-DVD and blu ray playback.
    the USB ones also use a lot of CPU power, so it will not be good while gaming.
    Zaspera says thanks.
  8. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    I wouldn't use it to watch HD/blu ray. As for CPU power, I only play WoW and I'm using a 3.2ghz hex core, so I have plenty of cpu power to spare. Are there any 7" monitors that use dvi or vga instead of usb?
  9. Wile E
    Wile E Power User
    Oct 1, 2006
    24,323 (7.11/day)
    3,777
  10. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
  11. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
    dealextreme items take time to arrive since they ship from china...
    Can't you fit a 4:3 15" monitor on your desk? perhaps put your HAF X on a Case holder on the floor?
    remember a 15" 4:3 monitor is almost a square, meaning it is pretty high and pretty narrow, taking less space than a 16:9 monitor. a 15" should be about 12" wide (+bezel)
  12. Mussels
    Oct 6, 2004
    44,273 (10.67/day)
    11,435
    Australalalalalaia.
    i can actually recommend dealXtreme, they're slow but i've never had any problems with items from them.
  13. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
    I, on he other hand, would beware. I've bought ~15 items from them, and out of them 3 were the wrong items. The total worth of both of them weree about 10$ so I didn't bother RMAing or anything though.
    TBH, I would buy from them again though
  14. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    What kind of case holder? I have a 1 year old daughter so crap on the floor usually spells out disaster, but it depends on the case holder I guess.
  15. Goodman
    Goodman
    Jun 13, 2009
    1,521 (0.62/day)
    325
    Canada/Québec/Montreal
    Why not buy a second monitor like an 17" or 19" & a wall mount...;)
    Or make a shelf on the wall or on the side of your desk & put you case on it?
  16. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    I would really love to wall mount the case with the side window facing out. The only problem is the case weighs a shit ton and I have no idea what I would need to mount a stable shelf.
  17. Goodman
    Goodman
    Jun 13, 2009
    1,521 (0.62/day)
    325
    I don't know what kind of desk you got & if you got some room on either side of the desk?
    but if it is wood & you got a little side room to spare you could always make a little extension of your desk with some plywood & 2x2 or 1x2 for support... maybe?
  18. Frick
    Frick Fishfaced Nincompoop
    Feb 27, 2006
    12,234 (3.36/day)
    3,465
    Blurry as heck (phone camera yay!), but here's how I did it:
    [​IMG]
    I used ratchet straps (are they called that? Image.) to tie it to the thing with the drawers. It's very stable, they are rated for 500kg each (there's two of them). :)
    It makes taking apart the computer a hassle, but it was worth it. More desk space = another monitor.
    streetfighter 2 says thanks.
  19. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    I just use a 4' folding plastic table....like an event/banquet table.
  20. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
  21. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    I'm not a handyman by any means. What would I need to make a shelf on the wall to put my case on?
  22. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
    is what I posted above not enough? you really want it much higher? building a shelf will take up alot of time and effort
  23. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    I can't see a picture. Just a little square where a picture would be. When I copy image url, it says the site is down for maintenance.
    edit: "Maplin.co.uk is currently undergoing server maintenance"
  24. n-ster
    Jan 11, 2009
    8,979 (3.47/day)
    1,445
    [​IMG]
    is it good now?
  25. Zaspera New Member
    Jan 5, 2011
    500 (0.27/day)
    11
    Mapleville, RI
    Ya, I can see that one. I like it, but my daughter would have a field day with that thing on the floor.
