The Final Coutdown. Need help lots of help with RAID and OC'ing
3,405 (0.62/day)
Brunswick, GA
System Name Haz0
Processor i7-2700K
Motherboard Gigabyte Z68X-UD3H-B3
Cooling Chicken Stock
Memory 16GB G.Skill Ripshits X 1600MHz
Video Card(s) Sapphire 5850
Storage Kingston 128GB SSD + WD Black 640GB + 2x 1.5TB
Display(s) 24" Acer G245HQ + 19" Lenovo L194
Case Antec NSK-4482 Orangified
Audio Device(s) X-Fi XtremeGamer
Power Supply Corsair TX750W
Software Windows 7: Electric Boogaloo
My C2D E8400, HIS HD 4870, and second WD Black 640GB hard drive will be arriving at my doorstep sometime tomorrow. At that time, I will install the HDD, put all the junk on the mobo, mount the mobo, connect up all mah cables (already have psu cable management done) and hopefully post. I think I know everything I need to know except on a few topics. RAID, my OS, and overclocking.
RAID 0 Config
I'll be putting the two 640GB drives into a RAID 0 configuration. I have a Gigabyte GA-EP45-UD3P which has the Intel P45 and ICH10R bridges and is RAID 0/1/5/10 compatible. If I understand correctly, for anything older than Vista, you have to have the RAID drivers on a floppy disk, and with Vista and Win7 you can use a flash drive.
-Where could I find these drivers? (link?)
-How do I go about setting up the drives and how/when do I insert the drivers?
-Will the drivers need to be in a certain format so the setup process can use them?
Also, if I use Win7 as my main OS and get them from a flash drive, and want to put XP on a separate partition, then will I again have to go through the trouble of acquiring a floppy drive?
Overclocking
I know there are TONS of help sites and tuts all about OC'ing your CPU and whatever. My question is, could I just take the info (modified FSB speed, multiplier, voltage, etc.) from someone else who has components like mine and use those values without any trial and error? So like, if JohhnyQ has an E8400, 4870, and stuff like my stuff, and has a stable OC at 3.5GHz, could I just take the values that Johnny is using and use them for mine? I know, since the stuff I have is probably different than anyone else's, that the voltage may be different or something, but I don't know.
Operating System
I was planning on getting the latest RC of Win7 and burning it to a disk using PowerISO, and making a 40GB or so partiton for XP.
4,267 (0.70/day)
Sanford, FL, USA
Processor Intel i5-6600
Motherboard ASRock H170M-ITX
Cooling Cooler Master Geminii S524
Memory G.Skill DDR4-2133 16GB (8GB x 2)
Video Card(s) Gigabyte R9-380X 4GB
Storage Samsung 950 EVO 250GB (mSATA)
Display(s) LG 29UM69G-B 2560x1080 IPS
Case Lian Li PC-Q25
Power Supply Seasonic SS-460FL2
Mouse Logitech G700s
Keyboard Logitech G110
It's even easier than that - Vista/Win7 already has ICH drivers, so the array will be recognised during installation. Then afterwards you can install the Matrix Storage Manager from here: http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2101
As for Windows XP, I use nLite to integrate drivers into the install CD (I haven't had a floppy in over 9 years).
1,043 (0.15/day)
USA
For windows XP, you can get the drivers from the intel web site. Vista / win7 has the drivers already. During setup, windows XP asks you to press a button if you have sata/raid drivers. That's when you insert your floppy or whatever to get them
3,405 (0.62/day)
Brunswick, GA
System Name Haz0
Processor i7-2700K
Bump for glory. The stuff should be here any minute.
4,213 (0.74/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
some overclocking settings for you. try 1.3v and 450fsb, move up from there
Binge
Overclocking Surrealism
6,979 (1.22/day)
PA, USA
System Name Molly
Processor i5 3570K
Motherboard Z77 ASRock
Cooling CooliT Eco
Memory 2x4GB Mushkin Redline Ridgebacks
Video Card(s) Gigabyte GTX 680
Case Coolermaster CM690 II Advanced
Power Supply Corsair HX-1000
Broad span of topics... two of the three aren't hard to find info on.
RAID 0 Config
Does your UD3P's manual say anything about setting up RAID? All of your raid drivers will be available on the install CD or from Gig's website.
Overclocking
No no no no NO NO NO NO... NO!!!! There are tons of help sites and tutorials about overclocking cpus or whatever and NONE of them even hint that your components will behave the same as JohhnyQ. I suggest you start reading these "tons" of reputible guides before you come back with a bios corruption, HDD failure, component failure, or something similar.
Operating System
Is this a question or statement? I know every time I boot into W7 I remember how much I want to break my old vista disks. Why would you foul up a perfectly HDD with old crap? Compatability? Are you tryin to run 4870s and a 8800 for physX? PhysX cards are really cheap and would save you the hassle.
Don't hesitate to ask more questions :D
