478 and PCI-E
1,977 (0.29/day)
Fremont, Ohio
System Name The Darkside
Processor Ryzen 5 3600
Motherboard ASRock B550 Extreme4
Cooling OEM
Memory 16gb G.Skill Fortis
Video Card(s) MSI Seahawk 1070
Storage 500gb Mushkin Pilot NVMe
Display(s) 55" Samsung 4k UHD
Case Corsair iCue 465X RGB
Audio Device(s) Onboard Reltek
Power Supply Corsair AX860i
Exactly how rare is a socket 478 and PCI-E mobo? I know its almost worthless to have one but the ones i found are damned expensive and I know getting the LGA775 with PCI-E is better.:confused:
all right I found all the forums for this complication took awhile but found most everything. I would like to find one of those Albatron PX915P4 Pro mobos. I just dont really want to spend all that money to upgrade to LGA775 mobo and cpu, but sometimes performance comes at a cost
* ASUS P4GPL-X
* ASUS P4GD1
* Albatron PX915P4C Pro
* ASRock P4Dual-915GL.
they are pricy...and rare.
Very rare indeed, found a P4GD1 on ebay once it went for 80GBP in the end!!
yea the ones I found went for $100+!
Give up on a s478 PCIe hybrid.
I think you want a decent GPU. Get yourself a X1950 AGP, use your existing CPU, RAM, HDD, and no new OS to install.
well i did and am getting a LGA 775 and already have a X800XL PCI-E with a Arctic silencer 5 on it for $85. Just need my mobo and processor to come in, cant wait!
I hope you enjoy your new Core 2 Duo ;-)
Which m/b did you go for? Recycling DDR or need to buy DDR2?
Well on my budget Im recycling my DDR and getting a ECS RS400-A, then in about 2-3 months getting my Asus mobo and DDR2, not sure what kind but a heck of an upgrade from my 478 celeron and 9600XT.
Make sure you get a mainboard with Core 2 compatability, DDR, and (possibly) AGP. Then you can upgrade the CPU easy, and up the GPU whenever you want... to 9800 to X800 to X1950, depending on budget.
buy this one then:
ASROCK 775DUAL-VSTA SOCKET 775
I already have a Sapphire X800XL PCI-E
