qubit
Overclocked quantum bit
- Dec 6, 2007
- 17,865 (2.98/day)
- Quantum Well UK
System Name | Quantumville™ |
Processor | Intel Core i7-2700K @ 4GHz |
Motherboard | Asus P8Z68-V PRO/GEN3 |
Cooling | Noctua NH-D14 |
Memory | 16GB (2 x 8GB Corsair Vengeance Black DDR3 PC3-12800 C9 1600MHz) |
Video Card(s) | MSI RTX 2080 SUPER Gaming X Trio |
Storage | Samsung 850 Pro 256GB | WD Black 4TB | WD Blue 6TB |
Display(s) | ASUS ROG Strix XG27UQR (4K, 144Hz, G-SYNC compatible) | Asus MG28UQ (4K, 60Hz, FreeSync compatible) |
Case | Cooler Master HAF 922 |
Audio Device(s) | Creative Sound Blaster X-Fi Fatal1ty PCIe |
Power Supply | Corsair AX1600i |
Mouse | Microsoft Intellimouse Pro - Black Shadow |
Keyboard | Yes |
Software | Windows 10 Pro 64-bit |
Well, I can hear a quiet fan in my open case and I also have very quiet fans on my CPU cooler and the PSU fan is quiet-ish so the PC doesn't make much noise. Therefore, I certainly like the 0dB feature. Also, the card does look really clean since it's pointing downwards and there's no airflow to attract dust. The downside of course, is that it does run a bit warmer, but it's not a problem.This is what I do and it makes the most sense. Not just because I do it though, but hey
No one is going to convince me that a zero-DB fan will live longer than one that can keep spinning all the time - same as HDDs that die faster when they're put to sleep every five minutes. At the same time, you can't hear a good fan at low RPM anyway so the usefulness of 0dB eludes me. And then there is the obvious hot GPU in the case at idle that you also get to avoid when you just keep that fan going.
I'm gonna look to setting a custom profile using AfterBurner. I finally got round to playing with it last night and I can see that it supports hysteresis, so this might finally fix the problem. Looking at newtekie's last post, I can that I've been meaning to do this for a month, lol.
