Water cooling advice
996 (0.15/day)
Kentucky
System Name Sony Vaio - VGNFW390-CTO
Processor Intel® Core™ 2 Duo Processor T9550 (2.66GHz)
Cooling Stock
Memory 4GB DDR2-SDRAM (DDR2-800, 2GBx2)
Video Card(s) ATI Mobility Radeon™ HD 3650 with 512MB vRAM (pitiful card)
Storage 320GB SATA Hard Disk Drive [7200 rpm]
Display(s) LCD 16.4" (XBRITE-FullHD™)
Audio Device(s) SupremeFX
Software Windows 7
So, I'm looking to buy a water cooling system for my computer. I upgraded from a stock heat sink but I'm still reaching temperatures of about 56 degrees celsius load which I would like to knock down. Anybody have any advice on which water cooling kit to buy? Oh, and I don't have a lot of money to throw around, so we're talking less than $100 for sure.
azz
4 (0.00/day)
For that kind of dollars your better of getting a decent fan heatsink........another thing is water cooling will only take u to just below the ambeint temperature of the case.
Bob The Fish
121 (0.02/day)
Edmonton Alberta Canada
System Name Neo2
Processor Intel Core i7 CPU 920
Motherboard ASUS X58 Sabertooth
Cooling Water cooled
Memory HyperX blu 8GB DDR3-1600MHz CL9 Dual Channel Kit (2 x 4GB) x 3
Video Card(s) ASUS Radeon HD 5850 1024m x2
Storage 1x 60g Corsair CSSD-F60GB2, 1 x 1000g WD Black 2x 500g SATA2, 1x 320g SATA2
Display(s) x3 HP 2210ms
Case Thermaltake Armor VA800BWS
Audio Device(s) PCI Express X-Fi Titanium Fatal1ty Champion Series on Z-5000 Digtal speakers
Power Supply Corsair Enthusiast Series TX850 V2
Software Windows 7 Pro x64
For water cooling in the $100 range i dont like your chances, Insted get the CNPS9500v from Zalman. I have a Big Water from thermltake and i like it, it was my first time with water cooling so i went with something simple. It cost me $250 cnd when i bought it and i just love it.
5,147 (0.77/day)
AZ
System Name Thought I'd be done with this by now
Processor i7 11700k 8/16
Motherboard MSI Z590 Pro Wifi
Cooling Be Quiet Dark Rock Pro 4, 9x aigo AR12
Memory 32GB GSkill TridentZ Neo DDR4-4000 CL18-22-22-42
Video Card(s) MSI Ventus 2x Geforce RTX 3070
Storage 1TB MX300 M.2 OS + Games, + cloud mostly
Display(s) Samsung 40" 4k (TV)
Case Lian Li PC-011 Dynamic EVO Black
Audio Device(s) onboard HD -> Yamaha 5.1
Power Supply EVGA 850 GQ
Mouse Logitech wireless
Keyboard same
VR HMD nah
Benchmark Scores no one cares anymore lols
the kingwin systems are nice, but not exactly the most powerful things, as for vs the zalman, it'll easily beat the zalman by up to 10C load but overall the most value per $ is found in a cheaper air cooler, good water isn't easy to come by at anything less than 250$
M
markkleb
You could do WC for $110 if you have some stuff at home.
I hate giving away all my good secrets but here is a very good system,
Pump ($27 for a Hydor)
http://www.marinedepot.com/md_viewItem.asp?idproduct=HD12202
CPU Block ($49 for Apogee)
http://www.svc.com/apogee.html
Rad ($29 Swiftech)
http://www.crazypc.com/products/9316BK.html
than all u need is a fan (you should have a extra 120mm fan) an a few feet of hose. Voila
For a really good budget cooling sys. Use this stuff and a AC cooler on ur Videocard. The Hydor uses 120V so it wont bother your PS in any way and you wont need extra wires.
996 (0.15/day)
Kentucky
Cooling Stock
Software Windows 7
That's pretty sweet. Would you mind sharing what kind of performance you get with your current CPU?
cHillen
91 (0.01/day)
Here and There
Naw dude CHEAPER you can use a car oil transmission cooler for like $20 . Go to you local petstore(what I did) and put my pump for $20 on sale. As for a water block watch out for acrylic made cheap. The acrylic might spider crack! For an example check out my case named: Leaky
