very strange problem - slight electric shock from USB ports?
speedy11131
120 (0.02/day)
New York City, USA
Processor Phenom II X4 965 Black Edition
Motherboard Gigabyte GA-M68MT-SP2
Video Card(s) EVGA GeForce GTX 580 1.5GB
Storage Crucial RealSSD C300 128GB SSD, Western Digital Caviar Black 1.5TB
Display(s) JVC 32"
Power Supply RP-550
Software Windows 7 Ultimate
I have a laptop that for some reason sends a small shock current when I either touch the port by accident, or touch the connectors on a cable or anything connected to it at the time (for example, ipod cable connected to USB port will shock me if i touch the ipod)
And it's not even a shock, it feels more like the current is running through to my fingers, a sort of tingling feeling.
It's very odd because it never did this before. Is this some sort of electric isolation problem? Is it something I can fix or have to send to repair somewhere?
It's a very small shock, I'm assuming because USB is only rated at 5V?
It is an HP laptop, don't have the model number off the top of my head.
pbmaster
2,588 (0.40/day)
Savannah, GA
Processor AMD Phenom II 955
Motherboard Asus Crosshair III Formula
Cooling Cooler Master V8 CPU cooler, 120 mm and 200 mm exhaust, 3 x 120 mm intake
Memory 4 GB OCZ DDR3 1600
Video Card(s) Sapphire Radeon HD 4890
Storage Western Digital 500 GB Blacks in RAID 0/ Wesdtern Digital SE16 250 GB
Display(s) Acer 19" widescreen
Case Antec Nine Hundred
Audio Device(s) Supreme X-Fi
Power Supply Seasonic M12 SS-700HM
Software Windows Vista Home Premium x64 SP2
Benchmark Scores 3dMark 03-~62k 3dMark 05-~22k 3dMark 06-18268
Sounds like a very important piece of hardware is going to get shorted out soon.
BUCK NASTY
4P Enthusiust
4,974 (0.81/day)
Port St Lucie, FL. U.S.A.
System Name Main Rig
Processor AMD FX-4130 @ 4.8Ghz
Motherboard ASUS M5A99X Evo
Cooling Coolermaster Hyper 212+
Memory 8GB GSkill DDR3 1600
Video Card(s) ASUS GTX 970 Strix @ 1503Mhz Core
Storage Corsair Force 90gb SSD/ WD Caviar Blue 750gb
Display(s) ASUS 24" IPS
Case Coolermaster Centurion 590
Power Supply Antec TP750 80+
Software Windows 7 Ultimate 64
If you can feel it, it's more than 5v.
Solaris17
Super Dainty Moderator
25,937 (3.79/day)
Alabama
System Name Rocinante
Processor I9 14900KS
Motherboard MSI MPG Z790I Edge WiFi Gaming
Cooling be quiet! Pure Loop 240mm
Memory 64GB Gskill Trident Z5 DDR5 6000 @6400
Storage 1x 500GB 980 Pro | 1x 1TB 980 Pro | 1x 8TB Corsair MP400
Display(s) Philips Evnia 49M2C8900
Case LANCOOL 205M MESH Snow
Audio Device(s) Moondrop S8's on Schiit Hel 2e
Power Supply ASUS ROG Loki SFX-L 1000W
Keyboard Monsgeek M3 Lavender, Akko Crystal Blues
VR HMD Quest 3
time for a rebuild if its in warrentee get it sent back if its not rebuild it then try the store if it doesnt work.
1,539 (0.28/day)
Canada/Québec/Montreal
System Name Main PC
Processor PII 925 x4 @3.724GHz (266x14) 1.525v NB 2660 1.425v
Motherboard Gigabyte AM3 GA-890XA-UD3 (790x+SB850)
Cooling Scythe Mugen 2 rev.B
Memory Hyperx 8GB (2x4) 1600@1418 8-7-7-20-27-1t
Video Card(s) GTX 680
Storage 256GB SSD / 2TB HDD
Display(s) LCD Samsung 24" 16:9
Case Cooler Master HAF 912
Audio Device(s) On-Board HD
Power Supply CM 750w GX |3.3v@25a|5v@25a|12v@60a
Software Kubuntu dual boot /Windows 7 Ultimate 64bit
Benchmark Scores later...
Got any carpet on the floor at your feet or near the computer?
