x-over cable/straight-through cable + uplink switch
Discussion in 'Networking & Security' started by Viscarious, Feb 18, 2009.
  1. Viscarious New Member
    May 17, 2008
    951 (0.34/day)
    149
    Can I interchange a crossover and straight-through cable by toggling the uplink switch or a switch/hub? I cant find any info on this matter anywhere. I get too consice when trying to google this and return 0 results. =[
  2. Darknova
    Darknova
    Nov 8, 2006
    5,037 (1.49/day)
    536
    Manchester, United Kingdom
    Crossover cables are generally used when connecting one device to another. A switch uses straight-through cables.
    So I don't know. You could always try it, you won't damage anything, it just won't work.
    Viscarious says thanks.
  3. Hybrid_theory
    Hybrid_theory
    Mar 31, 2007
    1,895 (0.59/day)
    163
    ontario canada
    Well if its hub to hub you have to use the cross over unless the device you have can switch it virtually. But usually it's more expensive equipment that have that functionality.
  4. AUTOgod
    AUTOgod
    Jan 28, 2009
    104 (0.04/day)
    3
    the only thing that i have that cant change its pinout to match a different type of cable is a crappy netgear pci card. everything else i have doesnt seem to care, but then i dont have any hubs, all switches. but hubs do need to use a special uplink port with a switch to accomodate the different cable type.
  5. Hybrid_theory
    Hybrid_theory
    Mar 31, 2007
    1,895 (0.59/day)
    163
    ontario canada
    Hub to switch should be crossover as well.
  6. AUTOgod
    AUTOgod
    Jan 28, 2009
    104 (0.04/day)
    3
    see thats what i thought as well, but ive never had any experience with hubs, only switches (got 5 including 2 routers, all full :laugh: )
  7. DanTheBanjoman SeƱor Moderator
    May 20, 2004
    10,546 (2.46/day)
    1,384
    It's part of the gigabit standard, all gigabit hardware can do it.
    10 Year Member at TPU
