Temps on First Build - Thoughts?
How Are my Temperatures?
  • Temps could use improvement - add more fans or re-adjust heatsink
    Votes: 0 0.0%
  • Total voters
    9
30 (0.01/day)
Hello,
So I just finished my first build ever and it's been running for a couple days now. I've been periodically checking the CPU temperature with Core Temp and the GPU temperature with GPU-Z. I know optimal temperatures will differ for every case, but I wanted to get the community's feedback including opinions on whether I should get additional case fans.
Here is the build:
PCPartPicker part list / Price breakdown by merchant
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($238.99 @ Newegg)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.50 @ Newegg)
Motherboard: Asus Z97-A/USB 3.1 ATX LGA1150 Motherboard ($152.00 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($62.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($97.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($49.19 @ Amazon)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card ($339.99 @ SuperBiiz)
Case: Fractal Design Define R5 w/Window (Titanium) ATX Mid Tower Case ($107.99 @ SuperBiiz)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($49.99 @ NCIX US)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($19.75 @ OutletPC)
Total: $1138.28
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-05-28 00:45 EDT-0400
The Fractal R5 comes with 2 140mm fans located at the back and front of the case. I used AS5 as my choice of thermal compound.
My ambient temperatures have tended to be between 22-23°C around this time. On idle, all of the cores float around 29-32°C and the GPU between 30-32°C. For load temps, I ran Prime95's Small FFT test for 15 minutes and after checking Core Temp all the cores were between 50-55°C. Not sure how to test GPU temps under load, but I can tell you that after playing the Witcher 3 the temps stay below 70°C.
One other note: While I was mounting the CPU cooler to the crossbar, one of the corners did not catch onto the screw (It was positioned correctly above the screw, but the heatsink wasn't low enough on that corner to latch onto the corresponding crossbar screw). Consequently, and this was after I had already started screwing the opposite corner in, I had to gently press that corner down so it would lock into position and I could secure the screw. It took maybe about three light presses for it to finally stay latched for me to screw it in.
Do you think this will have or had any significant effect on my temperatures? If my temps already seem fine, I would rather not have to go through the trouble of opening my case again, unmounting the heatsink, cleaning up and reapplying the paste, etc.
702 (0.15/day)
Where the hand of man has never set foot
Processor AMD Ryzen 5 3600X
Motherboard ASUS TUF GAMING X570-PLUS
Cooling Noctua NH-D15 SE-AM4
Memory 2x8GB G.SKILL Ripjaws V DDR4-3200MHz CL16 1.35V
Video Card(s) MSI Radeon RX 6600 XT Gaming X 8G
Storage Crucial MX100 512GB + Samsung 870 EVO 2TB
Display(s) MSI Optix MAG24C
Power Supply Seasonic FOCUS GX-550
Mouse Razer Viper Ultimate
Keyboard Corsair K60
Your temps are fine.
Enjoy your build. :toast:
INSTG8R
Vanguard Beta Tester
7,966 (1.12/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
Seems fine to me. Enjoy!
12,280 (2.36/day)
Oregon
System Name Juliette // HTPC
Video Card(s) ASUS RTX4070 OC// GTX 1650
Mouse Cooler Master MM710 53G
You can go up to 80c safely on Haswell. 95c if you got balls
Just run Heaven Benchmark for the GPU temps
peche
Thermaltake fanboy
6,709 (1.94/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
enjoy that beast playing as much as you can, personally I don’t trust benchmarks and crappy tests, so want to test you machine? play a while, then check temps, every time I play check temps…. after and before,
Your temps are pretty fine, don’t worry and enjoy again!
rtwjunkie
PC Gaming Enthusiast
13,909 (2.42/day)
System Name Bayou Phantom
Power Supply Seasonic X-850
Excellent temps all around!!
With that case, if temps end up rising, you can add another fan up fron and one in the bottom for intake, without raising noise. Probably I would go for the bottom intake first, as it sends fresh air straight to the gpu.
Also, you have two more exhausts up top. You could add an exhaust fan up there for only a moderate increase in noise. The Fractal R2 140mm fans that come with it are among the highest airflow fans that are basically pretty quiet.
unclewebb
7,347 (1.26/day)
No balls needed. Intel says that as long as your CPU is not thermal throttling, it is operating at a safe temperature. Thermal throttling does not start until a peak core temperature of 100°C in the 4690K so no worries.
30 (0.01/day)
Thanks for all the feedback everyone! I"ll hold off on adding extra case fans until I start overclocking. Is there any reason or particular way I should be stress testing my GPU temps?
peche
Thermaltake fanboy
6,709 (1.94/day)
System Name Athenna
test stability... prevent crashes and errors...
i preffer testing my craps and works with games... i hate benchs...
