Thermaltake WATER2.0 Performer Review
brandonwh64
19,542 (3.65/day)
By: Brandon Harrison (Brandonwh64)
Though Thermaltake is no stranger to water cooling products, this is one of the first lines of closed loop liquid cooling systems. With the release of this series of closed loop coolers, Thermaltake has strived to bring large improvements to the hassle free liquid cooling solution. In this review we will be doing visual inspections as well as benchmarking to its competitor. Please feel free to ask any questions you may have on the product.
Unboxing
The box was well packaged and very protected with all of the components in their own individual packages. The whole package is tucked in an egg carton style cardboard container.
Specifications of the Thermaltake WATER2.0 Performer
the specifications of the Performer are similar to the Corsair H50. The radiators are identical in size. The pumps are not alike. The pump on the Performer is estimated ¾ inch in height while the H50 is estimated 2 ¾ inch in height.
Contents:
Back Plate (AMD “AM2/AM2+/AM3/AM3+”, Intel “775/1366/1156/1155/2011”)
Retention Rings (AMD “AM2/AM2+/AM3/AM3+”, Intel “775/1366/1156/1155/2011”)
Mylar
Grommet x4
Screws (Fan mounting) x8
Plastic Components Top x4 (AMD/Intel)
Plastic Components Bottom x4 (AMD/Intel)
Screws (CPU Block Mounting) x4 (775/1366/1156/1155/AMD)
Screws (CPU Block Mounting) x4 (2011)
Retention Clip
Washers x4
Fan Y Cable x1
120MM Fan x2
WATER2.0 Performer Unit
Installation:
The installation for this product has improved over their competitors previous versions. Installation of the back plate with the mylar strips to hold the back plate securely to the motherboard. The grommet inserts must be inserted for specific socket of the board. The plastic components must be put together with the boards socket name facing out and the proper socket screws inserted into the plastic clips. Below is a picture of the CPU block with the retention bracket and clips installed.
Test Bed:
• Mainboard: Gigabyte P67A-UD4;
• Processor: Intel Core i7-2600K, (Stock - 3.4 GHz Stock Voltage),(OCed - 4.5 GHz 1.33V);
• Thermal interface: Arctic Silver Ceramique;
• Memory: DDR3 1333Mhz 2 x 2 GB Corsair XMS3Dual Channel (Spec: 1333MHz / 9-9-9-24 / 1.5 V);
• Power supply: Corsair TX550M;
Testing:
In this review I will be comparing the Thermaltake’s WATER2.0 Performer to the Corsair H50 which share the same characteristics and are closed loop water systems. The Corsair H50 is one of the older style coolers and this test will prove that the newer designed WATER2.0 Performer can outperform the older technology.
Corsair H50 Stock:
Corsair H50 OCed @ 4.5ghz 1.33V:
Results:
Stock: 53 Degree Celsius
Oced: 70 Degree Celsius
Thermaltake WATER2.0 Performer Stock:
Thermaltake WATER2.0 Performer OCed:
Results:
Stock: 46 Degree Celsius
OCed: 57 Degree Celsius
Temperature Differences:
Stock: 7 Degree Celsius
OCed: 13 Degree Celsius
Great numbers!
Value and Conclusion
*The Thermaltake WATER2.0 Performer has an MSRP $69.99*
Good
• Packaged very well with protective cardboard shell
• Very clean and well built
• Rubber tubes instead of metal coiled tubes of the H50
• Excellent performance!
• Easy installation
• Supports AMD and Intel along with the new socket 2011
• Hassle free liquid cooling!
Bad
• Requires a 120mm fan port inside case to install
• Motherboard requires removal to install
• Loop cannot be extended to other components like the GPU
Thermaltake has done a phenomenal job with this unit! It has many improvements over previous generations of closed loop liquid coolers. The fans that are included with this cooler move air greatly through the radiator and are very quiet. While not performing in the same range of custom built high-end water cooling, the Thermaltake 2.0 Performer is great for the typical overclocker. This cooler has provided significant cooling for the typical gamer or moderate overclocking enthusiast. Thermaltake’s sleek design of the CPU block and quiet fans has provided a simple cooling system that can be installed and does not require much maintenance. Basically, if you are looking for the cheapest water cooling solution for your CPU or simply want a great cooler for your CPU in the Thermaltake’s price range, you shouldn’t have to think twice.