DirectorC
1,624 (0.31/day)
Florizy
System Name -= Son of a Whore =-
Processor E8400 @ 4.0GHz (445 x 9)
Motherboard Gigabyte GA-EP45-UD3R
Memory 3GB Corsair XMS2
Video Card(s) EVGA 8800 GT 512
Storage 74GB Raptor + Caviars in RAID0
Display(s) I-Inc 19" LCD 1440x900
Audio Device(s) Audigy SE & Logitech X-540
Power Supply Corsair 750TX
Software Win32 v6.1.7600
Benchmark Scores Logitech KB & Sidewinder X3
I think laptops are suffering from awful build quality problems. My nephew tried to plug the end of a plug from a headset into a USB port in my sister's laptop and the laptop shut down and it no longer works with the battery, she has to have it plugged into the wall. That makes absolutely no sense whatsoever, it was just a headset plug that touched the metal of a USB port, WTF.
Fourstaff
10,042 (1.90/day)
Home
Processor 3570K // 10400F
Cooling Stock // Stock
The last time I had electric shock from my hardware, the PSU died, taking quite a lot with it. I think it is time to try to get HP to honor their warranty (not that they will)
6,207 (1.12/day)
Midlands,UK
System Name Ultraman
Case Alienware X16
the only laptop manufacture that has the worst and poorest build quality is ACER,you should NEVER buy an ACER even it is cheapest laptop out there and their customer service is terrible.
Well anyways is that laptop an ACER by any chance??
3,628 (0.62/day)
System Name Ultra 64
Processor NEC VR4300 (MIPS R4300i)
Motherboard proprietary design
Cooling Fanless aircooled
Memory 4.5MB 250 MHz RDRAM
Video Card(s) 62.5 MHz Reality Coprocessor
Storage 32 - 512 Mbit ROM Cartridge
Display(s) 720x576
Case Clear Blue Funtastic
Audio Device(s) 16-bit CD quality
Power Supply proprietary design
Mouse N64 mouse for use with N64DD
Keyboard N64 keyboard for use with N64DD
Fourstaff
10,042 (1.90/day)
Home
Its HP according to first post. HP is not much better the way they handled the dead gfx card problem.
Edit: Ste beat me
6,207 (1.12/day)
Midlands,UK
Case Alienware X16
ah i see,well i guess most laptops have issues these days,but hey HP customer service is indeed better than ACER. :D
Mussels
Freshwater Moderator
58,413 (8.16/day)
Oystralia
Case Fractal Design R6
Benchmark Scores Nyooom.
its not voltage that you feel, its the amperage - and USB gives just enough to feel without being able to cause harm.
the parts of the port accesible from the outside (that metal frame that surrounds it) SHOULD be earth/ground.
Its possible somethings up with the laptops power brick, or maybe with the mains power there - does the problem occur when running on battery only, with NO external devices connected? (no mice, no PCMCIA cards, no cardbus, no memory cards in the card reader, etc)
2,255 (0.38/day)
System Name HOMECOMPUTER
Processor Intel i9 - 9900k @ 5.1Ghz - 1.31v
Motherboard Asux ROG Maximus XI Hero Wifi
Cooling ek supremacy evo full nickle, 2xEK 360 Radiators, ek d5 pump/res combo, ek full cover 2080ti block
Memory 16GB DDR 3600 Trident Z RGB
Video Card(s) Gigabyte RTX 2080TI
Storage 1xWD black NVME 500GB, 1xSamsung 970 Evo Plus NVME 1TB
Display(s) 2 Dell Gaming 27" 1440P Gsync
Case Lian LI PC-011 Dynamic
Power Supply Evga P2 1200Watt
Mouse Zowie FK1+
Keyboard Corsair Strafe rgb silent
Benchmark Scores i'm working on that
you aren'tusing wone of those 3 pin to 2 pin power cord adaptors commonly found in old houses with dated electrical systems are you?? i have a few power outlets around he house and if i use the adapator and plug a 3 pin item in i can feel the shock easily.
speedy11131
120 (0.02/day)
New York City, USA
Display(s) JVC 32"
Power Supply RP-550
The model number is Pavillion dv9000
EDIT: just unplugged from power outlet and let run off the battery, don't feel the shock anymore.
