İs My GPU overheating?
6 (0.01/day)
Turkiye
System Name PC
Processor Ryzen 5 5600
Motherboard Asus Prime B450M-A 2
Cooling Wraith Stealth
Memory Fury Beast 3200mhz 8x2 gb
Video Card(s) Asus Dual RTX 3060Ti GDDR6X
Storage WD Geen 480GB m.2 ssd
Display(s) Gigabyte G24F-2
Case Powerboost k521b
Power Supply NZXT C750 Bronze
Software Win11 Pro
Hi everyone!
İ'm using Asus dual rtx3060ti gddr6x and it heats up to 85 degrees in some games. İ also did the furmark test(8xmsaa, 1080p) and the result is: 79 degrees at %89 fan speed in 15 minutes. İn Doom Eternal 71-77 degrees at ultra nightmare settings, rtx off and dlss in quality mode. İs these results are normal or abnormal?
Hi everyone!
i know that gddr6x runs very hot possibly heat soaking rest of board. that version of card isnt the best cooling option either.... are those temps in closed case? try testing a game with front cover off and tell us the difference. also needto know ur ambient temperature in the room pc is in.
Yes, these temps are in a closed case, but my front panel is mesh.
well then ur temps are were they should be. cool your room better or take side cover off when gaming if u want lower temps
İs there any problem when it gets hot?
dont worry normal temps during gaming
Solution
Thank you for your answers guys.
İ took side cover and front panel off but the temps are changed by -2 degrees. Anyway it not bad i think.
And i forgot to say, i want to buy 2 more exhaust fans on the top of the case, will this help lower the temps down?
it may help a smidge . but ur inside case temp will always be your room temp at lowest