3,881 (0.88/day)
Nice:rockout:
Thermaltake Water 2.0, Antec 620/920-e (currently only sold in Asia) and Zalman new line being shown at Computex. Will all be carrying Aseteks new 3rd gen setups which are suppose to have improved silent pumps and better pressure from what i've been reading. Each will also be including quieter fans then before aswell so thats always nice.
3,051 (0.65/day)
System Name The SwagMachine / The Sister
Processor Core i5 3570K @5.2ghz 1.3V/ 1100T
Motherboard ASUS P8Z77-V / ASUS M5A99X EVO
Cooling Phanteks PH TC14PE / Corsair H40
Memory M379B5273DH0-YK0 2X4GB + PVI316G213C1QK 2X4GB / 2x4GB Patriot 2133
Video Card(s) PNY 780Ti /Windforce 7950
Storage 2xSamsung 840 EVO 250gb+WD10EZEX + WD30EZRX/ 1x WD1500 Black
Display(s) AOC Q2963PM+Acer S200HL / Acer S200L+ LG 22LD350
Case Fractal Define R4 / NZXT Trinity
Audio Device(s) Asus Xonar DG / Asus Xonar DG
Power Supply Seasonic 750X / ROSEWILL RG630-S12 630W R
Mouse Razer Deathadder Chroma / Roccat Kone+
Keyboard Razer Blackwidow 2013 Stealth / Roccat Isku
Software Windows 8.1 Pro / Windows 7 Ultimate
Benchmark Scores one time I scored a 3 on 3dmark 11
10/10 would read again.
P.S. I like how you can see the RAD, and CPU block in this picture.
brandonwh64
19,542 (3.65/day)
Yes the current case for that 2600K is an older P4 server tower but I have another one in the works but I wanted to mount it using rad mounts to one of the strut bars so people can see it better in the review.
*edit*
I am glad that you guys are enjoying the read. A fellow over at xtremesystems is saying my test setup is a joke and the cooler is practically not good enough to be reviewed. I think it is a great product to be honest.
http://www.xtremesystems.org/forums...rformer-Review&p=5104838&posted=1#post5104838
cadaveca
My name is Dave
17,232 (2.61/day)
*edit*
LuLz, he's a cork-sniffer. But when the Big Typhoon was the top air-cooler, he was running one too.:roll:
JrRacinFan
Served 5k and counting ...
20,073 (3.21/day)
Youngstown, OH
System Name Dual Build Streamer
Processor Ryzen 7900x3d : Ryzen 4600G
Motherboard AsRock B650E Steel Legend : Giga B450i Aorus
Cooling Custom Water 1x420 : Stock
Memory 32GB T-Force Deltas : 16GB Dominator Platinums
Video Card(s) PowerColor 7900 XTX Liquid Devil: iGPU
Storage 20+ TB
Display(s) Sammy 49" 5k Ultrawide
Case Custom White Painted Phanteks Enthoo Pro 2
Audio Device(s) Onboard : Onboard
Power Supply EVGA 1200W P2
Mouse Corsair M65 RGB Elite White
Keyboard Hyperx Origins 65
LMAO @ Dave.
@B
Looking very nice man. What's going to be the MSRP for one of these? I need to learn how to read rather than quickly skim over review.
brandonwh64
19,542 (3.65/day)
LMAO @ Dave.
@B
HAHAHA its ok Jr! Thanks for the support
861 (0.17/day)
System Name FragBox
Processor Intel Core i7 2600K @ 5.0GHz/1.45 volts
Motherboard Asus P8Z77 WS
Cooling Custom CPU loop
Memory Kingston 12GB DDR3 1600
Video Card(s) Galaxy GTX 680/Zotac GTX 680 in SLi/EVGA GTX 650Ti
Storage 2 Vertex 3 120's, raid 0, 2 Seagate Momentus XT 500GB's in raid 0, 1 Hitatchi 2TB for backup
Display(s) 3 Acer S232HLX2 in nvidia surround
Case Corsair C70 White
Power Supply Corsair AX1200
Software Win 7 x64 Pro
The only thing that's missing from the temps is delta over room temperature.
