wired home network problem
47 (0.01/day)
Ohio
Processor HTPC: 965BE 3.7GHz - Main Rig: FX-8150 3.6GHz
Motherboard ASUS M4A79 Deluxe - AsRock 990FX Killer
Cooling Arctic - Heatkiller/XSPC
Memory 8 gig GSkill 1066 - 8 gig Team Vulcan
Video Card(s) HIS 4670 - XFX R7 260X
Storage 1TB Samsung&2 WD 500GB - 250GB EVO SSD,WD 500GB, WD 640GB
Display(s) Toshiba 32" TV - Planar PX2710MW
Case Fractal Node 605 - Fractal Arc Midi R2 candy apple red over gold metallic
Audio Device(s) onboard - onboard
Power Supply PC power&cooling 750w - PC Power&Cooling 600w
Mouse Mini keyboard w/trackball - Intellimouse from Alienware (2002)
Keyboard Mini keyboard w/trackball - Antec
Software Win 7 Ult.SP1 - Ultimate Edition 4.2
I have a wired home network using internet connection sharing. (I'm stuck with dial-up) My internet gateway uses XP home. Have 5 other computers sharing the internet connection, file and printer sharing. All the other pc's use XP pro except for one linux machine. I have 2 linksys ezx55w workgroup switches. Everything has been fine until the end of July, one of the XP pro machines suddenly would not connect to the internet, printer, or access files on the other machines. Network connections show it's connected to the lan at 100 Mbps. All lights on the workgroup switches are on, green light is on on the back of the pc where the ethernet cable plugs in. Was going to re-install Windows, but today another XP pro machine started having the same problem. I have the IP addresses configured manually, if I use automatic IP addressing, I have limited or no connectivity. Could I have a bad workgroup switch even though the machines show they are connected at 100 Mbps ? Not sure what to do at this piont. Any help would be appreciated.
ipconfig in cmd =)
