- Sep 16, 2013
- 1,357 (0.31/day)
- Canada
System Name | HTPC |
Processor | Intel Core 2 Duo E8400 - 3.00/6M/1333 |
Motherboard | AsRock G31M-GS R2.0 |
Cooling | CoolerMaster Vortex 752 - Black |
Memory | 4 Go (2x2) Kingston ValueRam DDR2-800 |
Video Card(s) | Asus EN8600GT/HTDP/512M |
Storage | WD 3200AAKS |
Display(s) | 32" Irico E320GV-FHD |
Case | Aerocool Qx-2000 |
Audio Device(s) | Onboard |
Power Supply | Enermax NoiseTaker 2 - 465w |
Mouse | Logitech Wave MK550 combo (M510) |
Keyboard | Logitech Wave MK550 combo (K350) |
Software | Win_7_Pro-French |
Benchmark Scores | Windows index : 6.5 / 6.5 / 5.6 / 6.3 / 5.9 |
I want to put a 120mm pwm fan on my case but i dont want to split the only 4 pins of cpu fan with it in case it cant take it and block the capacitors. So I want to keep the rpm wire and the pwm wire connected then cut the + and - wires to connect-mod them on a molex. Is it a good way? Will the pwm still onboard going to make it turn the way as original or i need to leave the + or - still connected to mobo too?
Thx
Thx
