USB 3.0 Promoter Group Announces Availability of USB Power Delivery Specification
46,392 (7.67/day)
The USB 3.0 Promoter Group, in conjunction with the USB 2.0 Promoter Group, today announced the completion of the USB Power Delivery specification, which enables increased power delivery through USB cables and connectors. The specification expands cable bus power capabilities in USB applications, supplying higher voltage and current to deliver power up to 100 watts over USB Power Delivery certified cables. It is capable of delivering higher power to charge notebook PCs and power external hard-disk drives, devices which previously did not receive adequate power from traditional 5V bus power.
The USB Power Delivery specification enables a switchable source of power without changing cable direction. Existing USB cables and connectors are also compatible with this specification and will coexist with the USB Battery Charging 1.2 specification as well as existing USB-bus powered applications.
"USB Power Delivery enables a path to greatly reduce electronic waste by eliminating proprietary, platform-specific chargers," said Brad Saunders, USB 3.0 Promoter Group Chairman. "We envision a significant move toward universal charging based on this specification, most notably for charging notebook PCs using standardized USB power bricks or when connected to USB hubs and desktop displays that integrate USB Power Delivery capabilities."
"The publication of the USB Power Delivery specification is an important step in enabling a flexible, standardized power management ecosystem," said Peter Harrison, Director, Standards Collaboration, Nokia.
"We believe USB Power Delivery is the next big step in the USB evolution to provide high bandwidth data and intelligent power over a simple, single, ubiquitous cable," said Robert Hollingsworth, Senior Vice President and General Manager of the USB Products Group at SMSC. "USB has always combined data and power over a single cable, and this is widely believed to be a major contributor to the present ubiquity of USB. USB Power Delivery builds on that success and adds full bi-directional power that can be renegotiated as system power needs change with the end-user."
The USB 2.0 and 3.0 Promoter Groups developed the USB Power Delivery specification and have transitioned the specification's management to the USB-IF. The USB Promoter Groups are now accepting adopters of the USB Power Delivery specification. To download both the USB Power Delivery specification and adopter agreements, visit this page.
4,113 (0.71/day)
Iowa, USA
System Name THE CUBE 2.0
Processor Intel i5 13600k
Motherboard MSI MPG Z690 EDGE DDR4
Cooling Phanteks PH-TC14PE BK 2x T30-120 Fan mod mount
Memory G.Skill TridentZ 3200 MT/s C15 32GB 2x16GB
Video Card(s) Gigabyte Aorus 1080 Ti 11GB OC: Core 2GHz, Mem 5.7GHz
Storage WD SN770 250GB / 3x WD SN850X 2TB / Toshiba X300 4TB / 2x RAID1 Toshiba P300 3TB
Display(s) Samsung 49" Odyssey OLED G95SC 240Hz 5120 x 1440
Audio Device(s) Beyerdynamic DT 880
Power Supply Corsair RM1000X
Mouse Logitech G700
Keyboard Logitech G910
46,392 (7.67/day)
531 (0.11/day)
Inside a mini ITX
System Name ITX Desktop
Processor Core i7 9700K
Motherboard Gigabyte Aorus Pro WiFi Z390
Cooling Arctic esports 34 duo.
Memory Corsair Vengeance LPX 16GB 3000MHz
Video Card(s) Gigabyte GeForce RTX 2070 Gaming OC White PRO
Storage Samsung 970 EVO Plus | Intel SSD 660p
Case NZXT H200
Power Supply Corsair CX Series 750 Watt
It really is 100W. You can charge a laptop with that power.
Transferring 100W at 5V requires 20A current:eek:. How many lines are they using ?
145 (0.02/day)
System Name Little Bear
Processor Inten 3770K @4.4Ghz 1.2v
Motherboard ASRock Extreme4-M
Cooling Thermalright Macho120 Rev.A
Memory 4x4GB Samsung LP DDR3 @ 1866MHz 9-9-9-28
Video Card(s) Radeon R9 290
Storage 256GB Samsung SSD 830 + 1TB SSD 840 EVO + 2.5in 1TB Hitachi
Display(s) Dell U2711
Case Silverstong SG10
Audio Device(s) USB SB Omni
Power Supply Enermax Modu 82+ 620w
Software Windows 8.1 x64
it won't be at 5V it'll probably be something like 30V
3,881 (0.89/day)
Given the USB 3.0 can be second hottest thing on a motherboard besides the CPU. I'd hate to see it when they add more current through it. Its gonna require its own Heatsink and fan to keep heat down.
10,881 (1.62/day)
Manchester, NH
System Name Senile
Case Rosewill
Power Supply Corsair HX750
Mouse Logitech G5
Software Win 10
Reading through the spec, it appears both voltage and current are variable.