@RaXxaa@
473 (0.09/day)
Pakistan & US
System Name ROG
Processor AMD PhenomII X6 1090T 3.2-4.0 GHZ
Motherboard Crosshair IV Formula
Cooling Thermaltake Frio
Memory OCZ Gold 1333 4GB
Video Card(s) XFX Radeon HD 5850
Storage 1000GB SeaGate Sata
Case Thermaltake V4
Audio Device(s) Built in
Power Supply OCZ Modextreme 700W
Software Win7 & Win2k8 server
Benchmark Scores Almost 20300 in 3D 06 6.9 IN Cinebench 11.5 CPU Score
i had a major problem like that once in my pc and still have it only when i plug monitor into my psu... and its a metal case so its really a bad current flowing through me until my monitor short circuited.... any how it looks like maybe your Power adapter is not grounded. not an expert but check your power adapter
Mussels
58,413 (8.16/day)
Oystralia
i had that as well from a CRT monitor with bad earthing (monitor died next time it zapped me, and blew me clean across the room) - its why i asked him to do an isolation test
2,753 (0.44/day)
louisiana
Processor Intel Core i7-4790 Haswell Quad-Core 3.6GHz LGA 1150 84W
Motherboard GIGABYTE GA-H87-D3H LGA 1150 Intel H87 HDMI
Cooling CPU - Cooler Master Hyper T4 / Case - cooler master 120mm rear case fan (Air cooling)
Memory 32GB (4 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
Video Card(s) GTX1060 6GB
Storage Samsung 512 GB 840 PRO SSD Main Drive and Samsung 512 GB 840 EVO SSD Backup Drive
Display(s) ASUS 23" LED Monitor
Case COOLER MASTER Centurion 5 (silver & black)
Audio Device(s) (onboard audio) Realtek ALC892
Power Supply CORSAIR SU-750TX 750W ATX12V / EPS12V
Software Windows 10 Home Premium 64bit Edition
you could have any number of issues, but its definately some sort of voltage going to ground (your case)
a HDD or motherboard is shorting to ground or your battery is leaking acid and the acidic oil is caused a path for it to short to ground but it also could be a simple pinched wire somewhere that just started touching metal.
its not good news no matter what it is so i cant offer you hope that its a cheap fix unless its in warranty
EDIT: just saw your edit, it could be the charging circuit in your laptop that is shorted since you didnt notice it on battery but then it could just be still there at a much lower voltage and your just not noticing it anymore because the AC voltage isnt giving it that extra kick
1,977 (0.31/day)
Fremont, Ohio
System Name The Darkside
Processor Ryzen 5 3600
Motherboard ASRock B550 Extreme4
Cooling OEM
Memory 16gb G.Skill Fortis
Video Card(s) MSI Seahawk 1070
Storage 500gb Mushkin Pilot NVMe
Display(s) 55" Samsung 4k UHD
Case Corsair iCue 465X RGB
Audio Device(s) Onboard Reltek
Power Supply Corsair AX860i
I agree with a grounding issue. If its not properly grounded, you WILL be the ground. Electricity is like water, flows to the path of least resistance. Except if you turn something electrical upside down, it wont go faster :p
Id say something is up with ur power brick
4,012 (0.75/day)
Sarasota, Florida, USA
System Name Awesomesauce 4.3 | Laptop (MSI GE72VR 6RF Apache Pro-023)
Processor Intel Core i7-5820K 4.16GHz 1.28v/3GHz 1.05v uncore | Intel Core i7-6700HQ @ 3.1GHz
Motherboard Gigabyte GA-X99-UD5 WiFi LGA2011-v3| Stock
Cooling Corsair H100i v2 w/ 2x EK Vardar F4-120ER + various 120/140mm case fans | Stock
Memory G.Skill RJ-4 16GB DDR4-2666 CL15 quad channel | 12GB DDR4-2133
Video Card(s) EVGA GTX 1080 Ti Hybrid SC2 11GB @ 2012/5151 boost | NVIDIA GTX 1060 6GB +200/+500 + Intel 530
Storage Samsung 840 EVO 500GB + Seagate 3TB 7200RPM + others | Kingston 256GB M.2 SATA + 1TB 7200RPM
Display(s) Acer G257HU 1440p 60Hz AH-IPS 4ms | 17.3" 1920*1080 60Hz wide angle TN notebook panel
Case Fractal Design Define XL R2 | MSI
Audio Device(s) Creative Sound Blaster Z | Realtek with quad stereo speakers and subwoofer
Power Supply Corsair HX850i Platinum | 19.5v 180w Delta brick
Software Windows 10 Pro x64 | Windows 10 Home x64
It is definitely an issue with your power adapter not having a proper ground. Numerous reports from Dell laptop owners with 2 pin power adapters reported being lightly shocked by the laptops if they were plugged into AC, and with a 2 prong power adapter. Dell rectified this by swapping the power bricks with 3 pin ones. Your problem is either you have a 2 prong power brick, or if you have a 3 prong adapter with a damaged ground wire, or the outlet you are plugged into is not properly earthed. Try a different outlet first.
