2080 Super Max Q vBios
Messing with the VBIOS on a laptop is a bad idea.
In some cases, it is integrated with the main BIOS and flashing may result in a bricked laptop.
There is only one RTX 2080 Super Max Q in the database:
Do it at own risk, and only if you have external graphics.
You can try searching the device ID on the main page custom search. Maybe you'll find more.
Good chances you're already hitting the thermal limits.
I managed to get one from Reddit and flashed it to my card. Now I pull over 100w under full load and temps havent gone over the high 60's yet. Well worth it to those considering
Could you either post this or point us to where you got it? I've been trying to obtain a higher power 2080 Super Max-Q BIOS for my 2020 Blade 15.
