water cooling parts
Discussion in 'Overclocking & Cooling' started by Maelstrom, Feb 18, 2009.
  1. Maelstrom
    Sep 10, 2008
    534 (0.21/day)
    159
    VA/PA
    Ok, so I've decided to do a small upgrade to my computer since my current w/c kit (swiftech H20 compact 220) cracked and killed both my gfx cards when it leaked. I plan on getting a q9650 to hold me over for a while before I go with core i7 or something. I wanted to watercool it, and wanted to check with you guys to see if part list is ok, and I have a few questions about a few things.
    CPU block
    http://www.frozencpu.com/products/7929/ex-blc-518/Swiftech_Apogee_GTZ_Universal_CPU_Waterblock.html?tl=g30c85s141
    Radiator
    http://www.frozencpu.com/products/7216/ex-rad-130/Feser_X-Changer_Dual_120mm_Xtreme_Performance_Radiator_-_Thermochill_Killers.html?tl=g30c95s160
    Pump
    http://www.frozencpu.com/products/2128/ex-pmp-27/Swiftech_MCP655-B_12v_Water_Pump_w_38_Conversion_Kit_317_GPH.html?tl=g30c107s155 with http://www.frozencpu.com/products/7832/ex-pmp-68/EK_D5_X-Top_Acetal_Pump_Top_-_Laing_D5_and_Swiftech_MCP-650655.html?tl=g30c107s156
    - Got the top add-on for flexibility of placement for the pump
    Reservoir
    http://www.frozencpu.com/products/2184/ex-res-104/XSPC_525_Bay_Reservoir_-_Black.html?tl=g30c97s168
    Ok, now for my questions:
    I looked at the Naturally aspired watercooling thread and read that the radiator should be vertical, but I have seen many times radiators placed horizontal, be it in or out of the case. I'm assuming it doesn't matter, but can it affect performance? Also whats a good northbridge water block, and is it worth it? and finally, tubing. 1/2" id or 3/8" id?
    Any help would be appreciated :toast:
  2. fromeo85 New Member
    Feb 16, 2009
    5 (0.00/day)
    2
    no the radiator can absolutely be horizontal. i personally (and i am sure some will agree) putting the rad horizontal in the top of the case if you can fit it works great because when you need to empty it and put in fresh distilled water and coolant its a lot easier because gravity just pulls the water down
    Maelstrom says thanks.
  3. Maelstrom
    Sep 10, 2008
    534 (0.21/day)
    159
    VA/PA
    Ok thx, I assumed it didn't matter, but good to know anyways
  4. aspire
    May 27, 2007
    290 (0.10/day)
    30
    Get a DDC 3.2 instead of a D-5 B.
    Pair that with the XSPC Acrylic top and you'll see better performance, smaller footprint, and a cheaper price tag.
  5. Maelstrom
    Sep 10, 2008
    534 (0.21/day)
    159
    VA/PA
    Yeah I see your point, but at least for where I planned to put the pump, the other would be better because I could set up the fittings horizontal. But if I put on top of my psu (probably wouldn't be the smartest thing :laugh:) it could work i think. I'll have to look @ where i can place the thing more thoroughly
  6. aspire
    May 27, 2007
    290 (0.10/day)
    30
    My DDC is setup with the outlet pointing upwards... I think that's what your talking about...
  7. Maelstrom
    Sep 10, 2008
    534 (0.21/day)
    159
    VA/PA
    Actually nevermind, I found another top that will put the outlet/inlet horizontal (with the pump set flat). Should be a bit cheaper
Share This Page
