Bongbuster
- Dec 11, 2006
- 65 (0.01/day)
Hi, I have no idea about motherboards that use two graphics cards so I need help bad
My situation is I need a PC that can run 3 or 4 monitors at the same time. For example I can display a different application on each monitor.
I know you can get MB's with two PCI slots such as gigabyte 785gt-ud3h which I am (was) planning on buying. I've also found out that you can two cards in a crossfire configuration on a crossfire compatible MB like the gigabyte ma790fx-dq6.
I find this confusing so i have some questions.
1-Can two graphics cards in crossfire configuration run 3 to 4 monitors like I want?
2-If you have two graphics cards that are not in a crossfire configuration and are only running monitors off one of those cards, the second card will not be used will it? (stupid question but want to make sure)
3-Which type of 2 PCI slot MB is normally more expensive, the crossfire compatible or the non crossfire compatible?
