T
TechnicalFreak
Hi
Ok, so today I will go and get my SuperSilent Freezer 64 Pro. Right now I have a stock cooler on my AMD 64 (3000+). So, after I have disconnected all power from system, grounded myself using ESD protective gear and dismounted the old heatsink what do I do?
I've read that I can use "rubbing alcohol" to remove the leftovers from the thermal pad. I don't know what this "rubbing alcohol" contains , so here is what I have:
Something called "T-Röd" (T-Red). It contains Denaturated Etanol and some "color" [it's red].
However it can catch fire already at +11C.. So perhaps it isn't the best to use?
Also I have thinner for paint removal, perhaps that is a better option?
And now a question to them who actually own the SuperSilent Freezer 64 Pro:
It's said that it comes with thermal paste, but is it already applied or is it in a "tube"?
Do I need to modify the cooler itself in anyway to fit my socket 754?
Should I keep the system on for about 1 hour or so before removing old heatsink (maybe makes it easier to remove it)??
Thankful for any replies and advice given.
