Rotary fittings eh? Will try on that one. Yea acrylic is getting wide now, but thats just it, looks over performance. I should balance both. How about coolants? I read some articles that you non-coloured is better than dyes one. Idk if I misunderstood the sentence but yea, better ask than nothing.
I went with this cooant. I like it and your talking maybe a few degrees if that with color and non color coolants. Most of the good ones yoiu will not even see any diff.
http://www.performance-pcs.com/cata...oduct_info&cPath=59_381_303&products_id=37159
Just ordered the lighting for my build..
5 x LED - Pre-wired with Connectors - 5mm - Red
- Connector Type: 2-Pin Connector
- Cable: Sleeve in your choice of colors
- Sleeve Color: Black
- Heatshrink Color: Black
2 x Akasa Vegas LED 60cm Light Strip - White
Also got this for the corners in the case and to help hid the seams.
Corner Guard, Black, 1x48in, Adhesive
http://www.amazon.com/dp/B007ICCXRG/?tag=tec06d-20
