System Name | Juliette // My HTPC |
Processor | Intel i7 9700K // AMD Ryzen 5 5600G |
Motherboard | ASUS Prime Z390X-A // ASRock B550 ITX-AC |
Cooling | Noctua NH-U12 Black // Stock |
Memory | Corsair DDR4 3600 32gb //G.SKILL Trident Z Royal Series 16GB (2 x 8GB) 3600 |
Video Card(s) | ASUS RTX4070 OC// ASUS RTX 4060 OC |
Storage | Samsung 970 EVO NVMe 1Tb, Intel 665p Series M.2 2280 1TB // Samsung 1Tb SSD |
Display(s) | ASUS VP348QGL 34" Quad HD 3440 x 1440 // 55" LG 4K SK8000 Series |
Case | Seasonic SYNCRO Q7// Silverstone Granada GD05 |
Audio Device(s) | Focusrite Scarlett 4i4 // HDMI to Samsung HW-R650 sound bar |
Power Supply | Seasonic SYNCRO 750 W // CORSAIR Vengeance 650M |
Mouse | G903 and a Master Mouse MM710/No mouse, MS game copntroller |
Keyboard | EVGA / Logitech K400 |
Software | Windows 11 Pro // Windows 10 Pro |
System Name | PCGOD |
Processor | AMD FX 8350@ 5.0GHz |
Motherboard | Asus TUF 990FX Sabertooth R2 2901 Bios |
Cooling | Scythe Ashura, 2×BitFenix 230mm Spectre Pro LED (Blue,Green), 2x BitFenix 140mm Spectre Pro LED |
Memory | 16 GB Gskill Ripjaws X 2133 (2400 OC, 10-10-12-20-20, 1T, 1.65V) |
Video Card(s) | AMD Radeon 290 Sapphire Vapor-X |
Storage | Samsung 840 Pro 256GB, WD Velociraptor 1TB |
Display(s) | NEC Multisync LCD 1700V (Display Port Adapter) |
Case | AeroCool Xpredator Evil Blue Edition |
Audio Device(s) | Creative Labs Sound Blaster ZxR |
Power Supply | Seasonic 1250 XM2 Series (XP3) |
Mouse | Roccat Kone XTD |
Keyboard | Roccat Ryos MK Pro |
Software | Windows 7 Pro 64 |
System Name | LGA775 | BoX-Server |
Processor | Xeon E5450 OC3.6GHZ from 3GHZ | i3 3.4GHZ |
Motherboard | ASUS PQ5-EM | ASRock |
Cooling | 120MM Heatsink (2-FANs) | Custom HSK 90mm |
Memory | DDR2 2GB-x4=8GB | 8GB 2x4GB=8GB |
Video Card(s) | NVIDIA Quadro K2200 4GB | Intel |
Storage | 500\500/240/240GB SSDs 120GB Laptop IDE |
Display(s) | Asus 24" |
Case | DIYPC N1e-SPORT | CoolerMaster 110 |
Audio Device(s) | Onboard |
Power Supply | EVGA 550WATT | Rosewill 530WATT |
Mouse | Rosewill RGB |
Keyboard | Rosewill RGB |
Software | WiN10ET/WiN11ET |
Ahh thank you I will download it, should i be looking for the information in the cpu, gpu, or ram section about memory clock?Its just not reading it. Try CPU-Z
System Name | BY-2021 |
Processor | AMD Ryzen 7 5800X (65w eco profile) |
Motherboard | MSI B550 Gaming Plus |
Cooling | Scythe Mugen (rev 5) |
Memory | 2 x Kingston HyperX DDR4-3200 32 GiB |
Video Card(s) | AMD Radeon RX 7900 XT |
Storage | Samsung 980 Pro, Seagate Exos X20 TB 7200 RPM |
Display(s) | Nixeus NX-EDG274K (3840x2160@144 DP) + Samsung SyncMaster 906BW (1440x900@60 HDMI-DVI) |
Case | Coolermaster HAF 932 w/ USB 3.0 5.25" bay + USB 3.2 (A+C) 3.5" bay |
Audio Device(s) | Realtek ALC1150, Micca OriGen+ |
Power Supply | Enermax Platimax 850w |
Mouse | Nixeus REVEL-X |
Keyboard | Tesoro Excalibur |
Software | Windows 10 Home 64-bit |
Benchmark Scores | Faster than the tortoise; slower than the hare. |
Yes the only issue is with ryzen, Cpu Z and task manager show correct ram mhz. As for driver question, are you referring to bios I am new to computer stuff srryWhich version of drivers are you running? Just seeing problems with Ryzen? What graphics device is installed?
Vanguard doesn't deal with Ryzen unless it's the GPU side of the APUs.@FordGT90Concept, @AlienIsGOD, @INSTG8R
send a bug report to amd, be as specific as you can be about this please. Also send a bug report to userbench...
I'd update BIOS version if you haven't already. Failing that, contact MSI technical support.
