so since last month was having problems with my rig simply switching off.
i took out the parts out of the case and started troubleshooting. i lost hope and almost RMA'ed the motherboard.
everything works except the the cpu and the gpu, with the CPU_LED turning red.
it turns out that when i bend the big 24pin eatx power cable a little bit, the whole thing worked like a charm. when i set the cable loose the cpu stops powering up.
the PSU is fine, so the problem lies in the 24pin cable, this is a stupid fkin problem to have, but im happy that i discovered it
so i have to bend it to work it
any suggestions? RMA the PSU?
