200mm fan that came with my Phanteks Mini ITX or two Noctua NF-A14?
272 (0.06/day)
i have seen a lot of people using this fans, i have never used them.
that is the fan that came with my case, is it good enough?
is it better to buy two of this: http://www.amazon.com/Bearing-Cooling-NF-A14-iPPC-2000-PWM/dp/B00KFCRMSG/ref=cm_cr_pr_product_top?ie=UTF8
2,098 (0.51/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
TBH I would keep the 200 mm fan and see how it does before deciding to replace it.
Kursah
Super Moderator
14,763 (2.18/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I'm sure it'll work well...all 200mm fans I've used have been airflow monsters. Some were quieter than others, but overall, everyone of them had good airflow. Plus the nice thing is if that fan fails you can then choose if you stick with 200mm or go 2X 140mm at that point. Might as well give it a go before ripping it out, Phanteks has some decent fans in my experience.
What is your goal with the intake fan on this case? Airflow? Noise? Durability? What do you consider good for your case fans? I think it depends on what you want...I can assume you want airflow for cooling, silence and lower airflow, or a happy medium...but I'd rather know what you want first.
272 (0.06/day)
i like the silence.... but also i want to keep a good airflow inside to keep good temps.
1,618 (0.27/day)
it's a large fan, it moves air, i doubt phanteks would be stupid
the cpu & gpu heatsinks are going to affect temps more
Kursah
Super Moderator
14,763 (2.18/day)
Missoula, MT, USA
Odds are this 200mm fan will provide both, or enough of both to keep you content...I still stick by waiting and just using that fan in the first place.
Kursah
Super Moderator
14,763 (2.18/day)
Missoula, MT, USA
Yep they're good fans, good quality, good warranty.
407 (0.12/day)
UK
System Name it needs a name?
Processor Xeon E3-1241 v3 @3.5GHz- standard clock
Motherboard Asus Z97A 3.1
Cooling Bequiet! Dark Rock 3 CPU cooler, 2 x 140mm intake and 1 x 120mm exhaust PWM fans in the case
Memory 16 GB Crucial DDR3 1600MHz CL9 Ballistix Sport 2 x 8 GB
Video Card(s) Palit 980ti Super Jetscream
Storage Sandisk X110 256GB SSD, Sandisk Ultra II 960GB SSD, 640GB WD Blue, 12TB Ultrastar
Display(s) Acer XB270HU
Case Lian Li PC 7H
Audio Device(s) Focusrite Scarlett 6i6 USB interface
Power Supply Seasonic P660
Mouse cheapo logitech wireless
Keyboard some keyboard from the 90's
Software Win10pro 64bit
I have 2 NFA 14 PWM fans in my case.
They are inaudible at tickover and reasonably quiet when flat out. but at medium rpm they have an annoying resonant sound.
They provide good cooling.
The resonant sound does annoy me but it isn't a massive problem as my fans only spin up more than 500 rpm when gaming or similar high usage, so I usually have headphones or speakers to cover up the noise.
272 (0.06/day)
The resonant sound does annoy me but it isn't a massive problem as my fans only spin up when gaming, so I usually have headphones or speakers to cover up the noise.
i was seeying this:
Noctua SSO2 Bearing Fan Retail Cooling NF-A14 iPPC-2000
non-PWM fans, they will be loud too or not? (my pc is next to me)
8,253 (1.17/day)
System Name money pit..
Power Supply EVGA 850 watt..
Mouse Logitech G700s
Keyboard Logitech K270
Software Win 10 pro..
good..
but i still need a 140mm at the rear, this noctua fans are good?
i doubt you do with a bloody great thing like that at the front and all those vent holes at the back.. :)
but it does all depend on what you are going to put inside the case..
if you do fit one at the back.. you dont need a 2000 rpm fan.. a pwm 1350 is enough.. all fans should be pwm if possible.. both from a noise and dust point of view..
all blowing more air than needed though a case does is fill it full of dust and crud quicker..
trog
272 (0.06/day)
trog
so, with a 200mm front and 1 140mm back and 1 140mm top is good enough?
8,253 (1.17/day)
more than good enough.. he he
but you still need good coolers on the cpu and gpu.. excessive case cooling wont make up for poor cpu or gpu coolers..
trog
407 (0.12/day)
UK
Case Lian Li PC 7H
What CPU, what CPU cooler and what GPU combination are you going to be using?
The amount of air movement you need is proportional to the amount of heat your rig dumps inside the case.
272 (0.06/day)
i7-6700 non-k
gtx980ti
evga nitx cooler
8,253 (1.17/day)
the next question of course is how much to you intend to overclock your CPU.. at stock levels cooling is not a problem.. but to get 10% more performance will often generate twice the heat.. overclocking is fun but it does have its downsides.. he he
but i see a none K cpu so maybe you will leave it at stock.. :)
the obsession with cooling is directly linked to overclocked parts.. one goes with the other.. :)
trog