@RaXxaa@
473 (0.09/day)
Pakistan & US
System Name ROG
Case Thermaltake V4
:roll:
P
Ptep
It still requires voltage to give you the amps, for example my bench DC powersupply will output 5v at 50Amps with you touching the outputs all day long and not feel much, because at 5v and an assumed resistance of 1.5KOhms (a fairly low resistance for a human, its usually about 100K or more, further reducing the amperage, you'd have to be soaking wet to achieve this low), the amps flowing would be 0.0033 or 3.3mA, at 100K (a more realistic resistance) you'd be looking at 0.05mA. The lowest perceivable amperage is 1.1mA. Assuming the user is not soaking wet whilst inserting his finger between the 5V usb power and the shield i think its safe to say its not that! :p
Its most likely lack of adequate grounding in the mains supply, cabling or a faulty power brick. As its an HP Pavilion its uses the standard 19V 3.42A HP PSU which are easily available on ebay and the like. It may well be worth buying a 3 pin earth socket tester (i assume you have them in US they arent too expensive, this is the sort of thing: http://www.hse.gov.uk/electricity/socket1.htm )
Laptop batteries do not contain acid, oils, or liquids for that matter. Most laptop batteries these days are lithium ion or lithium polymer. The only batteries that contain acid are lead acid batteries/Gel lead acid cells, which are used in cars/motorbikes/vans etc and other high current or long standby applications.
57 (0.01/day)
System Name Asus M50Vn
Processor Core 2 Duo P8600
Motherboard ASUSTeK M50Vn, Intel PM45, BIOS 212 (2009-10-14)
Memory 2x2 GiB DDR2 PC2-6400 Samsung
Video Card(s) GeForce 9650M GT
Storage 320 GB Hitachi
Software Win XP 32, Ubuntu 9.10 64, Fedora 12 64
Benchmark Scores 3DMark03: 13445 (SC) 15008 (OC) http://www.techpowerup.com/gpuz/v6b2f/ Fritz 9 Chess: 3091knps (6.
Haha, funny I happen to have a 4 year old laptop from Acer, and guess what it gave me electric shocks too (actually, rather slight electric burning feelings), from the keyboard (somewhere around the left CTRL to ALT keys). It still work great though (but I don't really use it a lot since I've got a more recent one now).
704 (0.10/day)
Chicago
System Name Woot
Processor AMD FX-9590
Motherboard ASUSTeK m5a99fxpro r2.0
Cooling Corsair H100i gtx
Memory 24GB G.SKILL PC3-12800
Video Card(s) MSI GTX 970GTX
Storage 2X 256GB SANDISK SSD 3X1TB MIXED HD
Display(s) 2x 32" Sony LCD
Case CoolerMaster Storm Trooper
Audio Device(s) 5.1 Surround Onboard
Power Supply Corsair 750W
Mouse Junk
Keyboard Junk
Benchmark Scores Anti-Gigabyte rig!
no way man. acer is the best. i have a aspire 3680, and it runs like a champ! better than 2 other toshiba satellites i bought a year ago
Vikramsingh
2 (0.00/day)
There should not be any voltage in between neutral and earthing point of the power supply plug. The voltage in between neutral and Line/phase can be 110V(Europe, USA) or 230V(India, UK etc). Now if the your earth and the neutral points are fine and inspite of this you are getting slight shock(approx.70 to 98 volts) then the device power card is faulty and needs replacement. This voltage leakage can be due to high humidity in the room where the printer is placed or finally the card is faulty.
2,326 (0.52/day)
System Name msdos
Processor 8086
Motherboard mainboard
Cooling passive
Memory 640KB + 384KB extended
Video Card(s) EGA
Storage 5.25"
Display(s) 80x25
Case plastic
Audio Device(s) modchip
Power Supply 45 watts
Mouse serial
Keyboard yes
Software disk commander
