water cooled? help
TcrackerX
4 (0.00/day)
Well I'm a n00b at cooling. But is watercooling worth it for your video card. I'm really interested becuase I feel like spending money lol. Anyways what do I need for this? People say from what I heard that buying a whole watercooled setup doesn't inprove much but its better to by it piece by piece. Can you guys tell me some good parts I can get and brands or something. I don't really care much about the processor because the fan on that is really quiet. Its my x1800 is so loud..
Thanks
666 (0.10/day)
England, UK
Processor AMD Athlon 3800+ X2
Motherboard ASUS A8N-SLI SE
Cooling 2 Exhaust fans
Memory 2x512MB DDR400 RAM
Video Card(s) Connect3D ATI Radeon X1900XT 512MB
Storage 80GB Maxtor DiamondMax
Display(s) Packard bell 17" CRT
Case Stock
Power Supply 580W Hiper Type-R
problem solved: http://www.thermaltake.com/product/Liguid/All-In-One/cl-w0052/cl-w0052.asp
just have to find a place that sells it near you, dont know if its and good tho, going to buy one about christmas time cant yet as have to save for bike :D
EDIT: they also do an upgraded one for SLI or Crossfire if you require it
EDIT 2: LOL only just noticed you guys did a review on this, any good?
W2hCYK
907 (0.13/day)
Processor Intel Core 2 Duo E6600 @ 3.3GHz
Motherboard P5WDG2-WS Pro, need new chipset cooler.
Cooling Dangerden TDX-775
Memory OCZ 2gb PC2-6400 DDR2 RAM 4-5-4-15
Video Card(s) X850XTPE 256mb @ 585/640
Storage 2x 250gb Perpendicular SATA3.0, 2x Maxtor DiamondMax10 160gb SATA-150 drives
Display(s) Sceptre 19" 8ms LCD
Case Lian-Li PC-65
Power Supply OCZ GameXStream 700w 18a 12v, Quad Rail
Software Windows XP SP2
I would get a single 120mm radiator and a semi-high flow pump, about 5ft of tubing (for just a video card, i'd do 3/8th", if you plan to add your cpu in, go with 1/2"), zip ties, reservoir, and a fair waterblock.. You should be fine with that.. should run you about $220~ if you get an expensive wb. $180~ on the lower side of the price scale..
dont do the thermaltake thing, i dont think that will handle the heat from the x1xxx series very well.. you'd be better off going with a seperate system.
**Heres a part list, $192~ @ xoxide.com.