Good job otherwise!
Norton
Moderator - Returning from the Darkness
14,108 (3.12/day)
Northeast USA
System Name Main PC- Gamer- Main Cruncher/Folder and too many crunching/folding rigs
Processor Ryzen 5900X- Ryzen 5950X- Ryzen 3950X and etc...
Motherboard Asrock X570 Extreme4- MSI X570S Tomahawk MAX WiFi- MSI B450M Bazooka Max and etc...
Cooling Noctua NH-U14S (dual fan)- EK 360 AIO with push/pull fans- Corsair H115i RGB Pro XT and etc...
Memory 2x16GB GSkill FlareX 3200/c14- 4x8GB Corsair Vengeance 3600/c16- 2x16GB Team 3600/c18 and etc..
Video Card(s) MSI Gaming RX 6800- Asus RTX 3070 TUF OC- MSI Ventus GTX 1660Ti and etc...
Storage Main PC (1TB WD SN850- 2TB PNY CS 3040- 2TB Seagate Firecuda) and etc...
Display(s) Main PC (2x24" Dell UltraSharp U2414H)
Case Phanteks P600s- Seasonic Q704- Fractal Meshify C and etc...
Audio Device(s) Logitech Z625 THX 2.1 speakers
Power Supply EVGA 750 G3- SeaSonic DGC 750- EVGA P2 850 and etc...
Mouse G300s
Keyboard Corsair K65
VR HMD N/A
Software Windows 10 Pro or Ubuntu
Benchmark Scores Why sit on the Bench when you can get in the game and Crunch!!!
Great review brandon- very well done!!!:toast:
I don't know wtf the guy in the other forum had an issue with? :wtf::shadedshu
Now is the time to see if XNine will let you review the quality of NZXT's refurbished M59 cases :rolleyes:
TheMailMan78
Big Member
22,599 (3.66/day)
'Merica. The Great SOUTH!
Ive seen better reviews written on a bathroom wall.
lol J/k Great job man!
FreedomEclipse
~Technological Technocrat~
23,398 (3.76/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
@TT
- bitch plz, Its clearly an Antec/asetek 620/920 despite TT making it themselves.
brandonwh64
19,542 (3.65/day)
@TT
Maybe the TT rep can come in and answer that comment. I have not used the newer antec/asetek coolers but from pictures they do look similar.
FreedomEclipse
23,398 (3.76/day)
London,UK
Mouse Logitech G900
He already has in his support thread. They make these coolers inhouse instead of going to Astek like quite a few other companies already have.
the design looks very similar to Antec's from the same retention clip system to the waterblock and the tubing they used which is said to reduce kinking.
If you still have the cooler, any chance of doing some testing with some Scythe GTs in Push Pull configuration?
brandonwh64
19,542 (3.65/day)
If I had some scythe GTs I would surely test them for you :)
10,881 (1.62/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Awsome work... :toast: looks like a consistent and fair performance evaluation. Simple and well written, results are surprising.
Be great to see some high-end air coolers compared vs. water too, hope you do some more with this.
brandonwh64
19,542 (3.65/day)
Awsome work... :toast: looks like a consistent and fair performance evaluation. Simple and well written.
Be awesome to see some high-end air coolers, hop you do some more with this.
Me too! I was so thrilled to be able to do this review! I hope there are more to come.
10,881 (1.62/day)
Manchester, NH
System Name Senile
Case Rosewill
Mouse Logitech G5
Software Win 10
I dig comparative testing, it's like opening a box of chocolates :laugh:
One suggestion, document the ambient (room) temps for every run.
95Viper
Super Moderator
12,710 (2.24/day)
Nice review.:toast:
However, (yes, there is a however) and it is just my opinion.
What is it with the BOLD, LARGE TYPE FONTS, especially in the title and author; it makes my lazy a** scroll more.
Makes it seem the article is as much about you as the cooler.
brandonwh64
19,542 (3.65/day)
Nice review.:toast:
What is it with the BOLD, LARGE TYPE FONTS, especially in the title and author and makes my lazy a** scroll more.
The reason is that with the normal font, it seems harder to read than with a one step up font.