145 (0.02/day)
Agreed. I also went diving into the spec sheet and drew a few conclusions. The new 'PD' connectors proposed are designed to handle 5A for full size connectors (A, B) and 3A for Mini/Micro.
That would necessitate 20V to deliver 100W at 5A.
9,899 (1.77/day)
Essex, England
System Name My pc
Processor Ryzen 5 3600
Motherboard Asus Rog b450-f
Cooling Cooler master 120mm aio
Memory 16gb ddr4 3200mhz
Video Card(s) MSI Ventus 3x 3070
Storage 2tb intel nvme and 2tb generic ssd
Display(s) Generic dell 1080p overclocked to 75hz
Case Phanteks enthoo
Power Supply 650w of borderline fire hazard
Mouse Some wierd Chinese vertical mouse
Keyboard Generic mechanical keyboard
Software Windows ten
External video cards for laptops that won't be obscenely expensive you say!?
iO
526 (0.12/day)
Germany
Processor R7 5700x
Motherboard MSI B450i Gaming
Cooling Accelero Mono CPU Edition
Memory 16 GB VLP
Video Card(s) AMD RX 6700 XT
Storage P34A80 512GB
Display(s) LG 27UM67 UHD
Case none
Power Supply SS G-650
POW!
In your face Thunderbolt!
5,379 (1.03/day)
Gougeland (NZ)
System Name Cumquat 2021
BUT who the hell charges their Laptop/net/notebook from their desktop pft no one I know the only thing I charge from mine is my cell phone
6,687 (1.43/day)
Processor 7800x3d
Cooling Custom Water
Case ThermalTake P3
Software Windows 11 64 Bit
No need too. These are popping up a lot now in newer homes. You can even install your own.
1,166 (0.19/day)
Hampton Roads
Processor Xeon x5650
Motherboard SABERTOOTH X58
Cooling Fans
Memory 24 GB Kingston HyperX 1600
Video Card(s) GTX 1060 3GB
Storage small ssd
Display(s) Dell 2001F, BenQ short throw
Case Lian Li
Power Supply X750
Software Mint 19.3, Win 10
Benchmark Scores not so fast...
The way I see it, no one can charge a laptop from a desktop now.
I've said it before, this will work for printers, hubs, routers, modems...
6,687 (1.43/day)
Processor 7800x3d
Case ThermalTake P3
Mussels
Freshwater Moderator
58,413 (8.18/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
printers are the only ones in that list that need more than USB 2.0 can deliver.
yet-another-account
1 (0.00/day)
IT industry admits 12-year power brick rip-off
Once again proving that humanity is doomed, the clowns who manage the USB standard today announced that they could have allowed the USB standard to prevent the endless plethora of non-interoperable power-bricks constantly going to landfill throughout the last 12 years.
USB promoters defended their refusal to provide meaningful power through USB2 when released at the turn of the century with the feeble excuse that every other standard in IT was - and is - released with built-in-obsolescence. "Why should we have done the human race an environmental and economical favour when nobody else was doing so?" said chief USB promoter Dick Gutless. "The decision was made with broad industry consensus", he claimed. "Silicon Valley shareholders would have caused a riot if we didn't ensure that royalties would continue to flow in for their companies when we periodically 'found' new features for the standard." He stated. "As for the landfill and socio-economic implications of our decision, well it's not as if green principles were all that common at the time. Greenpeace was only formed 25 years before we came up with the USB standard. The UN was only formed 50 years beforehand. Socio-economic concepts were just the last things on our minds. We had not had time to educate ourselves about these concepts. Nonetheless I still believe we were the greatest minds available at the time to work on the USB concept." Mr Gutless re-iterated that there was nothing the USB promoters could do about their failures other than to learn from the mistakes and improve the standard in the future. "Someone suggested we should charge a green tax on the standard to help fund a clean up of all old power bricks in the world. We considered that idea thoroughly but felt such a policy would show the sort of forward-thinking responsibility we couldn't justify to our investors."
6,687 (1.43/day)
Processor 7800x3d
Case ThermalTake P3
I'm pretty fond of usb, this is a good step forward. Glad they finally got around to adding this feature to usb.
INSTG8R
Vanguard Beta Tester
7,966 (1.12/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 2
Software Win 10 Pro x64
Welcome TPU :toast:
Thank you for your rant...:wtf:
1,166 (0.19/day)
Hampton Roads
Cooling Fans
Storage small ssd
Case Lian Li
Power Supply X750
raspberryssels;2679750]printers are the only ones in that list that need more than USB 2.0 can deliver.[/QUOTE]
USB 2.0 is 5 volt. USB 3.0 is any volt up to 30, and higher power.
My router and modem are 12 volt so USB 2.0 wouldn't work.
