3 ddr400 512's dual channel?
newmodder
669 (0.09/day)
british columbia
System Name Gamer
Processor amd phenom quad core 9950 black edition
Motherboard msi ms-7309
Cooling 120mm front,120mm rear
Memory 2gigs ddr2 800
Video Card(s) BFG gtx 260 maxcore
Storage wd 160gig sata2 hd
Display(s) LG 20in widescreen
Case USP 100
Audio Device(s) onboard Logitech x-530 5.1 spkrs
Power Supply Antec Neo 550watt
Software windows 7 Ultimate 64 bit
i have 3 sticks of 512 ddr400 can i make those run in dual channel or would i have to buy one more stick?...i have 2 installed right now running in dual channel.
Even number are required for dual channel. 1 more or stay with two.
tried 3
yeh i tried 3 and i got worse perforamce so i think i will just stay with 2 until i get another stick. thanks for the reply:rockout:
u might find u get worse performance with 4 sticks as well.. it will default to 2t memory timings instead of 1T.. 2 one gig sticks gives the best performance..
bit of a bugger having to throw 3 perfectly good 512 sticks away thow just to go 2 gig and keep the faster memory timings.. he he he
your saving grace is at least u dont seem to have expensive superfast 512 sticks to throw away..
trog
ps.. best to stay with one gig.. your grfx cards wont play high enough resolutions for u to really need the two.. unless u need more memory for something other than gaming.. if u really do need more memory its decision time.. he he
the way mem ctrl handle the banks IS "important"
i think its just an amd 64 on chip memory controler thing.. they used to default to 333 with all banks full and dual channel.. now they stay at 400 just sneakily drop the timing to 2T.. which has pretty much the same effect.. just dosnt sound quite as bad..
trog
